FMIC Installed - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Forced Induction - *Sponsored by Kraftwerks USA*
Forced Induction - *Sponsored by Kraftwerks USA* High spoolin', force-fed fun! Talk about your boosted mods here.
Old 05-20-2007, 06:32 PM   #1 (permalink)
ray_sir_6's Avatar
Default FMIC Installed
It only took 2 days to do, and alot of fab work by Brice @ Alamo. We mocked up the passenger side Saturday, then put back the stock stuff so I could drive home. Then went out there today (Sunday) and mocked up the driver's side and then installed it. It uses 2" on the DS and 2.5" on the PS.
91 Miata 1.6l Greddy Turbo AEM EMS
17psi 280whp@6200rpm/265tq@4400rpm, 2450lbs
ray_sir_6 is offline   Reply With Quote
Old 05-20-2007, 06:32 PM   #2 (permalink)
ray_sir_6's Avatar
Default Re: FMIC Installed
The PS is probably pretty typical of most FMIC installs. It just goes up between the radiator and the pulleys, straight to the throttle body. No BOV right now due to the supplied bung being steel, not aluminum. Should get that installed soon.
Old 05-20-2007, 06:33 PM   #3 (permalink)
ray_sir_6's Avatar
The DS took alot more time and fab work. We clocked the turbo, then went down thru the gap in the sub-frame and between the suspension control-arms to the IC.
Old 05-20-2007, 07:06 PM   #4 (permalink)
j0oftheworld's Avatar
That's really well done! A++
j0oftheworld is offline   Reply With Quote
Old 05-20-2007, 08:23 PM   #5 (permalink)
ray_sir_6's Avatar
Thanks.
Old 05-20-2007, 08:32 PM   #6 (permalink)
JDMAflac's Avatar
very nice, what intercooler are you running?
I really need to reroute my intake.
90' Mazda Miata- Boosted!
JDMAflac is offline   Reply With Quote
Old 05-20-2007, 08:35 PM   #7 (permalink)
UNDERSTAR's Avatar
Did you installed it yourself, ray_sir_6?? I dont have the balls to go through the process to do it myself. ARRG!!!!!!
GO KICKY FAST!!!
http://profile.myspace.com/index.cfm...endid=34041977
UNDERSTAR is offline   Reply With Quote
Old 05-20-2007, 08:53 PM   #8 (permalink)
slevin's Avatar
woah i just noticed, you actually welded your intercooler pipe to the compressor housing ?
slevin is offline   Reply With Quote
Old 05-20-2007, 09:31 PM   #9 (permalink)
ray_sir_6's Avatar
Default Ebay IC
Ebay
Core Size: 22"x5.5"x2.5"Inlet OverAll Size: 28"x5"x3"
Under $100 shipped.
Old 05-20-2007, 09:33 PM   #10 (permalink)
ray_sir_6's Avatar
I did some of the small stuff, but Brice @ Alamo Autosports in Arlington, TX did all the fab work.
Old 05-20-2007, 09:38 PM   #11 (permalink)
ray_sir_6's Avatar
Yeah, due to the limited space and the tight radius there wasn't any other way. We put a silicone hose before it went thru the subframe to allow for removal.
Old 05-20-2007, 10:29 PM   #12 (permalink)
Marty's Avatar
Very nice!
Marty is offline   Reply With Quote
Old 05-21-2007, 09:26 AM   #13 (permalink)
Lit like a BranchDavidian
Doppelganger's Avatar
you were starting to scare me!!!
aNYWAY, +1!!! On the job well done!!!!
2002 Ti SE Turbo
Doppelganger is online now   Reply With Quote
