turbo quetion keep in mind turbo noob - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Forced Induction - *Sponsored by Kraftwerks USA*
Forced Induction - *Sponsored by Kraftwerks USA* High spoolin', force-fed fun! Talk about your boosted mods here.
Old 01-27-2008, 09:33 AM   #1 (permalink)
moe
moe's Avatar
Default turbo quetion keep in mind turbo noob
ok so i was wondering for low end turbo system would you need a emanage because im looking at getting a begi turbo kit so thats my noob question sorry if sound retarded
moe is offline   Reply With Quote
Old 01-27-2008, 11:04 AM   #2 (permalink)
FUCK YOU!!!!
emmi's Avatar
anything that will add more air will need more fuel. the emanage is okay, but the lil upgrade parts can be so expensive. if ur getting the emanage blue, then u have to spend more to add timing control etc etc. like an ala carte thing
emmi is offline   Reply With Quote
Old 01-27-2008, 11:18 AM   #3 (permalink)
moe
moe's Avatar
so what do you recommend so that the little things do cost sooo much?
Originally Posted by Replica http://www.houston-imports.com/forum...s/viewpost.gif
The way to tell if it sucks, is if there are axles going to the front hubs and there's no drive shaft going to the back wheels.
Old 01-27-2008, 11:19 AM   #4 (permalink)
moe
moe's Avatar
oh and what about the mega squirt would that be worth the price
Old 01-27-2008, 04:38 PM   #5 (permalink)
if you feel comfortable with wiring the megasquirt seems to be the best way to go for a cheaper ECU. I am going this way this summer. You can get a MS kit for about 300 dollars then add the wideband in and you will be good to go. THe folks at DIY auto tune will be able to talk to you about what you should get. You can also get the same model they use for their PNP so you can use their base map.
Andrew
wademunkey is offline   Reply With Quote
Old 01-27-2008, 04:52 PM   #6 (permalink)
What year is your car??
Cause right now you can get any OBD1 car a PNPMS from DIY for 700. Its the best system you can get sub $1000. Its going to be 100x better then the emange for any car OBD1 right now. I know DIY is working on starting the OBD2 system but not sure on any new date(have an OBD1 so haven't keep up with it)
Doesn't the BEGI kit come with a FMU?? If so then you would be set for low boost fuel.
wildfire0310 is offline   Reply With Quote
Old 02-06-2008, 07:31 PM   #7 (permalink)
Hazimwood's Avatar
Default Re: turbo quetion keep in mind turbo noob
Dont be a fool. Spend a litlte more and worry a lot less; get yourself a Megasquirt PNP and done with it. Lets see, if you have a 1.6, then getting rid of the Mass Airflow Meter will cost a little less than $20.00. And to run the larger injectors is a snap. Wiring...what wiring? The ECU connectors snap right into it! The interface is great and there is a lot of support on the net for it.
Hazimwood is offline   Reply With Quote
Old 03-30-2008, 12:20 AM   #8 (permalink)
MX54PLA's Avatar
MegasquirtPNP is so easy even a caveman can do it. couldn't resist..just unplug old ECU...plug in Megasquirt....set timing and away you go
MX54PLA is offline   Reply With Quote
Old 03-30-2008, 01:27 AM   #9 (permalink)
BACK BY POPULAR DEMAND
ultimateforce's Avatar
I think I blew my MSPnP today just plugging it in, I have no idea what happened but I am not a happy camper.
Dumb Cars I Own:1986.5 Nissan Hardbody (longbed), 1994 Nissan 240sx (Convertible), 1994 Mustang GT
Shout-Outs: Hank Chinaski, sonique128, Skinnyroadster, Oops2Low, mk_slayr, Haigog, Kuane.
Certified TIG Welder: 304 Stainless / 5052 Aluminum - 3F / 3G - 1/16th - 1/4th inch thick.
Keep the Jeep Riding. http://www.youtube.com/watch?v=MCMFt...eature=g-all-u
ultimateforce is offline   Reply With Quote
Old 03-30-2008, 01:51 AM   #10 (permalink)
dontpassthefence's Avatar
I wish there was an MSPNP for the NB models ;_; - sounds like even a re-re like me could tune my car with one
2004 Ponyspeed Miata #2595 [SOLD!]
2013 Scion FR-S #500
Originally Posted by 01cblue View Post
Screw whole milk, shit makes you slow and fat. Real men drink beer.
dontpassthefence is offline   Reply With Quote
Old 04-03-2008, 09:51 PM   #11 (permalink)
kurtrohmer's Avatar
if i'm not mistaken diyautotune is coming out with a "ultra mega squirt" might this be something for the NB people?
PROJECT WAKAZASHI: Remote Mount Turbo
JDM 1.6, Garrett GT2256VariableVane, Mitsu I/C, Megasquirt PNPwLC1, DENSO460's (red tops), RacingBeat, ACTII,OZ Racing,AVS100E,Harddog Rollbar, HeaderWrapped, custom wizdom frontfascia with 6" hellas, EBC Redpads with stockbrakes, TrePerformance255lph/HP, NitrousXpress dry50shot, Coil Over Plugs by SAVINGTON (worth weight in gold).
kurtrohmer is offline   Reply With Quote
Old 04-04-2008, 04:29 PM   #12 (permalink)
PaKMaN's Avatar
I've got a Plug n Play Greddy E-manage.. Everything you need... $350 shipped.
GT30R powered 1994 Mazda Miata
2000 Mazda Miata
PaKMaN is offline   Reply With Quote
Old 04-04-2008, 05:48 PM   #13 (permalink)
moe
moe's Avatar
sweet thanks for the help guys really appreciate it
Old 04-04-2008, 06:35 PM   #14 (permalink)
tougeroadster's Avatar
if youre getting the begi-s kit then it comes with a Fuel Pressure Regulator(FPR) which takes car of your fueling. All the begi kits come with everything you need.
tougeroadster is offline   Reply With Quote
