So I just bought some new Hankook Ventus RS3s today and I think I'm going to paint the letters white with a tire specific white paint and was just wanting to see who all on here has done it, with what material/where you sourced it, results and overall impressions. I know this has been covered in one form or another but I was hoping for not just input but pictures of your own handiwork to help others in the future with a similar decision. I know this is CR but lets try to keep this on track please. :icon_cheers:
Re: to swag or not to swag? (m.net translation paint tire lettering or not?)
Sharka is the reason I even considered this and Adam has been very helpful when I have bugged him multiple times about it. I already have what I want to use(classic spirit white wall paint) but figured stating what others have experience with, where they sourced it and the results would help others. I will have to find the stuff I got on eBay and post a link. I started doing one tire when I was putting on the suspension but realized how time consuming it was going to he and even the small amount applied, even after trying to remove with rubbing alcohol, has stayed on quit well, so I'm optimistic about the outcome once I dive in.
Yesterday I saw a first Gen MR2 lowered with racing seats, and Flaken Altenzas (whatever the Falken street slicks are). He pulled the painted look off well, but the car had a mean, old school Japanese racer vibe. I'm not sure miatas have that.
Just to reiterate the point of this thread....I have made up my mind but wanted others to share their experience/thoughts/pictures with others to help them make an informed decision about the options and what outcomes to expect depending on material used, etc.
Not that I don't welcome people's opinions but no need to simply post to say I should do it, not that I don't appreciate positive reinforcement but for the sake of thread integrity(if such a thing is possible when talking about such a thing) and not cluttering it up.
Adam if you have anymore information, insight or pictures to share beyond the links already posted then by all my means stop by and share and of course that goes for anyone else that's done it! :icon_cheers:
just be careful with the curb. one of the letters on mine scraped off when the tire made contact with the side walk curb. It didn't help that the GV tails have the reverse light only on one side.
Other than that, the letter was still good and reapplied it back on!
I tested platidip, rattle-can paint, and a few different paint pens on the all-seasons I had my daisies wrapped in. All of them started to wear and fade within a week. Nearly unrecognizable by a months time. I'm not sure if it was because of the lack of prep before hand or maintenance after application. Either way, it was enough to scare me from painting my current set of Direzzas.
^^^^^ I have heard similar experiences and why I chose the product I did but I agree prep probably is a fair amount of the longevity factor no matter what you use. When I was going to do my current set of RS3's I first washed the tire with soapy water and then rubbing alcohol till the rag was pretty much dirt/contaminant free. The latter being another reason I decided to wait until I had brand new tires to give it a shot, to be honest the fading wouldn't bother me as long as it was fairly uniform but that may be wishful thinking.
I'm curious to why manufacturers seemingly stopped making tires where one side is black and the other has white lettering? :dunno: I'm only 30 yrs old remember that being common place up until maybe 10 yrs ago... :dunno:
Well I got started tonight and the process is tedious and time consuming. It took about 2 hours to do one tire, that's cleaning it with soapy water/denatured alcohol & googone, then laying wide(4"?) blue painters tape and then using exacto knife to outline "Hankook Ventus RS-3" and of course painting took like two minutes. So one done with two remaining coats applied approximately 24 hours apart and will do the other three tires tomorrow. Will get pictures up ASAP. :icon_cheers:
Well here goes how the process went. First the materials, Classic Spirit white wall paint, painters tape, exacto knifed, goo gone and denatured alcohol.
Washed the tire with soapy water:
Then dried, used denatured alcohol and goo gone:
Tape over lettering and about two hours of exacto knife precision cutting:
Coat of Classic Spirit white wall paint:
After a second coat coat, several hours a part:
I did one last coat and let it dry another 3-4 hours then I started removing the tape....this is where it all went wrong. Not sure what was wrong with my methodology but when I started removing tape the paint came with it. :suicide: This isn't an issue of the product, it was definitely the user. Thankfully I only did one tire because if I had done all them I would have flipped. Unfortunately I am not as persistent and patient as others and decided to cut my loses because after spending almost 8 hours on this venture, I really didnt care to have further failure.
I think part of the issue is I put each coat on to thick and maybe I should have waited longer between coats and maybe instead of using the supplied sponge applicator,I should have used small brushes to try and avoid to much overlap on the tape? :dunno: I hate conceding to defeat but it is what is and I REALLY wish this project had succeeded because I know I would have been thrilled with the results.
I hope others learn from my mistake and succeed and post their results because the time would have been worth it imo if I had succeeded. I would recommend the tire paint as it was not the easiest to remove what didn't get pulled of with the tape and was very elastic so I think it would hold up well. Sorry to disappoint any anticipating the results.
I used the same time paint as Adam did. What I learned from it was never and I mean never do it on new tires. I put on 5 layers and it still bled through and turned a really nasty brown. Also make sure to sand or rub the letters with steel wool a bit so that they stick nice to the tire. Mine are pealing pretty bad now. I'll be redoing mine soon since the tires are broken in and the mold release compound should be completely gone now.
^^^^This is why did the several prep steps that I did and it stuck to the tire, well in places but like I said I think because of overlapping the tape it made an equally good bond with the tape and came up. :dunno: I think the main issue was the coat thickness(too thick) and applicator type(sponge stick thingy) and too much over lapping on the tape.
It may be that you need to remove the tape while the paint is wet. I know with Plastidip if you want a clean edge you remove tape while wet otherwise it will peel and tear along the edge of the tape.
i'm sorry to say but you're gonna have to sit there and use a tire paint pen. It's tedious but a tad bit easier than going through that process! This is the exact paint pen that i get every time from Ebay and here's what it looks like done on my cars.
tried making a stencil today and failed miserably, guess ill be buying a pen and just drawing it on.
