#1 (permalink) |
Does anyone know if their are companies that make aftermarket front control arms? upper and lower. My ball joints are torn and i'd like to upgrade to something beefier or higher performance.
thanks I also saw a website where a guy had RP Speed drift tie rods. Just curious if anyone knew where he got them. ![]() thanks guys |
#4 (permalink) | ||
#5 (permalink) | |
Stop it, just because you have been to a track DOES NOT make you a road racer... http://www.sloganizer.net/en/style8,...otorsports.png http://i31.photobucket.com/albums/c3...ed/Burnout.gif 2 Mazdas and 2 Hondas, I'm having trouble moving around in my garage these days... |
#6 (permalink) | |
#7 (permalink) |
I see what you guys mean. All my ball joints are shot so I figured I'd upgrade.
factory upper control arms were like $200 at the dealer!!!! thanks alot for all the help. I'm pretty new to the mazda scene so i dont know too much about aftermarket components. |
#8 (permalink) |
I'm pretty sure you can replace the ball joints themselves.
As for tie rod ends and inner tie rods, they aren't very expensive. However, if you can, look into 93LE tie rods. They handle bumpsteer much better on lowered cars b/c they were designed for the R pkg. and 93 LE which sit about 3/8-1/2" lower than stock 90-91 Miatas (the lowest of the non-special models). |
Man, you know what reminds me of a 240sx? The 1984 Cadillac Eldorado. - VitaminT |
#9 (permalink) |
lower ball joints are easy to replace and cost arounnd $60-70+ ea for OEM or just get cheaper non-oem ones for about $50 a pair....upper ball joints are a diifferent story tho, they usually come pre assembled with the upper control arm from the factory...if your boots are torn you can just re-pack it with grease and put new dust boots for under $20 pair
#10 (permalink) |
I ordered the rp rods from japan, pricey but ive ran into a wall with them and thet held up
+1 on the rpackage outters but just washer the tierods for more angle, and use rpackage outters and you will be fine. oem inners are just fine and easy to replace |
#12 (permalink) |
They cost about 3 g's. And I only know a few people who have them on their race cars (biggest being Andrew Fernandez's E Prod NB).
#13 (permalink) |
I could easily see mild cars running front upper control arms. These cars could definately use more front camber at the track.
2008 Redline TimeAttack! Grand Champion [img]hhttp://photos-g.ak.facebook.com/photos-ak-snc1/v271/25/27/561716982/n561716982_1086838_2140.jpg[/img] |
