swaybars or bushings. which one first? - ClubRoadster.net
Old 04-20-2010, 04:50 PM   #1 (permalink)
oldskoolroadster's Avatar
Default swaybars or bushings. which one first?
which ones to go and buy/install first? so i can save some money or just hoard em then just do one install. can anyone shed a light into this/ thanks a lot.
"Never forget who you are, for surely the world wont. Make it your strength. Then it can never be your weakness. Armor yourself in it, and it will never be used to hurt you."
oldskoolroadster is online now   Reply With Quote
Old 04-20-2010, 04:53 PM   #2 (permalink)
King of Hella Stance Swag
monkey.magicx's Avatar
Default Re: swaybars or bushings. which one first?
Bushings are going to affect your ride quality much more than sways, and aren't going to decrease roll.
Two kinda different things.
92 NA6 - Dead.
99 NB8 - Rice plate.
GarageStar
caosgomoo
Fat Cat Motorsports
monkey.magicx is offline   Reply With Quote
Old 04-20-2010, 05:00 PM   #3 (permalink)
so is it better to do sways first? im just concern of putting the swaybars in. then finding out i gotta take em out again to install the bushings. time and money just wanna do it right the first time.
Old 04-20-2010, 05:05 PM   #4 (permalink)
Swaybars take like 45 minutes tops. You don't even have to remove them to install a bushing kit, unless if you're changing sway bar bushings...which should be new with your sway bars.
92 NA6 - Dead.
GarageStar
caosgomoo
Fat Cat Motorsports
Old 04-20-2010, 05:10 PM   #5 (permalink)
thanks for the info, i guess ill get the sways in then buy the bushings at a later time.
Old 04-20-2010, 10:05 PM   #6 (permalink)
Big Pimpin'
Flyin' 92's Avatar
Depending on your suspension set up you should be able to get away with just a front sway bar. I'd recommend the RB hollow front bar if you got that route.
Originally Posted by AntiochOG View Post
Some day I hope to have the problem of having a car that is so dope I am bored with it.
Best build thread in the history of build threads
Flyin' 92 is online now   Reply With Quote
Old 04-20-2010, 10:26 PM   #7 (permalink)
Max_Power's Avatar
Swaybars first but as Flyin said just get a RB big sway bar for the front and leave the stock rear bar...
Then when you get more power you will feel like removing even the stock small bar...
Chris
Old 04-21-2010, 12:58 AM   #8 (permalink)
RB tubular front bar and 949racing endlinks
jacob300zx is offline   Reply With Quote
Old 04-21-2010, 07:33 AM   #9 (permalink)
this is my route, rb sway front and back and 949racing endlinks w/ rb front brace kit. comes out to $538.79 just a little pass 500 bucks. the FM sways are cheaper. but brian goodwin and 949 is local to me. so they ship faster.
Old 04-21-2010, 10:36 AM   #10 (permalink)
adam777's Avatar
Skip the rear bar. Not really needed. I have the OEM rear with the RB fron and 949 Links all around. Feels great. Save the cash on the rear bar.
adam777 is offline   Reply With Quote
Old 04-21-2010, 10:53 AM   #11 (permalink)
Official Armchair Racer
stormin'norman's Avatar
Like everyone's said... you're money is better spent elsewhere than on a rear bar.
"I think I'll go buy one of those large foam hands you see at sporting events and zip tie it to my left mirror in a permanent point-by position." -Rich Cohn Lee
stormin'norman is offline   Reply With Quote
Old 04-22-2010, 09:12 AM   #12 (permalink)
KJR50's Avatar
Get your RB F sway and Energy Suspension Poly bushings from RB, best price on master set.
KJR50 is offline   Reply With Quote
Old 04-22-2010, 09:31 AM   #13 (permalink)
Racing Beat carries prothane.. Not ES
Old 04-22-2010, 12:49 PM   #14 (permalink)
Big Pimpin'
Flyin' 92's Avatar
This! Miatas are prone to oversteer, so by removing the rear sway and adding a bigger front it more or less gives the car more neutrality and a touch more understeer. You'll be pleasently surprised how much better the car will feel without a rear bar.
