what do u thank of these rims - ClubRoadster.net
Old 08-08-2009, 02:03 PM   #1 (permalink)
Supporting Member #5522
j-radvw's Avatar
Default what do u thank of these rims
i wont these rims but there 15x7 0 offset. and i have 15x8 0 offset right now
. i just bought Autokonexion NA fenders to make my curent rims fit.
should i run spacers and how fat of a tire can i run?
[/QUOTE]
j-radvw is offline   Reply With Quote
Old 08-08-2009, 02:18 PM   #2 (permalink)
Sequence Number 1280
terry pham's Avatar
Default Re: what do u thank of these rims
you can run a fatter tire on the 15x7 0 offset, like 225 or 215, but if you use spacers, you can't run a decent tire, you would have to run 195 to make sure it doesnt hit the fender and destroy it.
i think mike(grinder) designed the fenders so you can run any 205 tire with the sportmax/XXR wheels
terry pham is offline   Reply With Quote
Old 08-08-2009, 04:40 PM   #3 (permalink)
Esteemed Member
slutz4's Avatar
Id just run some more meaty tires on the sportmax or keep your current setup. 8 inch wheels are pretty much always better than 7s imo
slutz4 is offline   Reply With Quote
Old 08-08-2009, 04:44 PM   #4 (permalink)
mr_mazda329's Avatar
Yea...max on a 7'' is about 225's. Keep the 15x8'' or upgrade to 6ULs
97MontegoBlue FM sways,FM butterfly Brace,Ohlins DFVs ,Boss frog roll,Borla Catback,JR header, JRSC M45 14x7 +19 Enkei RPF1's 195/60R14 ZE-912's
09 MS3 CWP NGR Type-S BPV, Cobb SRI, CorkSport CBE, Dashhawk, TWM Shifter Bushings, HTP Turbo Inlet, Denso ITV22, TRZ Poly MM, CXracing FMIC, Cobb AP Stg1 SF/FMIC
mr_mazda329 is offline   Reply With Quote
Old 08-09-2009, 03:11 AM   #5 (permalink)
16bit's Avatar
what he said ^^^^
16bit is offline   Reply With Quote
