#1 (permalink) |
I am currently lowered 12" F&R (GC+AGX) and have the stock 17x7 +40 with 215/40 tires. I want to keep the rims, but love that low offset look.
I ordered H&r spacers (15mm front and 25mm rear) This will bring the front offset to +25 and the rear to +15. I am already planning on rolling the fenders. Is there going to be any fitment issues here? I may have to go to a 205/40 or even a 195/40 (side note: i did not even know this size existed!) Also, I have a set of 15x7 +30 Team Dynamics Pro Race 1.2. With the spacers I am looking at +15F and +5R offsets.... I am thinking i need to run 195/50's to clear..... Thanks! Input is greatly appreciated |
#2 (permalink) |
How much negative camber are you running in the rear?
My set up is 11.5", 7.5" width, +41mm offset, -2.4 camber, 225/35/17 and they barely clear. A 25mm spacer in the back seems like it will have clearance issues unless you go with more negative camber or a more narrow tire. |
04 Mazdaspeed MX5 |
#3 (permalink) |
So far i am using the stock alignment....
If I need to I will raise it up to 12.5", but will definitely be getting some negative camber in addition to the fender rolls... I am looking forward to test fitting in a few weeks... |
04 Mazdaspeed |
#4 (permalink) |
Whiskey makes me Frisky
how would spacers make your rims "the low offset look"? I mean the face is still going to be sitting on the outside lip and a low offset is going to give you more lip. spacers just make skinny rims skinny but pushed further out.
Forever in my heart. http://25.media.tumblr.com/tumblr_m2...9ako1_1280.jpg http://25.media.tumblr.com/tumblr_m7...9ako1_1280.jpg |
#6 (permalink) |
3 posts since 2007 and all of them in this thread lol
04 Mazdaspeed MX5 |
#8 (permalink) |
Not to keen on spacers, but if you plan on rolling, I don't see why 205's won't clear.
You aren't that low from specs..... |
Racing is living, Everything else is just waiting.... Steve McQueen (Le Mans) (Final edit***too much done now to list.) The Anti-Style Bar Empire - Saving lives since 2010. |
#9 (permalink) | |
#10 (permalink) |
I'm on 16x8 +15 with 215/45/16 on my 05 MSM and I needed to roll and pull my fenders to avoid rubbing even on stock suspension. I haven't measured my ride height lately though. But I think its around 11.75 in the rear and 11.5 in the front and I still rub in the front on big bumps. But then again, I now have no idea what I am rubbing on since there are no marks on the tires. I think I might be rubbing the frame, I still need to look into that.
'05 MazdaSpeed Miata '08 Subaru Impreza WRX STI Contact me if you need to rent a fender roller!!! |
