#1 (permalink) |
im looking for a good suspension set up for daily driving. i want it drop at close to the tire at possible ( planning to buy the sportmax 501 with 15offset. )
should i go with tein basic? or some mix stuffs? please help. |
-Current 04 RED NB LS, Stance GR+, 16 x 8 XXR 521, Enthuza exhaust, Hard Dog Rollbar. -SOLD - 99 NB silver / tein flex / sportmax 002 / ebay exhuast / NGK sparks plug and Wires / Racing Beat intake. |
#3 (permalink) | |
The AGX shock bodies are about stock length, whereas the Teins have shortened bodies. That's one advantage over the AGXs. |
#4 (permalink) | ||
91 miata turbocharged 90 miata with wiring issues |
#5 (permalink) |
^^^^ Yea fuck koni/ground controll, its only a proven SCCA national winning set up. (moran)
http://www.hondamarketplace.com/show....php?t=2458437 |
#6 (permalink) | |
Mufasa in Training
The fact is AGX's just don't support very competetive spring rates. They are basically one step up from stock shocks. |
#7 (permalink) | ||
I'm a big fan of my Flex coilovers and they really do let you get the car low, prevent bottoming out on the bumpstops, and are fairly comfortable with the damping turned down. |
#8 (permalink) | ||
'Bout dat life
i wonder what i really am smoking. |
#9 (permalink) | ||
Mufasa in Training
#13 (permalink) | |
#14 (permalink) | ||
Mufasa in Training
#15 (permalink) |
Best $800 suspension:
Converted NB Mounts ($100 if you DIY) Short bumpstops ($100) Bilstein HD Shocks (super cheap used, $400 new) Racing Beat big front anti-sway bar ($200, with hardware kit) If you find a used set of Bilsteins, they're cheap to have revalved - something like $65 a shock, built to handle any spring rate you want. There's a lot of new info suggesting that the Bilstein HD's can handle much higher spring rates than stock - in the 400 lb range - even right off the shelf. If you're adventurous, lots of people have had success with eBay coilovers - just use the sleeves, and junk the springs, and replace them with QA-1's or Eibachs of the correct length, diameter, and rate. You can have the same set up as a Ground Control kit for significantly less money. National champion autocross drivers have vouched for the effectiveness of this setup. |
#16 (permalink) | |||
#17 (permalink) | |
I'm not really a fan of the tein stuff. especially thier low end stuff. The ground control sleeve and a quality spring is a good way to get hieght adjustment. Spring choice is important. Cheap springs can be under $100 a pair new. quality ones (KW, Swift, etc) can be $200 a pair. You get consistancy and repeatability with these. With Tein Springs and others, you don't really know if the spring rate they are labeled with is really thier spring rate. If you want your suspension to "work" and you want it low, you will need stiffer than normal spring rates to use it on the street, and you won't want to cut your bumpstops. Bump stops have a built in spring rate to keep your car from becoming completely unsettled when you hit them. If you cut them, your shock body gets slammed into the chassis of the car when it bottoms out. this makes a car extremely hard to drive. If you are on a budget, get the Koni yellows or a set of bilsteins, a set of upper mounts, and gc sleeves. |
2008 Redline TimeAttack! Grand Champion [img]hhttp://photos-g.ak.facebook.com/photos-ak-snc1/v271/25/27/561716982/n561716982_1086838_2140.jpg[/img] |
#18 (permalink) |
thanks for all the advices. my cousin going to order for me the tein SS
#19 (permalink) | |
#20 (permalink) | |||
I drift this setup, the rates are not ideal for autox. but its a pretty snappy weight transfer. --add I dissembled and inspected my suspension last fall (last significant driving really) and my shocks arent dead but I dont know how long that will be true., when they go they will be replaced with koni race in front and sport in rear. the miata has been kinda sidelined in various states of repair since December. |
Stop (brakes), Drop(suspension), then Roll (power) -hooked_on4 |
