ARRRGGGG!!!! My car hates me! - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > IRTB (Individual Runner Throttle Bodies)
IRTB (Individual Runner Throttle Bodies) Quadruple your fun! Nothing like Naturally Aspirated Power!
Old 09-15-2006, 08:20 PM   #1 (permalink)
rthompsonjr's Avatar
Default ARRRGGGG!!!! My car hates me!
Ok so everything was good at first. Then I put on a header and cat delete. Then everything went to hell. I thought it was the fuel pressue, which I set to factory. But its still acting bad. At ldle its fine, as soon as I tip in it starts spurtering. Once it gets going if I floor it from part throttle it just dies, not to the point it kills itself, but it just doens't go anywhere! The exhaust lets out black puffs of smoke so I assume its rich, it sure smells like it!
All the adjustments on the SUBCON are to the lean settings, and the Fuel Pressure is set to 35 without vacuum. I have my new cat finally and I'm going to put it on tomorrow AM. Will that affect my F/A ratio? Any other ideas? HELP?!!!
1991 Miata
1598cc of fury!!!!!
rthompsonjr is offline   Reply With Quote
Old 09-16-2006, 07:23 AM   #2 (permalink)
Sponsor
4 Throttle Tuning's Avatar
Default Re: ARRRGGGG!!!! My car hates me!
Just saw your post this morning & emailed one of my customers to see his exact setup. Here is his quote "I'm running an aftermarket header and currently running no cat. When you drove my Miata, she was equipped with a JR high flow cat. Both setups ran pretty rich The best I've been able to tune her would be running stoich @ full throttle in the mid to upper RPM range, and rich at cruising speeds". When I drove his car it idled better than mine and was running rich but not enough to foul the plugs. He's had our 1.6L IRTB kit with subcon for about a year now. I'll give you a call today since I will be talking to others about your problem. I always call Japan on Sunday evening(Monday morning) in Japan to get their input and see if they have come across something similar to you.
Jimmy
FujiRacing
4 Throttle Tuning is offline   Reply With Quote
Old 09-16-2006, 05:03 PM   #3 (permalink)
Ok I feel like an idiot.....
I had four problems as far as I can tell.
1) Fouled plugs. Replaced with fresh NGK plugs.
2) Loose plug wire on #3, turns out the little clips that hold the wires flat against the valve cover, was holding it too tight and it wasn't all the way down on the plug.
3) The rear two throttle's linkage had loosened and they weren't opening the same as the fronts.
4) After fixinf all those it still wasn't quite right, put the cat back on and..........it got much better?!?! I don't really get it but whatever. I'm going to either just go standalone when I get back from a work trip and be done with it. Or I might dry dyno tuning it first with the SUBCON and see how good it can get.
Arg, what a frustrating coupld of days.
1991 Miata
1598cc of fury!!!!!
Old 09-16-2006, 08:20 PM   #4 (permalink)
Moderator
the blue potato's Avatar
What year is your Miata? You using stock 02 sensors?
The Blue Potato / 1995 NA8C Pitcrew #001 / R.S. Aizawa IRTB / RS Watanabe / KG Works
www.thebluepotato.net | http://www.thebluepotato.net/blog/
the blue potato is offline   Reply With Quote
Old 09-17-2006, 09:55 AM   #5 (permalink)
91, and yes its the stock o2.
1991 Miata
1598cc of fury!!!!!
Old 09-29-2006, 09:26 PM   #6 (permalink)
90_mx's Avatar
Reviving this thread...after all the issues you`ve been having, hows the IRTB finally ruinning?
90_mx is offline   Reply With Quote
Old 09-30-2006, 02:53 PM   #7 (permalink)
I'm interested as well.
PS: Is that your miata in your avatar, 90_mx? It's been my inspiration for getting a hardtop. 8)
What has this become...
FooSchnickens is offline   Reply With Quote
Old 09-30-2006, 09:24 PM   #8 (permalink)
90_mx's Avatar
Yup
Old 10-04-2006, 07:12 PM   #9 (permalink)
They are ok, not great. I'm caving and going standalone. I've looked at all the options and decided to go the cheep but harder route and go megasquirt. I'll be ordering it hopefuly this friday when my paycheck hits. It will just be fore fuel to start and then I'll add ignition. It means my car will be down for awhile but in Colorado we'll start getting snow this month and thats a good time to have it parked in the garage as any I suppose.
They work ok with the subcon, but there are some quirky areas, like accelerating out of a corner after heel and toeing that it just boggs. I think that its not powerful enough to alter the factory maps enough to deal with every part of the rpm range.
The real downer is that all the issues I had made my bumper really bad, I think it may be stained permanently in some areas. I was planning on having it repainted someday, since the Mazda white is supposed to be crap anyways. We'll see, I'll have it detailed after I get the fueling perfected with Megasquirt and see if they can get it to go away.
I still would recommend Jimmy's kit, but I'd say get one of the standalones he offers or somethig similar. His customer service is top shelf and the kit itself is very very well made.
I also wonder if part of my probelm is that I live at 5500ft and the piggyback can't get it lean enough considering the thin air.
1991 Miata
1598cc of fury!!!!!
Old 10-04-2006, 07:35 PM   #10 (permalink)
Try using a clay bar on the bumper. It should take the soot off.
driver of the white 95
moto_bruce is offline   Reply With Quote
Old 10-04-2006, 08:48 PM   #11 (permalink)
Hmm I'll go get one and try it!
1991 Miata
1598cc of fury!!!!!
Old 10-04-2006, 08:48 PM   #12 (permalink)
Sponsor
Just put a call in to Japan to find out about the subcon in the 5500 ft. elevation with their customers. The person I always talk to doesn't come in until 13:00 today. In this past year our kits have been run with the subcon(Piggyback), AEM on a S2000, Hondata on a Civic, & the Freedom. All of them run on the rich side. Another customer will be using the MicroTech & I hope that they can make it work. My bumper is also black.
Jimmy
FujiRacing
Old 10-04-2006, 09:06 PM   #13 (permalink)
Mufasa in Training
Bryan's Avatar
Jimmy, is the Microtech the AEM unit you're offering now?
Originator of OEM Plus™
That's a really bromantic dream; miatas, fishing, Bryan... Does it get better?
Bryan is online now   Reply With Quote
Old 10-04-2006, 09:29 PM   #14 (permalink)
Sponsor
Hi Bryan
I now offer the MicroTech & AEM. MicroTech is wire & play with an integrated MAP sensor. AEM is a plug & play. I still haven't decided if I will go with MicroTech or AEM for my car. I will know in about a week & I hope to add technical information on both the AEM & MicroTech to my website.
Jimmy
FujiRacing
