Chikara or Fat Cat - ClubRoadster.net
Old 05-03-2007, 11:14 AM   #1 (permalink)
Esteemed Member
slutz4's Avatar
Default Chikara or Fat Cat
As title states, what is everyones opinion on both companies, and who has the better product??
Id like to get top hats for more travel and a lil lower ride
slutz4 is offline   Reply With Quote
Old 05-03-2007, 01:47 PM   #2 (permalink)
xn7
Default Re: Chikara or Fat Cat
im trying to figure out this same thing, are you going to use it for all 4 corners or just 2(if u have adjustable perches)
it seems pretty hard to bottom out the fronts w/ stiff springs.
xn7 is offline   Reply With Quote
Old 05-03-2007, 01:57 PM   #3 (permalink)
Esteemed Member
slutz4's Avatar
Im goin with all four, theres also another company called NOPRO that makes them as well
Old 05-03-2007, 02:18 PM   #4 (permalink)
I just installed the FCM's with a 375/250 GC setup on Koni Sports - it rides better than stock, even at a very low ride height (12" front, 12.5" rear.) Actually, I had it slammed down to about 11.5" all the way around so my 13x8's would look cool, and even though the ride wasn't bad, it was scraping the crap out of my GV lip.
Thumbs up for the FCM kit (mounts, stops, boots) and Koni shocks.
Benswen is offline   Reply With Quote
Old 05-03-2007, 09:29 PM   #5 (permalink)
STS2's Avatar
I'd go with normal NB mounts, as the FCM are a modified version anyways.
What do you have now, suspension wise?
Kurt
1990 Classic Red Miata (STS/Track)
Photostream
STS2 is offline   Reply With Quote
Old 05-03-2007, 09:35 PM   #6 (permalink)
Esteemed Member
slutz4's Avatar
I dunno, check my garage , running agx's and millen springs. Planning on swapping to high rate springs with top hats. Running that till I blow the agx's and then replacing them with bilsteins
Old 05-03-2007, 09:40 PM   #7 (permalink)
STS2's Avatar
FM mounts, but NB for low budget minded person like myself .
Kurt
Photostream
Old 05-04-2007, 02:36 PM   #8 (permalink)
They don't add travel, just make you lower.
Caleb is offline   Reply With Quote
Old 05-04-2007, 04:39 PM   #9 (permalink)
xn7
well the top mounts let u retain travel at a lowered height.. so thats basically the same thing
actual travel can be gained by using the shorter bumpstops
Old 05-04-2007, 05:07 PM   #10 (permalink)
Right, but only with adjstable height springs. Even then you aren't adding travel, simply shifting the balance of compression and rebound travel.
I have FCM 46mm stops and they made a huge difference, but I can't justify $200+ for 20mm of lowering and "feel". Maybe someday.
Old 05-04-2007, 05:25 PM   #11 (permalink)
xn7
i agree with that ^ except that it does have the same effect on fixed height springs. installing the upgraded tops effectively shifts all relevant surfaces of the upper spring perch upward vs stock.
Old 05-04-2007, 06:09 PM   #12 (permalink)
Sponsor
reckless_abandon's Avatar
when it comes to top hats, its same shit different hand.
chikara is nothing special, i know for a fact. but probably wont break.
visit Rev9 Autosport for all your jdm roadster needs!
the rotary roadster build
speedhunters coverage
reckless_abandon is offline   Reply With Quote
Old 05-06-2007, 11:42 PM   #13 (permalink)
Esteemed Veteran Member
modernbeat's Avatar
You could always make your own. Works best for Koni shocks with a 12mm shaft, but with a helicoil in the nut it can work for any shock.
http://www.cardomain.com/ride/2343497
I used this when I had Koni Yellow shocks. Worked well. It moved the shock shaft up about 3/4 of an inch, moved the spring up about one inch, dropped a bit of weight and removed the rubber out of the suspension.
modernbeat is offline   Reply With Quote
Old 05-07-2007, 12:03 AM   #14 (permalink)
xn7
nice write up.. question though, do you think it was necessary to use the gc polyurethane upper spring isolator? and how flush did it sit vs the bottom surface of that nb mount? if it has room for the isolator to flex i don't think that would be good..
Old 05-07-2007, 12:09 AM   #15 (permalink)
Sean Jay!'s Avatar
FAT CAT OR ELSE
Sean Jay! is offline   Reply With Quote
Old 05-07-2007, 12:38 AM   #16 (permalink)
xn7
^lol
i was just looking at the fat cat setup, the 1 piece that is "special" is the 10x.125 or 12x1.25 nut with extended shaft,
i was going to go with FCM or one of the others but now im considering custom.. seems easy enough thanks to modernbeat ^, if i can find a 10x1.25. 12x1.25 is much more common..
Old 05-07-2007, 12:55 AM   #17 (permalink)
Try it! and take pics!
I made this up a while ago when I was thinking of trying :wink:
Old 05-07-2007, 01:07 AM   #18 (permalink)
xn7
any idea where to get the 10x1.25s??
i know my local stores don't carry anything like this, ive tried
Old 05-10-2007, 02:44 PM   #19 (permalink)
modernbeat's Avatar
AFAIK, there isn't an easy to find nut like that. You can use an ATV mag wheel lug nut or you can use a helicoil inside the 12x1.25. I've seen the helicoil method used and it worked well. The guy did epoxy the helicoil into the lugnut and then cleaned it up with a tap.
You don't have to use the isolator. I was afraid of the spring skewing but in subsequent versions I've left the isolator off. Everything worked just fine.
Old 05-15-2007, 01:16 AM   #20 (permalink)
modernbeat's Avatar
I got a tip that Banjo Nuts used in brake systems may be the ticket.
See this for an example:
http://www.tpr-racing.nl/index.php?p...emart&Itemid=1
Old 05-15-2007, 03:48 AM   #21 (permalink)
xn7
nice find. i plan on calling around some hardware suppliers to see if they have anything in spec.
Old 05-26-2007, 03:06 PM   #22 (permalink)
Mechazawa's Avatar
You can get a bag of 50 or 100 or something for like $7.00 from Mcmaster-carr.
On that it dives it is best with the good weather.
Mechazawa is offline   Reply With Quote
Old 05-26-2007, 04:13 PM   #23 (permalink)
modernbeat's Avatar
Have you got a part number so everyone else doesn't have to thumb through the 10,000 page catalog?
Old 05-26-2007, 06:27 PM   #24 (permalink)
Esteemed Member
slutz4's Avatar
If we can find a place to get the rest of the parts that would ben sick
Old 05-26-2007, 11:36 PM   #25 (permalink)
modernbeat's Avatar
I sourced the parts from the following places:
Koni Shocks = Goodwin Racing
GC kit and bumpstops = GroundControl online store
NB Shock Tops = Mazda Salvage Specialist or Mazda Motorsports
All the misc hardware was purchased at PepBoys including the hose, the bushings, the lug nuts and the thick washers
I bought the aluminum rod for the adjuster tool from a local hobby shop. Glue came from a local Ace hardware shop.
All the important parts from PepBoys show the part numbers in the photos.
Old 07-28-2007, 02:03 AM   #26 (permalink)
I just installed NB mounts on my NA (this thread gave me the idea). I got the whole suspension from an NB for $70 and then went to Pep Boys and got 8 washers and 2 bushings for about $7. I cut each bushing in half and sandwiched those halves onto the strut mount with the washers... works perfect. I also re-used the NB bump stops instead of the NA's.
I was going to buy the Chikara mounts, but then I saw this thread and realized I could save myself some money by building my own.
Now my car doesn't bottom out anymore and it's a little lower.
Jeff_nc is offline   Reply With Quote
Old 08-13-2007, 11:01 AM   #27 (permalink)
Sid
Sid's Avatar
fat cats and chikara are the same thing... just NB mounts in kit form.
Stop (brakes), Drop(suspension), then Roll (power) -hooked_on4
Sid is offline   Reply With Quote
Old 06-10-2008, 06:23 AM   #28 (permalink)
klutchmaster's Avatar
Nobody mentioned ISC racing top mounts.
http://www.iscracing.net/Miata_suspension.htm
klutchmaster is offline   Reply With Quote
Old 06-10-2008, 08:01 AM   #29 (permalink)
Ham
Cat Jesus
Ham's Avatar
Uh it's been mentioned plenty of times.
Search?
"Like" and visit our Project-5 Roadsters facebook Page! Your only San Diego Roadster Club!
http://www.facebook.com/Project5Roadsters
Ham is offline   Reply With Quote
Old 06-10-2008, 08:09 AM   #30 (permalink)
Esteemed Member
slutz4's Avatar
this thread is ancient. My originally post was over a year ago...
