| Engine Swaps! - *Sponsored by V8Roadsters.com* V8, V6, Rotary, and any other engine swap info is in here! |
#1 (permalink) |
Supporting Member #5522
what should i do? i have a 91 1.6 with 190xxx on it i think the rear main seal is leeking. and needs rebuilt any ways, so its going to come out. how ever its my DD. i do have an extira 1.6 short noes that i can probly pun in it while its out, so what should i do rebuld it, 1.8 swap, low mile 1.6. dont have a lot of money starting collage in 5 days
what would it take to put in a vvt? thank you |
#5 (permalink) |
If it is the rear main seal, i would do like the rest are saying and drop the tranny and clutch bits, and do all of that at the same time. If you have a good 1.6L, you could drop both the old motor and trans, seperate them, replace the clutch and all its goodies, then attatch the new 1.6L, and reinstall. We could do it at my shop in about a day.
#6 (permalink) |
if i dont replace this engine. i will replace all the seals i have a stage 1 racing clutch so that will stay. and i need new moter mounts and will probly do t-belt and water pump what elts should i do?
#7 (permalink) |
that should be pretty much all you need. The biggest thing to think about is, if the rear main is leaking bad enough it can begin to soak into the clutch disc. But if you arent experiencing any clutch issues, you should be fine.
#8 (permalink) |
You're talking about a full re-seal job. You should also replace the following:
- Valve Cover Gasket - CAS O-Ring - Cam Seals (2 of them) - Crank Seal - Water pump gasket and O-ring (this will come with your new waterpump) - Rear main seal (will need to remove transmission for this) I don't think you'll need a rebuild and a 1.8L swap would only be suitable if you want to spend the money for a different motor and a bit of extra hp. As long as your car isn't smoking everywhere (ala headgasket, piston ring failure, and etc), I don't think a rebuild would be necessary or even cost-effective. Unless you're planning to rebuild everything to a certain spec (ala Spec Miata series), it just doesn't make sense for rebuilds on Miatas - the motors are so cheap anyways. I say....seals, timing belt, water pump, and gaskets.......and you're good for another 50-100k miles on that motor as long as your compression is still up to par (that reminds me.....go do a compression test to see if your motor is healthy). |
1993 Miata (NA6CE): Integral Stage 2 cams, MSPNP9093, Bride VIOS III, H&R Race springs, Tokico shocks, Konig Rewinds, Header, Midd-Tenn Headlights, Mazdaspeed Test Pipe, Back to stock exhaust |
#9 (permalink) | |
#10 (permalink) | |
#12 (permalink) |
I have the ability to do all that stuff at my shop. For the compression test I will only charge you $20. If you want to do all the seals we would have to talk about price and stuff, but I can get all your seals and stuff at cost and pass that savings onto you so you don't have buy some crap ebay parts.
#13 (permalink) | |
i would love a gestament on what it would cost on laber. but the problem is im relly impatient when it comes to some one elts working on my car. im starting school tusday and betwen school and work. i will have no days off and its my DD. but at the same time when my car was an auto and i had the trany rebult. i said, i would never let anyone work on my car. i do trust you. at the sametime i wont to do it my self, let next week roll around, if youn can get a gestament on laber i most likely have you do it. |
#17 (permalink) |
Beeeeer!
relly?
#18 (permalink) |
Ninja Messiah
the seals, timingbelt, waterpump, etc all all relatively cheap. i think timingbelt.com(?) has decent prices.
i think what you are going for is a reliability in the car because of school. it's a good idea. the rear main isn't hard to do, it's just a lot of labor. you would want to do this irregardless if it's your engine or a newer one. something else i would strongly consider is to replace ALL the coolant hoses, including the little ones. THIS can be a *little* expensive as the tiny ones are dealer only, i think, but it will mean you really shouldn't have to worry about much else unless you are flogging the car. with all this, you'll be flushing the coolant. i would also recommend buying about 10 ft of tubing and replace all the vacuum hoses, maybe less if you don't have cruise control. everything i mentioned is probably $300 or less if you shop the parts around online. this can all be done in a weekend or two with some help. as for the compression, you might be able to rent a tester and do it yourself. here's what you should consider for parts: WP WP seal WP o-ring idler pulley tensioner pulley 2 cam seals 1 crank seal timing belt VC gasket rear main seal CAS seal for coolant: upper main radiator hose lower main radiator hose both ACV hoses (the ones that goto the top of the intake manifold) both IAC hoses (these reqiure removing the throttle body to get at, but when they split, they will bleed a LOT of coolant in a hurry) new thermostat thermostat housing seals 10 ft (give or take) of rubber vacuum hose TB gasket coolant radiator cap things to consider: spark plugs spark plug wires PVC valve fuel filter flush clutch master flush brakes |
I ♣ baby seals. |
