xxr 527 - Page 22 - ClubRoadster.net
Go Back   ClubRoadster.net > HANDLING > Brakes, Wheels & Tires
Brakes, Wheels & Tires Got a nice set of wheels for your Roadster and wanna brag? Have questions about tires or brakes?
Old 03-26-2012, 07:43 PM   #631 (permalink)
Functionally formed.
_spyder's Avatar
Default Re: xxr 527
Originally Posted by Zapp View Post
Last time it was dyno'd it made 287whp with a tiny fan blowing on it on a 105 degree day.
Gotcha, good call on sticking with the 205's then
- 2008 6-speed Black Sapphire Metallic 135i
Photographer, videographer, graphic designer.
_spyder is offline   Reply With Quote Quick reply to this message
Old 03-26-2012, 07:45 PM   #632 (permalink)
Nicktorius's Avatar
Default Re: xxr 527
I can't find (decent)tires to put on these things!
I've been looking for 205/40/16 everywhere. Something preferably without an XL sidewall so I can stretch it a little. Discount Tire can't get any BF Goodrich G-Force Sport or KDW's because they are discontinued. Falkens are shit along with a number of other tires.
Any other options out there!?
2007 Mazda 3 - Black Mica
2005 Mazdaspeed MX-5 - Black Mica
2000 Miata - Evolution Orange Mica
1993 Miata - Crystal White
Nicktorius is offline   Reply With Quote Quick reply to this message
Old 03-26-2012, 07:46 PM   #633 (permalink)
Zapp's Avatar
Default Re: xxr 527
yup lol. Thanks for the help.
Zapp is offline   Reply With Quote Quick reply to this message
Old 03-28-2012, 01:49 PM   #634 (permalink)
Default Re: xxr 527
XXR 527
yellowmiata is offline   Reply With Quote Quick reply to this message
Old 03-28-2012, 01:52 PM   #635 (permalink)
Nicktorius's Avatar
Default Re: xxr 527
damn, those tires look hella beefy.
Old 03-28-2012, 02:00 PM   #636 (permalink)
ryanXstorey's Avatar
Look more stretched than anything.
RIP
1993 Electronic Pearl Blue Miata- Brain built MS2,Stock 1.6 with a SR20 turbo on 14 psi, 3 inch downpipe to open dump, custom stainless steel tubular manifold, Rx7 460cc injectors, MTX-L wideband.
ryanXstorey is offline   Reply With Quote Quick reply to this message
Old 03-28-2012, 02:08 PM   #637 (permalink)
RIP
Old 03-28-2012, 05:09 PM   #638 (permalink)
Default Re: xxr 527
im running 195 50
Old 04-03-2012, 06:05 PM   #639 (permalink)
Brunettes > Blondes
Dmn2258's Avatar
Default Re: xxr 527
im runnin 175/55 lol
Dmn2258 is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 06:24 PM   #640 (permalink)
Boostedmx5's Avatar
Default Re: xxr 527
I am using a 205/50
Boostedmx5 is offline   Reply With Quote Quick reply to this message
Old 04-04-2012, 01:09 PM   #641 (permalink)
sb253's Avatar
Default Re: xxr 527
sb253 is offline   Reply With Quote Quick reply to this message
Old 04-04-2012, 03:47 PM   #642 (permalink)
Got Wheel Gap?
Stumpy's Avatar
Default Re: xxr 527
^Impressive Stance!^
Sold - 2004 MSM
Stumpy is offline   Reply With Quote Quick reply to this message
Old 04-08-2012, 02:17 AM   #643 (permalink)
AdoboMiata's Avatar
Default Re: xxr 527
Anyone had issues with needing a hub centric for the wheels?
AdoboMiata is offline   Reply With Quote Quick reply to this message
Old 04-08-2012, 08:06 PM   #644 (permalink)
Default Re: xxr 527
Originally Posted by ryanXstorey View Post
definitely diggin this. should get better pictures.
peterr is offline   Reply With Quote Quick reply to this message
Old 04-08-2012, 09:19 PM   #645 (permalink)
blindboxx2334's Avatar
Default Re: xxr 527
my 513's never needed them. and im pretty sure ive seen lots of other dudes rockin xxrs without em
so im going to go with no.
flickr -
blindboxx2334 is offline   Reply With Quote Quick reply to this message
Old 04-09-2012, 09:34 AM   #646 (permalink)
Boostedmx5's Avatar
I'm running them.
Old 04-09-2012, 01:04 PM   #647 (permalink)
sb253's Avatar
Default Re: xxr 527
Im not. Correct install and correct lug nuts should be fine
Old 04-09-2012, 09:19 PM   #648 (permalink)
Brunettes > Blondes
Dmn2258's Avatar
Default Re: xxr 527
I didn't use hub centric rings....but I might put some on in the future
Old 04-10-2012, 02:21 PM   #649 (permalink)
Brunettes > Blondes
Dmn2258's Avatar
Default Re: xxr 527
Originally Posted by NAmike View Post
These wheels are sick, but they make the miatas look silly, To FreshNb. I seen your car on the old 16 xxr's correct? these are 15s and your car looks way higher than before. Maybe its the concave wheel..idk still lovin it though
they don't make miata's look silly at all!....I have them on my na and I still think they look 10x better on nb
Old 04-10-2012, 11:13 PM   #650 (permalink)
Default Re: xxr 527
Unless hub rings are aluminum they do nothing. the 60 degree conical seats of the 4 lugs center the wheels. The only negator of this would be aluminum or steel hub rings, and one or more lug holes or studs being out of place. In that case plastic hub rings would crack and not serve their purpose.
I'm ranting because I bought a pair before brushing up on physics or even thinking logically for that matter. I don't want anyone else to make the same mistake
Cammed Ls1 AllMotor Build
Ls1Mx5 is offline   Reply With Quote Quick reply to this message
Old 04-11-2012, 06:33 AM   #651 (permalink)
TurboTyla's Avatar
Fresh nbs car is still on,16s and perception is everything
you aren't tracking shit without a roll bar ,!!! "spoonboy"
TurboTyla is offline   Reply With Quote Quick reply to this message
Old 04-13-2012, 12:41 AM   #652 (permalink)
I used to be cool.
Fresh NB's Avatar
Default Re: xxr 527
I'm running 205/40/16 Falken Ziex ZE-512's on my setup. Works great for me.
'05 Crossfire SRT-6 - Current
'05 Sunset Bronze Mica MSM - SOLD
At first glance I thought it was Breezy and then realized the wheels and tires actually kinda fit.
Fresh NB is offline   Reply With Quote Quick reply to this message
Old 04-13-2012, 05:18 PM   #653 (permalink)
Default Re: xxr 527
even tho i dont have my car anymore. i love these wheels so much, that ive decided they are going to go on my next hooptie ;D
with that being said, Fresh nb, no matter how much i look at your car, it never gets old. its just so perfect. and the colors go great! (i really like metallic orange)
flickr -
Old 04-16-2012, 05:03 PM   #654 (permalink)
Nicktorius's Avatar
Default Re: xxr 527
I forgot to update, but I ended up going with 205/40/16 BF Goodrich G-Force Sport. The wheels and tires have been sitting in my living room for weeks now. I had an issue with my coilover install so I have to fix that before the wheels go on.
Old 04-18-2012, 12:02 AM   #655 (permalink)
Default Re: xxr 527
I LOVE THESE WHEELS!!
what size can fit without colivers?? looking for 16"
where do i get these from in melbourne, Australia. any1 selling a set?? lol
adz089 is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 02:06 AM   #656 (permalink)
Solace's Avatar
Default Re: xxr 527
16's would be ideal for NB. 15's would be best for NA fitment wise. You will have to look into finding a set in your area yourself. Best to go to the main car forum in your area and go on from there.
Solace is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 04:16 AM   #657 (permalink)
Default Re: xxr 527
i can get the them here Australia, there only 3 times more expensive than the US..
has anyone put these wheels on without coilovers?? size and offset the used??
Old 04-18-2012, 02:29 PM   #658 (permalink)
saldale's Avatar
Default Re: xxr 527
17x8.25 ET35
The Black Pearl
Eibach Pro Kit, Yellow Dot sways, Aluminium Strut Brace kit, Apollo K&N, LSD, 4.44FGR, Larini Exhaust, XXR's 17x8.25 ET35, 235's Federals 595RS-R
saldale is offline   Reply With Quote Quick reply to this message
Old 04-18-2012, 07:09 PM   #659 (permalink)
Solace's Avatar
Default Re: xxr 527
Make yourself more clear next time. Best bet is to buy online from NLmotoring.
It doesn't matter if these are put on with or without coilovers. If they fit, they fit. Simple.
Please clarify what generation miata you have to make it easier for the people to help and look through this thread and i am sure it will help you. There are many examples to look at.
Old 04-18-2012, 09:13 PM   #660 (permalink)
Default Re: xxr 527
thanks guys, sorry for the noob questions. im new to the mx5 / miata world.
its a 2002 nb btw,
