#2 (permalink) | |
Guest
Posts: n/a
You have to knock off the perches. They pop right off if you give them a wack vertically. No cutting needed, as on Illuminas. It's hard to tell with the small pic, but it looks like you got the wrong ID tubes. They should have a shoulder inside that catches on the flange that remains after you remove the perch. |
#3 (permalink) |
Ok i got a bigger pic. i need to remove the perch that the tube is sitting on, but do i also need to remove the lower perch? Couldn't it just rest on the lower perch where the stock springs would rest?
#4 (permalink) |
Guest
Posts: n/a
The perch is all one piece that pops off. It's just pressed on but the paint may keep it from slipping off easily.
If you have a vice, set the edges of the perch on the jaws and give the top of the body a wack (not the shaft, the body). The perch should pop off, leaving a very thin flange on the body that the GC tube will slip over. |
#5 (permalink) |
I don't think these are GC. I'm pretty sure they are knock offs. So am i removing #1 or #2 or are they both one piece. Couldn't the tubes rest on #2 like regular springs would? Sorry im so confusing
#6 (permalink) |
GC`s use Eibach springs...are those? Looking at the pic I would say those are knock offs, the threaded part of the sleeves go all the way to the bottom, those don`t.
If those are knock offs then you have to keep the spring perch on or the sleeves won`t have anything to sit on. The flange is way too smallin dimater to catch the sleeves. |
#7 (permalink) | |
#9 (permalink) | |
Guest
Posts: n/a
#10 (permalink) |
Guest
Posts: n/a
Except for the gold adjusters, it looks like these are the sleeves you got:
![]() http://clubroadster.net/forum/viewtopic.php?t=5033 |
#11 (permalink) | ||
