Isc top hats instructions not included... - Page 2 - ClubRoadster.net
Old 12-25-2012, 07:58 AM   #31 (permalink)
Default Re: Isc top hats instructions not included...
why did you buy isc tophats for teins? does coil binding remind you of the feel your boyfriend gives?
Braineack is offline   Reply With Quote Quick reply to this message
Old 12-25-2012, 09:46 AM   #32 (permalink)
LOLFWD's Avatar
Someone suggested them since I was tired of riding on the bump stops. I already tested this before I put them all on it'll hit the bump stops before the coils bind or the control arms hit the frame...
LOLFWD is offline   Reply With Quote Quick reply to this message
Old 12-25-2012, 11:12 AM   #33 (permalink)
Drock30's Avatar
Ok I had the same problem you did with my Raceland Coilovers when I purchased 2" for the fronts and 2.5" for the rear.
You'll need "Energy Suspension Sway Bar End Link Set".
It's comes with 8 Bushings and 8 Washers.
Before you put your tophat on along with the bushing and washer that came with the tophat, follow this step.
Starting with the washer that goes down the shaft of the coil.
Washer - bushing - bushing - washer - tophat - bushing - washer - nut.
Ill make a drawing if its confusing.
Vanilla Build [Long Gone]
@Instagram: derrick_michel
:: Derrick
Drock30 is offline   Reply With Quote Quick reply to this message
Old 01-01-2013, 12:31 AM   #34 (permalink)
808drifter's Avatar
...this fkn thread and the OP.
808drifter is offline   Reply With Quote Quick reply to this message
