Offset has somehow completely confused me - ClubRoadster.net
Go Back   ClubRoadster.net > HANDLING > Brakes, Wheels & Tires
Brakes, Wheels & Tires Got a nice set of wheels for your Roadster and wanna brag? Have questions about tires or brakes?
Old 02-05-2010, 03:05 AM   #1 (permalink)
Sponsor
ThePass's Avatar
Default Offset has somehow completely confused me
So I'm using the wheel offset calculator linked to by 949 racing:
http://www.1010tires.com/WheelOffsetCalculator.asp
And I am trying find a good size spacer to use on my TD 15X7 +30's so that when I run them they don't look all sunken battle ship style since my front fenders are very very stretched and I'm doing a minor rear flare (autokonexion v2) for my 002's.
So, simple enough I plugged in the TD's and the 002's specs into the calculator and it says the outside edge of the wheel is 43mm further out with the 002's than the TD's are. Good so far.
So, I don't necessarily want the TD's out quite as far as the 002's so I figure a +25 spacer would be pretty good - should add up to make an effectively 15x7 +5mm wheel.
Now check out these spacers:
http://www.saferacer.com/miata-cage-...productid=1312
This is where it gets confusing. They list the 3/8" spacer as a +35. Using a mm to inch converter it says that 35 mm is equal to 1.38" NOT 3/8". It says the 1" spacer is a +150! What am I missing here?? does the +35 not mean 35mm? I'm confused. Someone set me straight?
Ryan Passey
ThePass is online now   Reply With Quote Quick reply to this message
Old 02-05-2010, 03:12 AM   #2 (permalink)
Motorboat Captain
aarrow's Avatar
Default Re: Offset has somehow completely confused me
get 1" or 25mm spacers. done.
example: http://cgi.ebay.com/ebaymotors/25MM-...Q5fAccessories
'85 Chevy Celebrity, '95 Civic EJ1, '99 Olds Alero, '04 MSM, '96 911, '01 740i Sport, '91 NA, '06 NC '13 PRHT CLUB
Authorized Dealer for ERRYTHANG.
Email:
IG: merlow993
aarrow is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 03:26 AM   #3 (permalink)
Sponsor
ThePass's Avatar
I guess I just want to know why on earth saferacer shows a 1" spacer as a +150 not a +25???
Ryan Passey
Old 02-05-2010, 04:44 AM   #4 (permalink)
Max_Power's Avatar
Well then maybe you should ask them...who knows may they were refering to the new offset that the spec m wheels will end up having with these installed.
All the other info is correct.
Chris
Max_Power is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 09:07 AM   #5 (permalink)
Project-G
Risingsun124's Avatar
It really doesn't matter what they are showing. If it's wrong it's wrong, or if it doesn't apply to you, then it doesn't apply to you, no? If you understand offset which it sounds like you do in the first part of the post, then why worry about someone listing a 1" spacer as a +150.
About the Project-G G-String
The best purchase I made for this car, hands down...including the rotrex.
what?
Risingsun124 is offline   Reply With Quote Quick reply to this message
Old 02-05-2010, 01:43 PM   #6 (permalink)
Sponsor
ThePass's Avatar
true true I guess it was just rubbing me the wrong way. Some small part in me wanted to believe that these were special spacers that bent the laws of physics and their 1/4" spacer to REALLY DID add +23mm and because they say you don't need longer wheel studs for 1/4" spacers and smaller, I could run it and not have to spend the extra $100 on studs...
yeaaa....
Ok well longer track studs ($100) and 1" lightweight spacers ($100) are in my near future. Lovely, just more to add to the $1500 I wanted to spend revamping the car which has now turned into $2500. Cars are so awesome!!!!
/rant
Ryan Passey
