FujiRacing IRTB Air Box - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > IRTB (Individual Runner Throttle Bodies)
IRTB (Individual Runner Throttle Bodies) Quadruple your fun! Nothing like Naturally Aspirated Power!
Old 02-18-2008, 09:17 AM   #1 (permalink)
Sponsor
4 Throttle Tuning's Avatar
Default FujiRacing IRTB Air Box
You all are the first to hear this. We will be releasing our IRTB Air Box soon. It will be TIG welded-hand made and it already is on a customers Miata. No pictures until the release date, and I am looking at up to $750.00 retail. Quality will be second to none.
If you want I do not have a problem with you guys posting pictures of what you have seen on air boxes and then you will see ours.
Jimmy
IRTB NA Miata LAGUNA SECA Lap Time 1:44 w/146 RWHP. 130 RWHP 13.9 SEC. 1/4 MILE ON YOU TUBE! FujiRacing 7.2 lb. Flywheel-FujiRacing Short shifter. FujiRacing UD Pulley SPEC Clutch-Swift Springs-NX Express-Carbotech Brake Pads. ROTA Slipstream 15 x 7.5.
4 Throttle Tuning is offline   Reply With Quote
Old 02-18-2008, 09:23 AM   #2 (permalink)
freedomgli's Avatar
When you say it's TIG welded I assume it's made from aluminum? Does this mean FI + IRTB?
Old 02-18-2008, 09:36 AM   #3 (permalink)
Default Re: FujiRacing IRTB Air Box
So when is the expected release date?
Also, will the inlet for the airbox be located in the same position as the stock throttle body?
avante43 is offline   Reply With Quote
Old 02-18-2008, 10:07 AM   #4 (permalink)
Kicked off the island..
Miatadam's Avatar
I would assume its aluminum by the price tag also. Most fiberglass/resin/composite IRTB air boxes run around $300. But they can't handle FI, they're more for plumbing purposes.
Miatadam is offline   Reply With Quote
Old 02-18-2008, 01:14 PM   #5 (permalink)
Sponsor
One box will be for NA (first to be released) and the FI one will use a thicker grade material for the pressurization. I am hoping to release these within 1 month or 2 at the latest. The last post from Miatadam is correct from what I have seen thus far. Our design was carefully thought out to be able to utilize the longer airhorns if needed.
Jimmy
Old 02-18-2008, 01:36 PM   #6 (permalink)
Chucky's Avatar
Will they clear the washer bottle? Chuck
Chucky is offline   Reply With Quote
Old 02-18-2008, 02:25 PM   #7 (permalink)
Finger lickin' good...
LostSoulMiata's Avatar
So is this a custom built to order thing or is it based off of what works best for you Jimmy?
Andrew
- '98 Honda Superhawk
- '88 Yamaha YSR50 - "Play Thing"
'78 Honda CB750F SOHC SuperSport - "Lucky 13"
LostSoulMiata is offline   Reply With Quote
Old 02-18-2008, 07:02 PM   #8 (permalink)
Sponsor
It's actaully do to one of my IRTB customers and the box is sized bigger than what I have seen with other boxes and the washer bottle will have to be relocated. It's what we hope will work best on a Miata.
Jimmy
Old 02-18-2008, 07:08 PM   #9 (permalink)
AUTOKONEXION.COM
leatherface24's Avatar
Jimmy and I have spoke about this thing. I have high hopes that im sure wont be let down
Originally Posted by Seth View Post
So glad some simple questions about what size wheel fits where has gone to a bike with a dildo as a seat.
leatherface24 is offline   Reply With Quote
Old 02-18-2008, 09:55 PM   #10 (permalink)
ab7
ab7's Avatar
Jimmy , what's better in term of performance?
ITB with socks or with box?
NB8B - Hydra EMS | MaximWorks + SMB Midpipe + Metal Cat | BMC CDA + CF Pipe | Volks CE28N + Advan AD07 | KYB AGX + Kings | SD short shifter + Voodoo | Bling...
ab7 is offline   Reply With Quote
Old 02-18-2008, 11:06 PM   #11 (permalink)
freedomgli's Avatar
9 times out of 10 a cold air box would be better for performance. Socks aren't so good as they spoil the airflow around the air horns.
Old 02-19-2008, 01:18 AM   #12 (permalink)
Moderator
Greg G's Avatar
Arrrgh I hate suspense !
Goodbye, ARC. Thanks for the awesomeness.
Greg G is offline   Reply With Quote
Old 02-19-2008, 05:28 AM   #13 (permalink)
Sponsor
My thinking use to be no air box was the way to go from what I had seen since the air boxes were too small. On our box the cold air will be coming in smoothly and you will be able to use the longer air horns up to 110mm for low-mid range torque. The key is cold air + utilizing the air horns.
Jimmy
Old 02-19-2008, 08:43 AM   #14 (permalink)
AUTOKONEXION.COM
when you say cold air, do you mean that the box will have an intake tube plumbed to a cooler spot in the engine bay or just the fact that itll be blocking out any hotter ambient air just by closing off the itbs from taking in and more radient heat from the engine?
Old 02-19-2008, 09:12 AM   #15 (permalink)
retrorocket's Avatar
.... or just plumb a tube down to a nice big intake in the nose
ram stylee
retrorocket is offline   Reply With Quote
Old 02-19-2008, 03:59 PM   #16 (permalink)
URN
im interested & will watch this thread with interest 8)
URN 96 Merlot Supercharged & Intercooled now sold & owning a G Ltd now with IRTB's
URN is offline   Reply With Quote
Old 02-19-2008, 05:13 PM   #17 (permalink)
Sponsor
Alright I will say this. "Cold air is going into the box and when I saw the finished product I about fellout of my chair." It's happening because of one of my customers and I have never seen anything that nice IMO when it comes to air boxes.
Jimmy
Old 02-19-2008, 09:47 PM   #18 (permalink)
Moderator
the blue potato's Avatar
...like drawing in air from behind the firewall?
The Blue Potato / 1995 NA8C Pitcrew #001 / R.S. Aizawa IRTB / RS Watanabe / KG Works
www.thebluepotato.net | http://www.thebluepotato.net/blog/
the blue potato is offline   Reply With Quote
Old 02-19-2008, 11:16 PM   #19 (permalink)
So is it tapered for better flow to the furthest away throttle body, or is it just a single one-size diameter plenum?
Andrew
Old 02-20-2008, 05:36 AM   #20 (permalink)
Sponsor
Air is coming from the front of the car and the box is not tapered because from our testing we want to utilize the longer airhorns.
Jimmy
Old 02-20-2008, 07:54 PM   #21 (permalink)
Matt [exz3owner]'s Avatar
what tests have you done?
for a FI box, most flow benching on other applications show the need for a taper.
curious to the net power gains in fi configurations...
cool project jimmy.
2008 Redline TimeAttack! Grand Champion
[img]hhttp://photos-g.ak.facebook.com/photos-ak-snc1/v271/25/27/561716982/n561716982_1086838_2140.jpg[/img]
Matt [exz3owner] is offline   Reply With Quote
Old 02-22-2008, 05:58 AM   #22 (permalink)
Sponsor
Originally Posted by Matt [exz3owner
@ Wed Feb 20, 2008 9:54 pm]what tests have you done?
cool project jimmy.
The first box will be for NA and Anniversary's box in Japan is tapered I believe since he has done IRTB/Turbo. If we need to make a tapered one for FI I am sure that that could be managed.
Jimmy
Old 02-22-2008, 06:00 AM   #23 (permalink)
enough talk already .......... pictures please :wink:
Old 02-22-2008, 06:02 AM   #24 (permalink)
wheresthepandas's Avatar
come on just give us a teaser photo or something. Pppppppplease
wheresthepandas is offline   Reply With Quote
Old 02-23-2008, 05:51 AM   #25 (permalink)
Sponsor
It's killing me but when I have been requested not to release it yet from one of my customers I have to and will honor that.
Jimmy
