Painting rims? - ClubRoadster.net
Old 10-11-2006, 09:33 AM   #1 (permalink)
JDMAflac's Avatar
Default Painting rims?
I bought a set of sportmax's in red off a friend but i despise the color and want to paint them in white for something different. How should I go about doing this?
If I use aircraft stripper on the rim will that effect the lip of the rim ?
Also, what grit for sanding?
90' Mazda Miata- Boosted!
JDMAflac is offline   Reply With Quote
Old 10-11-2006, 10:08 AM   #2 (permalink)
Esteemed Member
boogie van's Avatar
they would look hot in white, especially on a red car.
ive never seen them in person, are they a true 2 piece wheel or just for looks?
that would make it alot easier to paint the center obviously.
honestly I dont know if I would go as far as to strip off all the old paint, but thats just me, Ive been known to cut corners.
93 miata (sold)
waiting for my next miata.....
boogie van is offline   Reply With Quote
Old 10-11-2006, 11:13 AM   #3 (permalink)
turbored's Avatar
sportmaxes are 1 pc fake rivets.
turbored is offline   Reply With Quote
Old 10-11-2006, 02:39 PM   #4 (permalink)
JDMAflac's Avatar
^unfortunately
So should i take it down to the bare aluminum or just scuff them with maybe a 1500 grit? or self itching primer?
Old 10-11-2006, 02:43 PM   #5 (permalink)
airbrush1's Avatar
I'd go with 400 grit sandpaper.... then 600 grit wet. and a wet gray scotchbrite pad to get in all the cracks and crevices.... then paint away!
Trust me..... it works
my cardomain... http://www.cardomain.com/ride/832854
airbrush1 is offline   Reply With Quote
Old 10-11-2006, 02:49 PM   #6 (permalink)
JDMAflac's Avatar
should i primer after? also, after eat application of paint i was going to wet sand, recommended grit? same thing with clear?
Thanks!!
P.S. : Masking off the center from the lip is going to be difficult on this rim
Old 10-11-2006, 11:34 PM   #7 (permalink)
LUV2TURN's Avatar
Default Re: Painting rims?
My offer for powdercoating them for you still stands, Nick...
I'm going to start "shitted."
My MX6 is shitted.
1997 C-package. Shitted.
LUV2TURN is offline   Reply With Quote
Old 10-12-2006, 12:04 AM   #8 (permalink)
JDMAflac's Avatar
I was told powdercoating weakens the integrity of the rim, plus im using these rims for future events (autox, roadcourse)
Old 10-12-2006, 09:35 PM   #9 (permalink)
LUV2TURN's Avatar
You know, I was thinking about that, because I know you mentioned it before. The oven(s) that I powdercoat in are usually between 500 and 600 degrees fahrenheit. Hot, but not stupid hot. I don't know how much you'd really have to worry about it messing with the integrity of the wheel.
Just an offer
My MX6 is shitted.
