M2 Quality - ClubRoadster.net
Go Back   ClubRoadster.net > ROADSTER STYLE & AFTERMARKET > Roadster Special & Limited Editions
Roadster Special & Limited Editions Discuss the different Special and Limited Edition Roadsters from around the world, but please...post the pics in the Album under the correct category.
Old 10-02-2007, 05:02 PM   #1 (permalink)
Esteemed Member
roadsternut's Avatar
Default M2 Quality
roadsternut is offline   Reply With Quote
Old 10-02-2007, 05:16 PM   #2 (permalink)
Roadster Dave's Avatar
Default Re: M2 Quality
No problem, you should be able to just go down to your local mazda dealer and...
Good luck finding a new one. I would try and get in contact with someone in japan as it seems someone is always parting one out. Should not be that hard to get considering it is not one of the most desirable pieces from the car.
Roadster Dave is offline   Reply With Quote
Old 10-02-2007, 06:05 PM   #3 (permalink)
Nevadabob's Avatar
Damn
Well, at least you can swap the opener from the other, probably not as well used passenger side door over to the driver door. Then I suppose just use a regular Mazda opener as a temporary fix for the passenger side door.
The older KG Works openers were similar to the M2 openers, just not as nicely shaped. The opener on the KG Works opener was machined aluminum. The newer KG Works openers I beleive are chromed plastic.
Nevadabob is offline   Reply With Quote
Old 10-02-2007, 09:56 PM   #4 (permalink)
freedomgli's Avatar
I've seen that happen before. There was a set on YJ not too long ago with the same exact problem. If you had that you'd be whole again. Did you catch something on it when getting in or out? That is a weak spot. You could have it repaired but it is not simple. Alternatives are to replace it with Nakamae aluminum handles or AeroDramatics. I prefer the M2 shape myself but they are pricey and hard to come by. Good luck!
Old 10-03-2007, 02:57 AM   #5 (permalink)
retrorocket's Avatar
well unless Andy has bought an M2-1001 to add to his 1002, I'm guessing that is a library picture ....
as Kyle said this seems to be a major problem with the M2 cast door pulls ..... on every set I have seen ( used ) on JYA at least one of the pair has a stress/shear crack ..... only on the two sets of NOS ones I have seen for sale have been perfect and they went for $500 - $700 a set :shock:
M2 are much nicer design IMO but you may preserve the ones in your 1002 by replacing with a set of K G Works ones
retrorocket is offline   Reply With Quote
Old 10-03-2007, 11:30 AM   #6 (permalink)
Rare Parts Hoarder
Phatmiata's Avatar
well it is a 15 year old part. :wink:
No Roadster, No Life!
Phatmiata is offline   Reply With Quote
Old 10-03-2007, 12:51 PM   #7 (permalink)
Esteemed Member
Yep, library picture. Thats probably the reason my 1002 came from Japan with standard pulls. At the moment, I'm not interested in keeping the 1002, so tracking down suitable door handles can be the job of the next owner.
Might be nicer looking, but obviously lousy manufacturing quality.
Old 10-04-2007, 02:57 AM   #8 (permalink)
fair enough .... probably jointly due to too much leverage force going through too small a section of alloy that isn't strong enough ?
unlike the OEM plastic pulls on the standard cars these ( on only 300 / 1001's , 100 / 1002's and 40 / Tokyo models + a few for spares stock ) probbaly didn't see hundreds of hours of product testing due to the limited numbers !!!
Old 10-05-2007, 12:36 PM   #9 (permalink)
bobai's Avatar
:shock: I've got a pair of those around here somewhere! How do I post stuff on JYA? :wink:
bobai is offline   Reply With Quote
Old 10-05-2007, 12:44 PM   #10 (permalink)
freedomgli's Avatar
Give them to me and I'll take care of them for you.
