Test and tune day here at the house, i got in a ARC Radiator cap from Japan today, thanks to Metro Motorsports for sourcing all these JDM goodies. :mrgreen:
Today's test is the following;
ARC 1.5 Bar High Pressure Radiator Cap.......
VS.
Sapporo High Pressure Beer Cap. \(^_^)/
After many hours of testing, i have found that the ARC 1.5 Bar Rad Cap does work well on the car, adding a much needed cooling effect along with some JDM bling bling. Where as the Sapporo Beer Caps did not fit on the Radiator at all?? #-o However i found they worked much better off the bottle, trust me, i removed several of them with the same JDM dizzy effect. 8)
As you can see, i had a little help cleaning off the last few drops of Sapporo. :wink:
:twisted: PhatMiata & Spanky the Bulldog says.......... Sapporo Caps no fit Miata Radiator, and leave you dizzy, ARC parts fit Miata much better.
ARC for the Win!! \(^_^)/
disclaimer: no animals or JDM parts were harmed in this comparison test.
PhatMiata :shock:
Resistance IS Futile
VS.
PhatMiata :shock:
