Just a little boost..... how simple? - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Forced Induction
Forced Induction High spoolin', force-fed fun! Talk about your boosted mods here.
Old 04-01-2012, 06:35 AM   #1 (permalink)
Default Just a little boost..... how simple?
Hey Guys,
I was wondering if anyone had any experience with putting a "lite" turbo setup on. I don't want to lose reliability or spend thousands, I just want to add a little pep. I was thinking a tb02 or a t25. Maybe something that came off a stock turboed car like an audi tt or something. I have heard that if I am only running 5psi I don't need injectors, intercooler, and I can get away with a lot less of electronics as well. Can someone set me straight?
stover954rr is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 08:05 AM   #2 (permalink)
Default Re: Just a little boost..... how simple?
Check out turbomiata.net lots of forced induction information there. I am running 7lbs of boost in my 94 1.8 with a garrett2560, an intercooler, stock injectors, and megasquirt for fuel/timing. You will need to address fuel and timing, either with bandaids or with a standalone ecu.
drummersrs is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 08:07 AM   #3 (permalink)
To answer your question, yes u can run 5lbs no intercooler, stock injectors,.but.u will want to run a aftermarket ecu, or run a bandaided set up using a rising rate fuel pressure regulator, and an o2 clamp, or something to control timing.
Look at spending around 1000 if u want to fix it.every week, and 2000 if u want to have more time drivng rather than fixing.
Old 04-01-2012, 10:23 AM   #4 (permalink)
Yeah, that is what I don't want to get into. In the summer this is my wife's daily driver. I just wanted some extra pep without any of the headache.
Old 04-01-2012, 10:24 AM   #5 (permalink)
So how often do you have to mess with it. (I would have asked in the previous post, but I just realized it was the same person!)
Old 04-01-2012, 12:07 PM   #6 (permalink)
small turbo. BEGI Fuel Management Unit, Bipes ACU, O2 clamp. done. simple cheap no major hassles.
oh, you will have the small headache of tapping the oil pan, getting whatever downpipe you have to fit properly (if you are going cheap).
but +1 for goint to MT.net, or M.net for additional info.
kurt rohmer is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 01:09 PM   #7 (permalink)
Kurt,
I appreciate the input! I will venture over into the shark tank that is MT.net
Old 04-01-2012, 01:28 PM   #8 (permalink)
JO
d[-_-]b 56-783
JO's Avatar
Considered supercharger? Simple bolt on. Not too expensive. And always fun
Contact
for all your miata needs!!
God damn I would tell this mother fucker to search but I swear he probably can't even read fucking words
brb, gonna go punch pregnant chicks
JO is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 01:31 PM   #9 (permalink)
I am more of a turbo person. Also my wife's commute is 105miles round trip. So I like the idea that she can stay out of boost for the most part. I just want her to have a little extra for passing.
Old 04-01-2012, 01:45 PM   #10 (permalink)
JO
d[-_-]b 56-783
JO's Avatar
s/c doesn't stay in boost...
but if ur stuck on turbo, good luck
Contact
Old 04-01-2012, 01:57 PM   #11 (permalink)
(ಠ_ృ)
brontosaurus's Avatar
I think a low-boost, well- sorted turbo setup would be less of a hassle. No extra belts to deal with/funky idle. Just grab an off the shelf BEGI-S Shanghai kit and be done with it. Spring for the SS oil return and a turbo heat shield so you don't need to worry about them.
Old 04-01-2012, 02:05 PM   #12 (permalink)
Sponsor
ThePass's Avatar
Then don't turbo it. Any turbo setup that doesn't have any headaches costs a lot more than $1,000. Want something that adds pep and doesn't have any issues? Get a small supercharger. There are lots of reasons that we prefer turbos over superchargers for racing applications, but if you want to avoid the headaches AND want to keep it cheap, don't get a turbo.
Turbos have 1000 more components than superchargers, which can all wear out or break, and produce ridiculous amounts of heat, which stresses EVERYTHING else on the car. Even with a low-power simple kit like a BEGI-S, you'll find yourself needing to fabricate heat shields, tweak things, adjust the wastegate, drill and tap the oil pan, replace coolant lines, troubleshoot oil drain leaks, etc. etc.
You'll also need additional things for a turbo kit that you don't need for a supercharger - a boost gauge for example, because a wastegate failure can change the boost output, whereas a supercharger only produces one set psi depending on your pulley choice. No need to monitor your boost output.
Ryan Passey
ThePass is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 03:37 PM   #13 (permalink)
JO
d[-_-]b 56-783
JO's Avatar
i'm no boost freak, so i dont have the knowledge most do about turbos, but even then, i doubt it'd be less of a hassle, even with the begi kit.
S/c consist of the blower, pulley, belt, and crossover tube. super simple. i installed mine in approx. 2 hours... i sold my jrsc for $900 w/ 40k miles. still strong, and as far as i know, the buyer is still running it. 5-6psi, nice kick when u step on it, only boosting when u floor it, so gas wasnt an issue. i loved it.
+1
anywayz, lets not make this another s/c vs. turbo thread.
op, good luck with ur search, i was just curious to see if u had considered the s/c.
-Jo
Contact
Old 04-01-2012, 03:47 PM   #14 (permalink)
Boostedmx5's Avatar
Have had both a s/c and turbo on same car. Turbo is a far larger hassle than a s/c.
Boostedmx5 is offline   Reply With Quote Quick reply to this message
Old 04-01-2012, 03:51 PM   #15 (permalink)
+1
-Jo
This is great input. And frankly I never really think of SC, mostly because I am a suby guy and have owned a few turbo cars. I just liked driving around and watching the boost gauge sit at zero until I really get on it. I truly don't have a good understanding of SC and just thought that they boosted the car equally based on your rpms. Where as turbos need time to spool and only really get going 3.5krpm (obviously this depends on the turbo).
Old 04-01-2012, 03:52 PM   #16 (permalink)
Thanks!!! I love first hand experience.
Old 04-01-2012, 04:35 PM   #17 (permalink)
(ಠ_ృ)
There's a bypass valve, you're not in positive pressure all the time. When you get on it, the bypass closes and you have instant (more or less) boost based on whatever rpm you're running at. Depending on the setup, you can easily have full spool at 3k (gt2554r/tubular manifold/separated gases downpipe).
Old 04-02-2012, 12:43 AM   #18 (permalink)
Just to add to confusion, how small of a turbo can you get? (response wise, in conparo to supercharger, I don't wanna loose energy to that parasitic effect of the SC)
2.
If I go boosted I'm ...aw! Screw it! Begi kit 1 it is. Is there a cheaper kit?
As, I would pay 3K for 200+hp but if I'm looking for less, what would you recommend? For 2K and some shells?
3.
And last how does drivability differ from stock:turbo and s/c? (partial throttle)
2000NB Silver/tan. Done: FM springs, Bilsteins.
silvermazda is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 02:11 AM   #19 (permalink)
Sequence Number 1280
terry pham's Avatar
anyone looking to spend more than 2k can have our turbo 1.8 setup with the mspnp already tuned
-=tHa pHaM bRoS dOn'T F()cK aRouNd=-
terry pham is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 07:23 AM   #20 (permalink)
docrice's Avatar
If you decide to go turbo I'd suggest looking at the BEGI kits, especially if you're not a pretty serious tinkerer or if the car is going to be a DD (which you say it will). The shanghai kits start at around $1600 with EVERYTHING you need, ready to bolt on. You can slowly upgrade from there if you want more power, or leave it as is and have a nice reliable setup. Your wife, if she's like mine, would probably want more power down the road, so it's nice to have something you can slowly and relatively cheaply upgrade, where a supercharger is a little more difficult to upgrade in small increments.
docrice is offline   Reply With Quote Quick reply to this message
Old 04-02-2012, 01:33 PM   #21 (permalink)
terry pham's Avatar
Still needs a bypass (BOV - Blow Off Valve) and timing controller (ie. Bipes ACU), therefore, the kit is not complete. Also, you can never claim that any turbo setup is a "nice reliable setup." There will always be some sort of complication that will arise over time. Turbo gaskets go out all the time. Turbo studs/nuts need to be watched over or retorqued now and then. The exhaust system will need to be re-worked as well.
Old 04-02-2012, 01:50 PM   #22 (permalink)
JO
d[-_-]b 56-783
JO's Avatar
what do u mean by our?
Contact
Old 04-03-2012, 04:24 PM   #23 (permalink)
jdmmmmx's Avatar
^i was wondering the same thing
jdmmmmx is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 04:29 PM   #24 (permalink)
R U ?
horribleR's Avatar
GReddy.
horribleR is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 04:31 PM   #25 (permalink)
Haerie Ballsagna
concealer404's Avatar
Holset.
PM me for Amsoil fluids.
Originally Posted by Corky Bell
Understanding how it works and even it's limitations doesn't really matter.
Gotta tell you, Quaker Oats with Jose is a real treat.
corky
concealer404 is offline   Reply With Quote Quick reply to this message
Old 04-03-2012, 04:32 PM   #26 (permalink)
R U ?
horribleR's Avatar
HPF
Old 04-03-2012, 04:33 PM   #27 (permalink)
Haerie Ballsagna
Thomas Knight
corky
Old 04-03-2012, 04:44 PM   #28 (permalink)
George Clinton and the P-funk allstars
(We are having a naming game right?)
Old 04-04-2012, 07:47 AM   #29 (permalink)
Haerie Ballsagna
Kindof... but not that sort of thing.
corky
Old 04-04-2012, 11:39 AM   #30 (permalink)
PookieBear's Avatar
For the op, if you want a turbo then get an fm turbo kit and be done with it. If your gonna source out parts to boost your car then get a standalone and have it tuned with the turbo your building up. You don't want to run lean on high rpm using stock injectors. You can't really cut corners on boost, it will cost you a motor. Better yet buy a SC call it a day. I had a 89 mr2sc and 91/93 mr2 turbo. Although my turbo was much faster, I ran into more problems in and out of the track. My sc never gave me issues. All you need is 150-200 whp on a miata.
I don't know if you have a 1.6, but If I saw this post a few days ago; I could have sold you my old greddy for $500.
For brontosaurus, because I don't want to hurt your feelings. I just own a 97 miata.
PookieBear is offline   Reply With Quote Quick reply to this message
