| Engine Swaps! - *Sponsored by V8Roadsters.com* V8, V6, Rotary, and any other engine swap info is in here! |
#31 (permalink) |
Herpity Derpity
So my cousin has a f20c and another f22c motor sitting in his basement that he's been collecting for parts etc for his own s2k. Opinions, which is better for the swap? What do you think each one is worth individually? (both low miles and have trans) I personally like the f20c w/ 9k redline over the f22c with minimal difference in power and only 8k redline.
Plus correct me if I'm wrong but if you did a f22c swap in a miata does that mean it would have to be drive by wire? Or was drive by wire only on the later model s2k's with f22's? |
#32 (permalink) | |
I don't have bad days
The F20C cars have more loose ring clearances to aid the 9k RPM capabilities. These motors burn oil, no way around it. 1 quart every 1000 miles is perfectly acceptible per Honda's guidelines. Yet, I have seen many s2000 owners who change their oil every 5k miles. In addition many motors that failed from oil starvation. Not only do you have to monitor the oil level, but my oil will be pretty dark by 2200 miles (on my daily driver), which is around where I typically change it. Plus, there is a reason why you don't see many engines coming from the factory that spin to 9k. There are trade offs that come with that high of RPM. My car now has 93k and is still going strong. |
1999 NB8C, TWM ITB's, Adaptronics, Maruha Header + Cams, Advan RG II's, 4.77's, 172whp 1994 NA8C, SCCA Spec Miata Race Car, 106whp 1991 NA6C, Turbo, Flares, Tein Flex, MSPNP, Work Equip 01's, Retro Goodness, 254whp 1993 FD3S, SP 13b, T04S 60-1, Haltech, V-Mount, 99 Spec Aero, RPF-1's, 417whp 1993 FD3S, SP 13b, T04S 60-1, V-Mount, RE-Amemiya Widebody in progress 2003 AP1, AP2V1 Wheels, Kuhmo XS, Daily Grind and 1993 Suburban K1500, The Lump |
#33 (permalink) | |
I installed Krank Vents on my F20 and it took care of my oil burning issues. I used to use almost a quart or so every 3,000 miles, but now its not really noticable. My Type-R burned a lot of oil also, but never installed the Krank vents to see if it helped. |
1992 Miata w/ 2002 F20C swap. Comptech Supercharger/ aftercooler, 95 Diff w/LSD. Other stuff too... http://www.youtube.com/watch?v=cMWpb8wq9qg |
#34 (permalink) |
Interesting. Do you have a link with some more info on these specifically for the F20? Their website doesn't say much for vehicle specifics.
#36 (permalink) | |
I used to own Twin Turbo 3000GT and had the same problem. Would actually smoke out the exhaust on deceleration. Fixed the oil burning. Its worth the $100 to me. |
#37 (permalink) | |
Kicked off the island..
My 5.0 miata build: http://tinyurl.com/cv329ly |
#38 (permalink) |
Im thinking of doing the same swap, but I was thinking of buying a new K member and doing the swap to it. When I have everything ready, then drop out the old K member/engine/trans.
#40 (permalink) |
brontosaurus
Lol. I think you need to think about that some more.
The easiest part of the swap will be getting the actual motor mounted. What about trans placement, exhaust routing, the wiring harness, intake plumbing, driveshaft fitment, etc? That all needs to be done engine in car. Your subframe idea is required, how else would you fabricate the mounts? That's only one step of a hundred. |
#42 (permalink) |
i have 2 s2000s, a 95 miata r package daily, and an ae86 coupe with no motor.. with an f20 complete swap sitting... waiting for a new engine bay to sit in.. should i scrap the corolla and go miata? lol.
#43 (permalink) |
miata has a better layout...sorry but it does im next in line for a f22c swap
....BayAreaRoadster.... Now, me and the mad scientist got to rip apart the block... and replace the piston rings you fried. |
#44 (permalink) |
i love the corolla coupe tho.. i wish i had the time and money to swap an f20/22 into all the underpowered cars that i love lol. eventhough i just blew my first f22 after about a year and a half of track duties...
#46 (permalink) |
looks like the bearings on the connecting rod
#47 (permalink) |
i was on the s2ki forum when i owned mt s2k and it was a solid motor from what i read. most guys runnig gt3071r and putting out 370-over 400whp on stock internals just a 3mm head gasket. those cars have very aggressive gearing. in the ap1 you have the 9k redline but in the ap2 you get shorter gearing form 1-4 along with the bigger engine and more torque. (8lbs of torque more) not alot but the 1-4 shorter gearing and extra bit a torque make it much more drivable. i didnt believe this untill i drove them back to back. love the way s2ks look. the styling does not look dated. when my motor blows from the 16psi or i just get tired of the miata ill part it or sell it and pick another one up.
#48 (permalink) |
I really don't see the point in this swap. A stock S2000 makes about 192/131 to the wheels, and for most of that time makes piss-poor torque. It's an exciting sound, sure, but not really fast enough to be worth the effort. A 1.8 with a GT28 will make 250/210 with a much broader torque curve and way more area under the curve, and would be cheaper and less labor intensive. I wouldn't call an F20 unreliable, but as has been stated there are dissadvantages to revving to 9k RPM, and they don't outwheigh the powerband results in my opinion. Overall it was a failed experiment for Honda.
#52 (permalink) | |
EDIT: Anyway back to the actual topic, the F20 to me is an entertaing power plant and engineering wise is pretty cool. What it lacks is usability and outright power, despite being so high-strung I was never impressed with the speed of it. If you have an S2k, you can do FI to make up for its shortcomings, if you have a Miata, you're still going to have to make up for those shortcomings after you do all the work of swapping it. I'm not saying no one should do it, by all means its cool to have something unique and to overcome the challenge of putting something where it was never intended to go (did that myself). But the F20 just isn't an inherently desirable engine to me. |
#53 (permalink) |
Judging from your previous post, you were talking about the performance of the F series engine.
We're not talking about sales figures, we're talking about the potential of the F20C/F22C swap into a Miata used for racing. The S2000 also did very, very well in motorsports and the engine itself is a very good platform for tuning. I like the BP-ZE for what it is, but in your case, a turbo F20C > turbo BP. |
#54 (permalink) | |
As far as for use in a race car...well, no one besides you just now has yet mentioned that in this thread, so that's not at all what I'm talking about. I think it would be quite well suited for racing, so we're in agreement there... |
