Will sportmaxs fit on a lowered NB ? - ClubRoadster.net
Old 08-03-2006, 11:52 AM   #1 (permalink)
Mx-5 dude's Avatar
Default Will sportmaxs fit on a lowered NB ?
Im not to savy in terms of what works and will not work for the NB.
So as the topic says im wondering if the sportmaxs, 15x8 or 15x7 will fit on my miata. They have a 0 offset and my NB is lowered and because of the icehawk alignment it has a lot of negative camber.
thoughts ?
2001 Porsche Boxster
2003 Miata.
Mx-5 dude is offline   Reply With Quote
Old 08-03-2006, 12:16 PM   #2 (permalink)
boostmx5's Avatar
Default Re: Will sportmaxs fit on a lowered NB ?
If you look at my thread u can see them on a Na
They will work on a NB
A couple things you need neg camber to help with fitment and rubbing, you need to atleast roll your fenders and preferablly pull them, you need to get rid of your fender liners and you need to be low...but it can be done
93 Turbo na Roadster
93 RX-7 FD Gt35r
http://i26.photobucket.com/albums/c1..._1520small.jpg
boostmx5 is offline   Reply With Quote
Old 08-03-2006, 02:58 PM   #3 (permalink)
Mx-5 dude's Avatar
Ok thanks for the info, I read the thread about your car and It inspired me to look at some black ones for my NB.
Im assuming fender rolling wont be to hard.
However im just wondering if this would be a smart choice for a daily driver
2003 Miata.
Old 08-03-2006, 04:34 PM   #4 (permalink)
Esteemed Member
Dicker's Avatar
yes, alot of guys drive them
however i have my car so low right now my 15x7s are rubbing the insides of my fenders, woo me!
Car Make Kinod
Dicker is offline   Reply With Quote
Old 08-03-2006, 04:42 PM   #5 (permalink)
Esteemed Member
sonique128's Avatar
my only complaint with sportmaxes is this:
sonique128 is offline   Reply With Quote
Old 08-03-2006, 05:45 PM   #6 (permalink)
Esteemed Member
Dicker's Avatar
any wheel with a big lip that isnt forged is gonna break like that.
now a work or SSR wheel might fair better, but thats what you get when you pay over 3x the price.
Car Make Kinod
Old 08-03-2006, 07:01 PM   #7 (permalink)
Max_Power's Avatar
The sportmax are very lightweight (14lbs only for a 15x8 wheel is really good) and if they are acombined with a 195-50 tire the combo is light with enough sidewall for everyday driving...
Furthermore are cheap and easy to replace in case you break them
BTW Many people had problems (with bend/broken rims) with the SSR (there was even a webpage dedicated to these problems!!!) and of course they cost 3x of the sportmax
Chris
Old 08-03-2006, 08:14 PM   #8 (permalink)
RusMan's Avatar
The fit very good, you have to roll the fenders
RusMan is offline   Reply With Quote
Old 08-03-2006, 08:22 PM   #9 (permalink)
Max_Power's Avatar
RusMan you miata is the most beautiful NB I've ever seen =D>
You are making me thing again if I doing right by selling my Sportmax for the Rota PDC #-o
PS The picture became right away my wallpaper for the month
Chris
Old 08-04-2006, 02:19 AM   #10 (permalink)
Mx-5 dude's Avatar
Thanks for the pics and Info everyone.
Im really going to look into getting a set of sportmaxes.
2003 Miata.
Old 08-04-2006, 01:30 PM   #11 (permalink)
RusMan's Avatar
That broken wheel is also mine Yes it fell apart but I'm still saying that they're great rims, how hard I hit that curb no rim would've survived, yes the more expensive mabye wouldn't split like that but it will rip out your suspension, and I'd rather replace a wheel, which is very cheap, than order a new expensive wheel and a whole new suspension. I very highly recommend this wheel to anyone.
Old 08-04-2006, 01:33 PM   #12 (permalink)
RusMan's Avatar
I am also very low right now, 11" from center of the wheel to the top of the fender. My tires tuck about 1/2inch under the fender, I rub but not very much, only when cornering hard and running over a bump in the road or something.
Ohh and mx5 dude, make sure you buy 15x8 and not 15x7 because 15x7rims have +38offset which is really high and looks horrible :!:
Old 08-04-2006, 02:28 PM   #13 (permalink)
Esteemed Member
Dicker's Avatar
yeah, im at 11.5 F and 12 rear with a 207 on 15x7+38
my fender liners like to scrape.
Car Make Kinod
Old 08-05-2006, 02:31 AM   #14 (permalink)
Mx-5 dude's Avatar
Once again thanks for the info guys !
I cant tell you how much this is helping me right now.
So looks like I might be placing an order for a set of 15x8
what is the width of the tire ? 205 ?
2003 Miata.
Old 08-05-2006, 03:06 AM   #15 (permalink)
RusMan's Avatar
I'm running 195/50/15 tire right now, I haven't tried but I think 205 is possible if you pull the fender enough and have more negative camber.
Old 08-05-2006, 10:50 AM   #16 (permalink)
boostmx5's Avatar
def go with a 195 man, you wont loose any contact patch from a 195 vs 205 on 8 inch wide wheel. Since thats a very mild stretch and it will just pull the sidewalls down a bit. Before this I was running 205's on a 7 inch wide and had way less traction.
I am 10.5 inches....very low
Yes I dont have a MB but I am also running pulled fenders
You will not regret believe me. Yes it will take more work but you wont be sacrificing for some wimpy offset and sizes and in the end you will be satisfied and have no regrets =D>
93 RX-7 FD Gt35r
Old 08-05-2006, 01:45 PM   #17 (permalink)
Esteemed Member
Dicker's Avatar
youyr 195/50 on an 8 is gripping more than a 205/50 on a 7? same tire?
because i run 205s on a 7 and am afraid of losing grip going to a 195.
Car Make Kinod
Old 08-05-2006, 02:13 PM   #18 (permalink)
boostmx5's Avatar
Yep it is,
You will loose grip going to a 195 from a 205 on a 7
But I gained grip from a 205 on a 7inch to 195 on a 8 inch. Im stretching the rubber over a wider surface area thus more contact patch
93 RX-7 FD Gt35r
Old 08-06-2006, 02:43 AM   #19 (permalink)
Mx-5 dude's Avatar
Well damnit !!!
I just bought a set of new Azenis two weeks ago. 205/50/15.
theres no way im going to get these sport maxs now because I wont have the damn $$$ to buy new tires !!!
2003 Miata.
Old 08-06-2006, 07:13 PM   #20 (permalink)
danscreations's Avatar
I bought a set of these wheels about 2 months ago and was very impressed by the look and weight of them. I rolled (not sure if thats what your refering too by pulling them) and couldn't get them to fit with maxing out the camber. Now.. I did have 205/50/15 (i belive 205's for sure) Nitto Neogens which could have been the problem. I was going to order some 195 Toyo's but didn't see how it was going to make that MUCH of a differance. I'm running Tokico Illuminia's with H&R springs. What type of suspension are you all running. Thats the only thing i can figure is smaller tires and and very stiff suspension to make em' work.
I sold the wheels and tires and bought some huge ass wheels that look cool and are differant but I want these back and to work as I like the look and diffantly like the weight savings.
What I have now:
Sportmax 006's
17x8 et+35 Front
17x9 et+35 Rear
danscreations is offline   Reply With Quote
Old 08-06-2006, 11:40 PM   #21 (permalink)
RusMan's Avatar
I'm running Stance coilovers 9k/7k springs, no rubbing. I used to run d2 with 7k/6k springs and I was rubbing a bit on the corners.
Old 08-07-2006, 12:50 AM   #22 (permalink)
Esteemed Member
Dicker's Avatar
howd you get 9/7?
mine are 8/6 or so i think
Car Make Kinod
Old 08-07-2006, 02:29 AM   #23 (permalink)
Phantom's Avatar
Do you guys think the sportmaxs will look bad with out lowering and with a large gap? Also if you don't lower it, is it neccessary to roll the fenders?
http://www.cardomain.com/ride/752771/
[SIGPIC]http://i122.photobucket.com/albums/o273/Phantomiata/IMG_0577enhancedcopy-1.jpg[/SIGPIC]
Phantom is offline   Reply With Quote
Old 08-07-2006, 10:28 AM   #24 (permalink)
Mx-5 dude's Avatar
Im running Eibach pro kit springs and KYB AGX for dampers.
2003 Miata.
Old 08-07-2006, 11:59 AM   #25 (permalink)
asianrice02's Avatar
its going to look funny imo. you need to get it lowered to have it maxed cambered so it tucks in neatly when cornering. also if you going to have it at stock height: max camber and roll fenders anyways.
I have been diagnosed by psychiatrist w/ a messiah complex.
asianrice02 is online now   Reply With Quote
Old 08-07-2006, 02:17 PM   #26 (permalink)
boostmx5's Avatar
I think it will look real bad 4x4 mud bog look
93 RX-7 FD Gt35r
Old 08-07-2006, 02:42 PM   #27 (permalink)
Esteemed Member
Dicker's Avatar
i think it would look redonkulous.
i think any aftermarket wheel looks goofy on a tall car.
Car Make Kinod
Old 08-07-2006, 03:53 PM   #28 (permalink)
boostmx5's Avatar
especially when the wheels are 0 offset AND will stick out 2 inches past the fender
If you want wheels like these to fit you have to make them work. If you just bolt them on they will look bad gauranteed
93 RX-7 FD Gt35r
Old 08-07-2006, 04:13 PM   #29 (permalink)
Mx-5 dude's Avatar
So If I get these wheels they will stick out 2" past the fenders ? Im assuming the camber and the lower stance will help with this ?
2003 Miata.
Old 08-07-2006, 04:33 PM   #30 (permalink)
boostmx5's Avatar
well I didnt measure but they will stick out alot matbe 1 or 1.5? Yes the lowered stance, camber and rolled fenders will flush them to your fender not make them stick past out
Here is an example
This is -3.5 camber, slight pull and lowered via coilovers
now same wheels on same car but with stock fenders and h&r springs/tockico combo
As you can see its not low enough and not enough camber (sorry for the crappy pix)
so yeah you be the judge 8)
93 RX-7 FD Gt35r
