| Product Reviews Post your thoughts and opinions on a product here. Let us know about it, good or bad. |
LinkBack | Thread Tools | Rate Thread | Display Modes |
#1 (permalink) |
"Hey nice miata! Are you on m.net?"...
![]() ![]() The style bar had to go. I couldn't take it anymore. Not only did I look like I was borrowing my 65-year old grandpa's car, but that ish was just downright unsafe on the track and in the canyons without a rollbar. I'd been looking over the usual Hard Dogs and Boss Frogs since I got my car in January. It wasn't that they weren't good bars, it was just that. They were just, well, bars, to me. I needed something different. Something better. Lo and behold, I found rdrcr's thread detailing his new 6-point fabbed and installed by SoCal native Blackbird Fabworx. I always thought a 6-point would be nice. Heck, who wouldn't want door bars solidifying the chassis? But I sure as hell wasn't going to pay $275+$50 shipping for some bolt in tubes of metal. Now what Moti fabbed up for rdrcr- that's what I wanted. The way it flowed evenly with the four point with precise welds just made those door bars belong. Looking at 4-points, they just seemed incomplete now. I exchanged a few (heh, maybe a bit more than that. I'm sure my daily PM's started to rack up) messages with Moti and together we hashed out exactly what I wanted. Eventually we came to the decision to use 1.75"x0.095" DOM tubing with 1/8" mounting and backing plates. It was finally time to take my car to the next level. I made the trek to Northridge with my mom caravaning behind me (have to get back home some how) and along the way thought to myself how that would be the last time I would experience body flex. When I dropped the car off at Moti's, he came up with a few more suggestions to make the bar even better. Instead of black paint, he recommended antique bronze to flow with my black and tan and 3M tape to protect my door bars. I completely agreed and bid goodbye to my tiny go kart. Not only were the choices perfect, but after Moti detoxed my interior and removed the monstrosity called the 'style bar', he called to let me know that my plates were in fact being laser cut to look ever sharper. This is just one of the examples of Blackbird Fabworx going above and beyond what is deemed necessary to make a bar that is truly a work of art. Unfortunately, Moti called me the next day to inform me that my glass window was infact 36" instead of the standard 32-34" on the OEM tops. Not to be dismayed, Moti tried over four different designs with the rear legs to make sure they fit perfectly with the glass window. After a few days of building the bar and keeping me constantly updated with pictures, the car was ready. I was as giddy as a schoolgirl as I again made the trek up to Northridge. Everything I had hoped the bar to be had turned out better. Moti made sure that every single little detail was perfect and up to his standards. I still can't believe how solid the car feels now as I tear through Angeles Crest Highway. Unbelievably, this rigidity only weighed 46 lbs with the door bars! This isn't just a bar. It is an extension of the car, taking it to new horizons. ![]() ![]() ![]() ![]() ![]()
#6 (permalink) |
Junior Sponsor
Thank you Sean for the nice review!
The mounting and backing plates are indeed all laser cut now. Man, I love the way the bronze works with your interior ![]() The rollbar works with softtop and hardtop. The side latches may need some modification to fit but the rollbar is HT compatible. Moti |
#9 (permalink) |
Congrats, your 6-Point Rollbar is freaking awesome! I love the paint color!
Excellent work Moti! Mike |
2009 Audi A3 2.0T DSG S-Line: HPA Stage 1, HPA DSG Stage 2, S2T Paddle Shifters, ST Coilovers |
#10 (permalink) |
Looks awesome to the point that I might do it in the near future... especially if the penalty is only 46lbs.
Moti do you think it's possible to have a greater angle in the side bar so that it disappears in the door cavity (when you look at it from the top w/o armrests)? |
Chris Autokonexion Kevlar bumper and fenders 2096lbs FM 2.0L Stroker+GT2560+V-mount+1000cc ID+E85+22psi->335 whp Ford Motorsport Tremec T5z 5 speed transmission 275 Hoosier Koni 3011 coilovers 900 Lbs/inch springs - Daily Driver
#11 (permalink) | |
Junior Sponsor
Not sure what the question is. You want the door bar to go further out? As you see it in Sean's car, the door bars are barely 1/8" away from the door cards. When you remove the door card you see that the door panel itself (the sheet metal) is pretty much right behind it. I can surely notch a bit into the sheet metal and the door cards to get it a bit deeper into the door, but I think that if you sat in Sean's car you'll see that the bars are out of the way. Try it in the 5 yr. Kinod! Moti |
#12 (permalink) | |
Thank you for your answer, I was thinking of a sidebar that will be getting inside the door (not sure how deep it can get -if any- w/o interfering with the crank windows). Something similar with the picture below (but with a single side bar). Basically I'm want to have the bar as far away as possible from me. I'll try to make it in the 5 year Kinod anniversary so I can meet you and take a better look at Sean's car. |
#14 (permalink) |
Junior Sponsor
Gotcha, yeah that's pretty much what I figured.
The pic you attached is definitely a car with a full cage and most likely no windows, but if you're inclined to cut through the sheet metal and door cards than the door bar can probably move a bit further out. I'll be happy to work out a custom door bar set up for you. Let's try and catch up at Kinod or something. Moti |
#19 (permalink) |
I met with Moti during the last KINOD meeting. I was really impressed with how knowledgeable he is and his attention to detail. Lucky enough everyone was there so I could see three of the local miatas he worked on during the last couple of months.
Top notch stuff not comparable with most off the shelve solutions. He also had his laptop and I could see some really amazing projects he worked on in the past. We talked about the bar that I envisioned and I think sometime after summer I might drop my car there for my dream bar (something very light which will be as tall as possible following the HT height - don't care about soft top- with sidebars and a Woolery bar in the middle header). |
#21 (permalink) | |
Mike |
#22 (permalink) |
"The only power any government has is the power to crack down on criminals. Well, when there aren't enough criminals, one makes them. One declares so many things to be a crime that it becomes impossible for men to live without breaking laws."
#23 (permalink) |
Junior Sponsor
Hey Mike,
The 6 point rollbar includes the installation in the price and runs for most customers between $1100-$1500. Normally NA's will be a on the lower side of the range. When you do the math of a normal 4 point bar from a known brand, which will be close to $600 shipped, add door bars for roughly $300 more and about $300-400 for installation and you're right there at the same price range, only with an inferior product My rollbars (6 or 4 point) are allowing the customer to choose options that don't even exist from any other vendors and truly customized it to their needs. If you need an example just have a look at what Max power posted, he's looking into a lightweight 7 point rollbar, good luck getting that from other miata vendors Moti |
#24 (permalink) |
Moti is an awesome guys and very knowledgeable when it comes down to roll bars. Trust me. Youll be very satisfied with the outcome and overall quality of the materials he uses. Just gotta talk to him and go into deatails with what you really want.
-Roy |
#25 (permalink) |
nice color bro.
le sigh... |
black nc2 gold wheels blackbird NC 6-pointproject go-kart [go-kart on flickr] project killdozer [killdozer on flickr] |
#28 (permalink) |
Junior Sponsor
All 4 point models can be shipped and installed by the user (assuming you have the tools, nothing fancy).
The 6 point models require welding as a part of the installation process as it ships with the door bars detached (otherwise the package will be gigantic) and therefore will require pro installation. Moti |
#29 (permalink) |
This is an awesome creation! Great if you are planning for summer vacation trip! A tan skin is awesome! You may need a bottle of soda drink to ease the hotness. On the other hand, a ban on selling large sugary drinks in New York City was set to go into effect on Tues, March 12. However, the ban was overturned Monday by a court. Mayor Michael Bloomberg and the city of New York have vowed to appeal the decision.
#30 (permalink) |
What the fuck does that have to do with roll bars?
| Display Modes | Rate This Thread |
