Do I already have 93LE tie rod ends? - ClubRoadster.net
Old 08-10-2012, 10:04 PM   #1 (permalink)
circuitmstr's Avatar
Default Do I already have 93LE tie rod ends?
Based on the pictures on "revlimiter" website about the 93le tie rod end swap. Mine appear taht they might be the 93le ones already because the end of them are square... Uh, i cant tell. Because He also says that other non LE ones came with square ends. Well thats confusing. haha
hopefully someone can help me out. Here is a picture:
MacGruber drives one...!
circuitmstr is offline   Reply With Quote
Old 08-11-2012, 09:28 AM   #2 (permalink)
Default Re: Do I already have 93LE tie rod ends?
can anyone chime in?
Old 08-11-2012, 10:40 AM   #3 (permalink)
Any part numbers legible?
'94 Sepang blue project :: '95 flat black, HT | riced, JR45
'89 2WD, burgandy, Lariat F-150 | leveled w/ 31s
Originally Posted by nannerpus View Post
PUT THE THING IN THE THING THAT THE BOOK SAYS TO PUT IN THE THING
(Adam) is offline   Reply With Quote
Old 08-11-2012, 02:02 PM   #4 (permalink)
No I don't see any part#
Old 08-11-2012, 02:20 PM   #5 (permalink)
ill chime in in a few hours. my guess is no because the boot on the LE/r rods sits different than the regular ones. my 94 ends had the square ends and i too thought i had LE/r rods ends until i did the swap
Twibs415 is offline   Reply With Quote
Old 08-11-2012, 09:54 PM   #6 (permalink)
ok. Thanks twibs. let me know
Old 08-12-2012, 08:30 PM   #7 (permalink)
Custom Gauge Master
revlimiter's Avatar
You can't tell by looking at them. The LE are nearly identical to the regular ones. The angle is very very slightly different.
No way to tell if there's no part number stamped.
Adam
revlimiter is offline   Reply With Quote
Old 08-12-2012, 08:49 PM   #8 (permalink)
derp forgot to look. there is a difference in the way the boot scrunches up though
