turbo 2 rear install? - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Engine Swaps! - *Sponsored by V8Roadsters.com*
Engine Swaps! - *Sponsored by V8Roadsters.com* V8, V6, Rotary, and any other engine swap info is in here!
Old 09-30-2009, 06:28 PM   #1 (permalink)
silverslider's Avatar
Default turbo 2 rear install?
Is it true that the rx7 turbo 2 rear are all limited slip and will fit without modification? (In a 96 NA). And is the rear stock strong enough for light to moderate amounts of drifting.
Sorry for not using search but blackberrys are so freakin slow
silverslider is offline   Reply With Quote
Old 09-30-2009, 10:20 PM   #2 (permalink)
Rare Parts Hoarder
Phatmiata's Avatar
Default Re: turbo 2 rear install?
not sure but i think V8 Roadsters was making a kit for that swap?
No Roadster, No Life!
Phatmiata is offline   Reply With Quote
Old 10-01-2009, 10:01 AM   #3 (permalink)
dark_dementshun's Avatar
The TII diff is what i am running in my LS1 miata right now. The rear portion bolts into stock location and you have to make a mount for the front. Not too hard at all. A lot of the older ones seem to slip some with age, but can be rebuilt tighter than from the factory. Also, if you are making too much power for it stock, you can always plop in a KAAZ 1.5 way and call it a day. The main downside is the lack of gear options.
dark_dementshun is offline   Reply With Quote
