| Engine Swaps! - *Sponsored by V8Roadsters.com* V8, V6, Rotary, and any other engine swap info is in here! |
#1 (permalink) |
I'm an engineering student at Texas A&M. I'm involved with our local chapter of the Society of Automotive Engineers, and we're building a car for the $2011 (originally 2010, but eh, such is life) Grassroots Challenge.
Here's what we started with: A '92 Miata shell. Most of the suspension, and a few misc. interior pieces. ![]() We stripped it down, cleaned it up, and began to figure out where this engine was going to go. ![]() This is a lot of engine for a Miata. At this point we realize exhaust and intake manifolds are going to be custom. ![]() We're running a 7" Viscous LSD out of an FC 'vert. ![]() Here's a picture of the good engine sitting in the bay with all its parts still attached. Space is going to be at a premium. ![]() Engine mounts shouldn't be insane, though. ![]() Combined with the VG30DETT transmission, this is going to be quite a lot of powertrain for this car. ![]() Hardpoints added in the tunnel for transmission mount: ![]() Suspension is some old KYB AGXs with GCs. Those aren't our final springs. ![]() Fairly large intercooler to help keep the Turbonetics T3/T04E in check, required replacing the crash bar with a length of tubing. ![]() We're running an aluminum CRV radiator directly behind that bar, about an inch forward of the OEM location. Everything fits in the stock bumper with very minor modifications. ![]() Our exhaust primaries are going to be made out of galvanized fence pipe, cut into pie sections and acid-dipped in pool acid to remove the galvanizing. Flanges and a few miscellaneous bends came from a VG30DE header. ![]() Our good engine is currently apart and awaiting new rings and a good cleaning. ![]() The best part about all of this is we're all undergraduate engineering students, and we're doing this for less than $2011. |
#2 (permalink) |
epic!
I need to get my subscription renewed lol more pix/vids the better for this thread |
My sig is not worthy The Anti-Style Bar Empire - Saving Lives since 2010 2001 SE 398/3000 http://ilmadikz.tumblr.com/ |
#6 (permalink) |
I love V6 swaps. I prefer the KLZE (keeping it in the family allows you to run SCCA SM) but that Nissan motor should be fun for GRM Challenge. I think the VQ is even better but is undoubtedly out of your price range. In N/A form the VG shouldn't be too much trouble to work on. Good luck!
#7 (permalink) | |||
That's the same reason we didn't go with a VQ. The aluminum block would have been nice, but the EMS options were too expensive when stacked up to the rock-bottom prices of the VG30E. That, and the VG30DE and VQ35DE have massive DOHC heads. If you look at the pictures, there's not much room even with the small SOHC 12V heads. No way we could fit two more cams in there WITH a turbo manifold. |
#9 (permalink) |
brontosaurus
Awesome. As a student who plans on getting into engineering this really excites me. I am looking forward to seeing this project through. Projects like this are my inspiration to get through school.
#11 (permalink) |
Speed Racer
in for updates!
_Jess_ 1991 White Mazda Miata DD 1991 BRG Mazda Miata ![]() LS6 swap coming soon http://clubroadster.net/vb_forum/89-roadster-projects/33687-91-brg-ls6-build.html |
#12 (permalink) |
Going up the Country
wow. This is a neat project. With all that power and Iron block, are you considering ballast weight? This is thinking pretty far ahead, but given the power potential, ballast weight in the trunk might be useful.
#16 (permalink) | |||
We'll probably get creative with component placement, etc. I'm not too incredibly worried, though, as the transmission and diff are a bit heavier than the Miata pieces, and the motor's actually not that much heavier than the iron block BP.Quote:
![]() Detonated at 25psi and 5.5K RPM and we didn't even have time to react; that was all she wrote. That's racing, I guess. Quote:
Thanks. We love it too. We better, as much time as it takes. |
#19 (permalink) | |
Note the snail hiding in the 3rd picture and the large intercooler on picture 10 |
#20 (permalink) | |
Bingo. That's a Turbonetics T3/T04E with a 11"x17"x2.5" intercooler. Based on the compressor map I found (60 trim), that turbo is capable of flowing over 1000CFM at 25 psi and still be 78% thermally efficient. Based on previous VG30 builds by Maxima and Z31 guys, 400hp with a stock bottom end and stock cams is not unreasonable. There's a guy with his dyno sheet on redz31.net who hit 450hp/485lb.ft with a slightly reground cam, everything else identical to our build. This thing's gonna boogie. |
#22 (permalink) |
Herpity Derpity
Wait, maybe I dunno how the contest works. But how are you only doing all this for $2011?
#24 (permalink) | ||
#25 (permalink) |
Do yourself a favor and keep tabs on all your mock-ups. You might even want to patent any custom made pieces like mounts. If the project is successful, others will likely be interested in the parts to make it work down the road. Good luck. I can't wait to see this thing finished.
#26 (permalink) |
Thanks. There are a few companies that have offered some advice I would love to work with after the fact to improve this setup and make it more marketable.
I know the car's not done yet, but even this far along, I still fail to see any reasons why this wouldn't be a viable swap for more "normal" purposes. The NVH and livability would have to be addressed, but it's something I'd LOVE to consider post-graduation. |
#27 (permalink) | |
Finger lickin' good...
Andrew - '98 Honda Superhawk - '88 Yamaha YSR50 - "Play Thing" - '78 Honda CB750F SOHC SuperSport - "Lucky 13" |
#28 (permalink) |
Do you know a kid named Corbin Maginot? He goes to the same school as you, is way into miatas, and works on a ton of them for friends and stuff down there. This seems like something he'd be involved with.
#29 (permalink) | |
Yes, Mr. Prescott, actually, he's my roommate. I'm the reason he's into Miatas. |
