#1 (permalink) |
My '97 M has developed a strange problem.
Since I bought it (3 weeks ago) it has always pulled slightly to the right. But tonight, things got weird. Under acceleration, it now pulls hard to the right, but when I lift off the throttle, it snaps hard to the left, and will continue to pull to the left as long as the car is under deceleration. Has anyone had this happen? Any ideas? Thanks! |
#4 (permalink) |
Lit like a BranchDavidian
98% that it's uneven tire pressure in the rear. That's a tell-tale charistic of the torsen LSD when tires o nthe rear are uneven. You also want to make sure you are runnign the same type tire on the rear as well as tires with even amounts of tread.
The car is on fire, and there is no driver at the wheel. ![]() 2002 Ti SE Turbo
