Wheels to fit 225 tires without rolling the fenders? - ClubRoadster.net
Go Back   ClubRoadster.net > HANDLING > Brakes, Wheels & Tires
Brakes, Wheels & Tires Got a nice set of wheels for your Roadster and wanna brag? Have questions about tires or brakes?
Old 12-13-2006, 12:04 AM   #1 (permalink)
Default Wheels to fit 225 tires without rolling the fenders?
I'd like to get Yokohama A032R tires in 225/50R15 over some nice wheels. I'm also open to 16" if I could fit Falken Azenis 225/50R16 but I'd prefer 15" that would clear my FM/goodwin BBK for handling concerns.
Requirements:
-No rolling of fenders if at all possible and maintain full suspension travel
-Hoping to spend under $1k on wheels, cheaper is better.
Suggestions?
I currently have 16" BBS RKs. I don't know where the previous owner found them but I really like them. However I want another set of wheels for super sticky tires, these ES100s are out the door for T1Rs as the general use / road trip set. That is as soon as I'm done burning them off
Hoagie is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 05:29 AM   #2 (permalink)
Sid
Sid's Avatar
man I love those wheels. sorry no input
Stop (brakes), Drop(suspension), then Roll (power) -hooked_on4
Sid is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 06:32 AM   #3 (permalink)
Esteemed Member
boogie van's Avatar
check out emilio's wheels from 949 racing
http://clubroadster.net/forum/links....b_pages&cat=20
93 miata (sold)
waiting for my next miata.....
boogie van is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 06:48 AM   #4 (permalink)
Default Re: Wheels to fit 225 tires without rolling the fenders?
15x8 ATS DTC COMP LIGHT?
axiomtherapy is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 09:10 AM   #5 (permalink)
asianrice02's Avatar
it would fit. the 225/50/16 is too tall.
225/45/15 was my last set-up
I have been diagnosed by psychiatrist w/ a messiah complex.
asianrice02 is offline   Reply With Quote Quick reply to this message
Old 12-13-2006, 10:42 AM   #6 (permalink)
Thanks, I love them too Car looks so good rolling and cornering.
I emailed Emilio with some questions, thanks!
Saw these at Goodwin and they're really nice but too similar to my current BBSes despite being really nice.
I just need serious rubber. I've had two other NAs but they were N/A so just the 195/55R14 old Azenis on the stock wheels were amazing. But if I breathe on my go pedal it gets sideways
Old 12-16-2006, 02:16 AM   #7 (permalink)
STS2's Avatar
i second that on emilio's rims...........it's the way to go for 15" performance.
Kurt
1990 Classic Red Miata (STS/Track)
STS2 is offline   Reply With Quote Quick reply to this message
Old 12-16-2006, 07:51 AM   #8 (permalink)
Speed Racer
XCLR8TN's Avatar
I really like the rims you have now. Wow.
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap ...SOON
XCLR8TN is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 03:54 PM   #9 (permalink)
hoagie? you live in AZ?
kung fu jesus is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 04:06 PM   #10 (permalink)
Kicked off the island..
Miatadam's Avatar
Where did you get your rollbar pad? Is it custom or did you order it? Car is beautiful.
Miatadam is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 04:12 PM   #11 (permalink)
cheesefries's Avatar
RPF-1's
cheesefries is offline   Reply With Quote Quick reply to this message
Old 12-17-2006, 05:19 PM   #12 (permalink)
Savington's Avatar
15x8s, but 225/50 won't fit up front without modifying the fenders. 225/45 will, though, and the stickier stuff (Hoosier R6, Toyo RA-1) comes in that size. As far as wheels, Emilio's 15x8 is the way to go.
By the way - the RKs are HOT. Very nice wheels.
Black '94 | 8.6:1 1.9L, VVT, ABSURDflow GT2871R, AEM EMS, E85
KONI RACE/GC, 15x9 6UL/225 NT-01, Trackspeed BBK, DTC70/60
351whp/294wtq@17psi
[sigpic][/sigpic]
Savington is offline   Reply With Quote Quick reply to this message
Old 12-18-2006, 03:00 PM   #13 (permalink)
Pcola'sNB's Avatar
What would the difference be for 225/45/16 in physical size ( besides the obvious larger hole for the wheel )? Could you fit that on a factory NB 16''x6.5'' wheel? I'm looking for a slightly thicker sidewall, and preferably slightly wider tire.
/threadjack
www.creation.com
Pcola'sNB is offline   Reply With Quote Quick reply to this message
Old 12-18-2006, 06:45 PM   #14 (permalink)
Savington's Avatar
225/45-16 is 1 inch larger in diameter than a 225/45-15, which is about stock diameter. (Duh.) That makes it an inch larger than stock, which is too much. No, you can't CORRECTLY fit it to a 6.5" wheel. (You can fit anything on anything, but only certain combo ranges are "proper".) Proper size is 225/40-16.
If you want to fit without rolling fenders, you need 15x8s, +40 offset, and 225/45-15 tires.
351whp/294wtq@17psi
[sigpic][/sigpic]
Old 12-18-2006, 07:41 PM   #15 (permalink)
Pcola'sNB's Avatar
So would I be okay with a 225/40/16 on my stock NB wheels? Proper-wise..?
www.creation.com
Old 12-19-2006, 09:25 AM   #16 (permalink)
Yeah, Tempe
Previous owner had it custom made I believe.
Originally Posted by cheesefries @ Sun Dec 17, 2006 3:12 pm
RPF-1's
I really like the black hardtop on there, looks good
Thanks for the info. I'd like to get Emilio's black with polished lip 6ULs but they're at +36 offset, I think that'll make it harder to fit big rubber without rolling the fenders or cutting the fender liners.
I think I need to give up my hopes of getting big fat A032Rs on 6ULs without modifying anything on the car to make them fit.
Thanks for the ideas and compliments everyone
