#1 (permalink) |
hi
I am doing a MazdaSpeed 3 brake transplant onto a miata 92 NA. Still in process...... need to make a bracket for it that is it...... what do you guys think? ............ pictures show - xxr 002 16x8 0 offset - mazdaspeed 3 front brake rotor 12.6" re drilling rotor from 5x114.3 to 4x100 to fit my miata - mazdaspeed 3 caliper ![]()
#2 (permalink) |
Official Armchair Racer
Youre on xxr's so clearly you have no use for bigger brakes. If you were tracking the car, the 1.6 brakes are more than capable for stock power just add some real pads.
![]() "I think I'll go buy one of those large foam hands you see at sporting events and zip tie it to my left mirror in a permanent point-by position." -Rich Cohn Lee Last edited by stormin'norman; 09-12-2010 at 05:38 PM. |
#6 (permalink) |
![]() "I think I'll go buy one of those large foam hands you see at sporting events and zip tie it to my left mirror in a permanent point-by position." -Rich Cohn Lee |
#7 (permalink) |
do it! you should be able to lock them up doing 90 lol
"Johnny C" Nine lives Racing grip racer. watch my website for...ls1 miata build, upgrades. race video and pics. updated daily-> www.JohnnyCichowski.com |
#11 (permalink) |
oright .. if you think you have a clue for unsprung weight...
lets me ask you.... what is Unsprung Weight? What are some of the typical components of a car that fit in this category? What is the importance of this mass? How does it effect the performance of a car? dont tell me... - Unsprung weight is all of the weight between the road and the springs - Unsprung weight is anything that is NOT supported by the springs - unsprung weight is everything from the springs down - unsprung weight is not engine, fluids, you, your girlfriends, boyfriends (maybe) , toys, bags of candy. OOPS I have no clue....sooorry no clue |
#15 (permalink) |
why do you guys have to thread crap. He is doing something that is helping the braking performance efficiency.
So who cares if he has xxr wheels. This is better then racelands and slamming every fucking car. Shut up you people are stupid. How do you know that he doesnt have a ls1 in his car. Jesus. i begin to have less and less faith in this website. Go put fucking underglows on your cars and bitch when someone does something that is not text book slamming a miata. even if they weigh more they still will be a huge gain in performance. Even if it is not needed neither is a 400hp turbo 1.8. People do what they want why talk shit? ? |
#16 (permalink) |
Everybody loves uneven brake bias. Nose diving and losing rear traction is a performance upgrade I guess.
![]() Just because it's bigger doesn't mean it's better. |
#18 (permalink) | |
Sequence Number 1280
apparently you don't know what a proportioning valve is for?! wilwood - good and cheap, proven. |
-=tHa pHaM bRoS dOn'T F()cK aRouNd=- http://dstroyr.com/easyblog/blogger/...gs/t-pham.html http://www.flickr.com/photos/terrypham/ |
#22 (permalink) |
Lit like a BranchDavidian
Meh...I don't think it's really all that good. The rotor size maybe, but the caliper is 'meh' at best. You really need a caliper with pistons on both side of the rotor if you're going to "do it right". For drifting, you don't need much for brakes as you're not really loading them up with heat.
You could have bought my Brembo GT kit if you're really looking for a serious upgrade. I would recommend you get the 01+sport/03-05 standars/MSM rear brakes as well..along with the BMC from any of those cars if you are planning to have good brakes all around. |
The car is on fire, and there is no driver at the wheel. ![]() 2002 Ti SE Turbo
#23 (permalink) |
Which only works to the extent that the inherent bias can allow too-much-rear so that the valve can eliminate this issue.
For instance a stock NA/NB Miata comes front biased. If you add even more front brake torque for a given hydraulic pressure…how is reducing the rear braking action going to help? It won't. How will turning the bias to full rear help if the fronts still lock way before the rears. You want to wind up with a balanced braking system. If you do so, the car will stop as well as the tires allow. |
#24 (permalink) |
What Stanley said. You can only compensate so much and even then, it doesn't really help the problem. People that do the simple 1.8 swap have experienced bias issues, let alone custom fitted MS3 brakes. There's nothing to gain but asthetics.
#25 (permalink) | |
brontosaurus
#26 (permalink) |
You're conflating the brake booster with the master cylinder, and you're getting your years wrong:
http://forum.miata.net/vb/showthread.php?t=363284 The sport brakes actually have the highest pedal effort - 44lb-ft on the pedal only produces 638psi of line pressure, vs. 1038psi for '01-'02 non-Sport brakes or 796psi for '90-'00 brakes. However this calculation also ignores the brake caliper piston size. Assuming the MS3 calipers have larger/multiple pistons, you need the larger bore of the 'sport' master cylinder or your pedal effort will go down and pedal travel will go up. The non-ABS 'Sport' master cylinder is the one you want for a 'big brake' setup. |
