17x7.5 +45 offset - ClubRoadster.net
Old 03-24-2009, 12:56 AM   #1 (permalink)
Clappin' dem cheeks!
badassxr50r's Avatar
Default 17x7.5 +45 offset
Does anyone have a pic of some wheels on a roadster in this size?!?!
"Change is the law of life. And those who look only to the past or present are certain to miss the future. " - JFK
1999 mazda miata emerald green going turbo
1996 dodge neon 2.4 swapped going all motor
badassxr50r is offline   Reply With Quote
Old 03-24-2009, 10:15 AM   #2 (permalink)
ray_sir_6's Avatar
My car has 17X7.5 40offset wheels. 5mm is gonna be VERY MINOR difference.
91 Miata 1.6l Greddy Turbo AEM EMS
17psi 280whp@6200rpm/265tq@4400rpm, 2450lbs
ray_sir_6 is online now   Reply With Quote
Old 03-25-2009, 01:12 AM   #3 (permalink)
Nice, Thanks man! I am looking at getting rota d2's. i just want to make sure they don't stick out as much as mine do now. I want a wheel that will be flush so that when I lower it, I only have to camber it a bit to not rub and now rolling of the fenders or quarters.
Old 03-25-2009, 06:01 AM   #4 (permalink)
Asianguywithacamera's Avatar
I'm running two different 17x7.5" wheels - if you want it flush, a +35 or +40mm with 215 or 225mm tires would be best. +45mm will still be sunk in slightly.
04 Mazdaspeed MX5
Asianguywithacamera is offline   Reply With Quote
Old 03-25-2009, 06:59 AM   #5 (permalink)
ab7
ab7's Avatar
Default Re: 17x7.5 +45 offset
I saw Volks with 17 X 7.5 +33. Sit flush with the fender, closer to +30 is better for good stance
NB8B - Hydra EMS | MaximWorks + SMB Midpipe + Metal Cat | BMC CDA + CF Pipe | Volks CE28N + Advan AD07 | KYB AGX + Kings | SD short shifter + Voodoo | Bling...
ab7 is offline   Reply With Quote
Old 03-25-2009, 03:03 PM   #6 (permalink)
Lit like a BranchDavidian
Doppelganger's Avatar
this is 7.5 with +35 offset D2 and 215 40 17 tires
and to boil your noodle on how tire size and rim stly can make everything look different.... this is also a 7.5" wide 17" with +45 and 235 40-17 race slicks (remember, slicks are always 'oversized' compared to street tires)
2002 Ti SE Turbo
Doppelganger is offline   Reply With Quote
Old 03-26-2009, 04:42 AM   #7 (permalink)
駐車場5
Georgee's Avatar
17x7.5 38 offset, 215/40 tyres... came with the car
Georgee is offline   Reply With Quote
Old 03-26-2009, 06:43 PM   #8 (permalink)
see these are the exact wheels I want. I just want a wheel that will look good when I lower it down and camber it a little bit. I want a drift car look.
As for everyone else thanks for the post and ideas!! 8)
