Random Thoughts: Episode 6.0 (Return of the Bae?) - Page 7 - ClubRoadster.net
Go Back   ClubRoadster.net > DISCUSSION > Pub Roadster
Pub Roadster Non-Automotive General Chit Chat
Closed Thread
Old 06-03-2016, 09:12 PM   #181 (permalink)
Murse Magnet
Andy's Avatar
Default Re: Random Thoughts: Episode 6.0 (Return of the Bae?)
Random thought: For you people that know more than I do about diesel engines. What causes an engine to run away and how do you stop it? Just heard that that was a thing today.
Play stupid games, win stupid prizes.
Andy is offline   Quick reply to this message
Old 06-03-2016, 09:17 PM   #182 (permalink)
Too young to #swag
sellinger18's Avatar
Not sure how you stop it, but it's when the engine gets extra fuel and continues to overspeed and keeps raising the rpms until failure. Basically.
sellinger18 is offline   Quick reply to this message
Old 06-03-2016, 09:22 PM   #183 (permalink)
Rudy's Avatar
+1.
Best way to stop it depends on manual or auto.
Manual - While at a complete stop, put it in the highest gear (i.e. 5th or 6th) and dump the clutch. Unless you're in a high powered monster car/truck, it should kill the engine. If not, read next:
Auto - stuff something in the intake. Diesels are like gasoline engines in which you need air and fuel to make it run. Stuff a rag in the intake and you cut off the air supply, causing it to die.
The 100% most effective way I've ever seen, was a gentleman popped open the intake lid on his truck and unloaded a fire extinguisher in it. Killed the motor in a heartbeat.
It's 'cause I dropped my mixtape. I spit that hot fire. Word.
Rudy is offline   Quick reply to this message
Old 06-03-2016, 09:25 PM   #184 (permalink)
Old Threads > New Threads
Stoly's Avatar
Fuel. Air. Spark.
Remove any one of the three and an engine can't function.
Stoly is offline   Quick reply to this message
Old 06-03-2016, 09:28 PM   #185 (permalink)
Stoly's Avatar
Originally Posted by JennB View Post
I've never used a lawnmower in my life.
Apologies to Mike and my girlfriend but I kinda have a crush on you right now.
Old 06-03-2016, 09:34 PM   #186 (permalink)
I will find you. And I will kill you.
chiefmg's Avatar
As was said, generally this is the result of the engine getting extra fuel. This can take the form of lube oil getting into the intake (some older Detroit Diesels used by the US Navy were known for doing this, mainly due to their requirement for repeatedly testing the emergency shutdown. Over time this would cause the oil seals on the superchargers to get displaced thereby allowing lube oil into the intake) or a failure of the fuel system. Probably the best way to shut down an engine is to interrupt the fuel supply. Barring that, then cut off the air supply (although that can bite you in the ass as noted above). Industrial diesels have some sort of overspeed trip that can also shut things down, this is usually done by shutting off the air supply.
chiefmg is offline   Quick reply to this message
Old 06-03-2016, 09:44 PM   #187 (permalink)
DarkSwordsman's Avatar
Do the FCs not sell well? If I can't fix my car, I'm going to part it out and try to get this (as long as it's a good deal): https://newyork.craigslist.org/jsy/cto/5601277210.html
19"89" Miata
DarkSwordsman is offline   Quick reply to this message
Old 06-03-2016, 09:47 PM   #188 (permalink)
Rudy's Avatar
You want to go from a Miata to a rotary platform?
I just want to make sure I understand that right.
Old 06-03-2016, 09:51 PM   #189 (permalink)
Well, this one caught my eye. >.>
It's not a definite, I just would like to have one over a Miata, yes. Plus look at that price. If there's really nothing wrong with it besides the radiator fan, I would totally take it.
19"89" Miata
Old 06-03-2016, 09:59 PM   #190 (permalink)
See You Next Tuesday!
jpatrick's Avatar
Whatever you do, don't touch the AFM on it.
jpatrick is offline   Quick reply to this message
Old 06-03-2016, 10:03 PM   #191 (permalink)
Louros's Avatar
https://en.m.wikipedia.org/wiki/List..._United_States
Louros is offline   Quick reply to this message
Old 06-03-2016, 10:06 PM   #192 (permalink)
Too young to #swag
That's really not a bad price for what it is; but if I were you, I would not get it. From what I've seen you mention here in the forums, it would not be a good option. You're in high school with a very limited budget and, most likely, not that familiar with a rotary platform.
On average, you will have more problems with the rx7 than you would with the miata.
Old 06-03-2016, 10:09 PM   #193 (permalink)
100percentjake's Avatar
"My miata is too unreliable/broken"
"IMMA GET AN RX7"
I make bad decisions.
100percentjake is offline   Quick reply to this message
Old 06-03-2016, 10:15 PM   #194 (permalink)
It actually turns out that the guy had it listed for $8,500 and he put $12,000 worth of work into it. He had to drop the price because he needs money for rent and stuff; there's a whole story behind it. If I had the cash I would totally buy it and try to sell it immediately.
19"89" Miata
Old 06-03-2016, 10:19 PM   #195 (permalink)
Too young to #swag
There's a reason besides that why he dropped the price. It means that he's been having a hard time trying to sell it at that price, so he lowered it to a more reasonable price.
Old 06-03-2016, 10:19 PM   #196 (permalink)
R U ?
horribleR's Avatar
and then not get your money back..
horribleR is offline   Quick reply to this message
Old 06-03-2016, 10:24 PM   #197 (permalink)
01cblue's Avatar
Twice in the past decade I've forgotten the Interpol Antics album is awesome.
01cblue is offline   Quick reply to this message
Old 06-03-2016, 10:27 PM   #198 (permalink)
Financial Guru
JennB's Avatar
So you want to get a car that the owner is having a hard time selling... so you can sell it.
2005 Black Mica Mazdaspeed MX-5 - FM Intake - Enthuza Midpipe and Exhaust - FM DP - Hallman MBC - Upgraded Intercooler - Hard Dog Roll Bar - Volk TE37 - Hardtop - and then some...
2012 Porsche Cayman R - Carrara White
JennB is offline   Quick reply to this message
Old 06-03-2016, 10:38 PM   #199 (permalink)
humming's Avatar
Yardcare: what I am least looking forward to about home ownership someday.
Pickles are terrible. Cucumbers soaked in evil.
Random thought:
What has been/is your favorite TV commercial?
My wife and I have been comparing our favorite commercials for the last hour.
An oldie, but I loved it:
2005 Lava Orange MSM -
Originally Posted by maarp
...I'm a man of wealth and taste. Well. not so much the former, and I'm working on the latter.
humming is offline   Quick reply to this message
Old 06-03-2016, 10:48 PM   #200 (permalink)
01cblue's Avatar
Pickles are terrible. Cucumbers soaked in evil]
We live in southern AZ. No yardwork to speak of, unless one is wasting an awful lot of water to produce said yard.
Dill pickles with a burger. How you cannot like that is beyond me unless you're some damn kind of communist.
Old 06-03-2016, 11:03 PM   #201 (permalink)
Maybe I should just give up on everything for now. Just sell my car so I have money for college and give up my plans for MATG. I'll bet you all $100 each that I'll blow something up on the way down if I keep it.
19"89" Miata
Old 06-03-2016, 11:09 PM   #202 (permalink)
Too young to #swag
Things won't blow up on you if you fix it right. Why would you sell your car?
Old 06-03-2016, 11:14 PM   #203 (permalink)
R U ?
horribleR's Avatar
this is a good buy. spare cars/parts = free money.
http://sfbay.craigslist.org/sby/cto/5575814429.html
Old 06-03-2016, 11:17 PM   #204 (permalink)
Too young to #swag
That's $9500 for the whole lot; not $1000. Still not bad, but that's a high capital investment on something that most likely has a long return rate of revenue.
Old 06-03-2016, 11:28 PM   #205 (permalink)
(⌐■_■)
freshbuzz's Avatar
Such a sad way to ruin a perfectly good cucumber
Ad hominem
freshbuzz is offline   Quick reply to this message
Old 06-03-2016, 11:33 PM   #206 (permalink)
(⌐■_■)
freshbuzz's Avatar
I'd recommend you do this regardless of what you do with your car. There's aways next year for MATG, but you have no money, a questionable car, and college starting soon. You'd rather have that money for the school year, trust me
Ad hominem
Old 06-03-2016, 11:34 PM   #207 (permalink)
humming's Avatar
Fascist, thank you.
I'm in phoenix, but my wife wants grass in the back yard whenever we get a house.
Old 06-03-2016, 11:47 PM   #208 (permalink)
Sponsor
Chris@Moss's Avatar
Chris Knight
Chris@Moss is offline   Quick reply to this message
Old 06-03-2016, 11:48 PM   #209 (permalink)
Sponsor
Chris@Moss's Avatar
Fake grass / astroturf.
Chris Knight
Old 06-03-2016, 11:50 PM   #210 (permalink)
(⌐■_■)
freshbuzz's Avatar
I think the DSL line is more sig worthy than the pickles one
Ad hominem
Closed Thread
Tags
alabama hot pocket, bryan in a speedo, bryan in running shorts, get off my lawn!!!, good caulking, ping pong ding dongs, pocket pussy, rimz rimz rimz rimz rimz, the big toe massacre, truffle butter, where the white women at, yakusoba noodle sweater
