91 manual trans into a 97 auto swap. - ClubRoadster.net
Go Back   ClubRoadster.net > POWER & PERFORMANCE > Engine Swaps! - *Sponsored by V8Roadsters.com*
Engine Swaps! - *Sponsored by V8Roadsters.com* V8, V6, Rotary, and any other engine swap info is in here!
Old 08-13-2011, 09:51 PM   #1 (permalink)
bipple91's Avatar
Default 91 manual trans into a 97 auto swap.
Hey guys, will a 91 manual trans work on a 97 model? I'm thinking about getting a 97, but its auto and I already have a 91 miata trans laying around. Another thing is will the automatic ECU from the 97 still work with the manual trans and what things should I remove from the wiring harness?
bipple91 is offline   Reply With Quote
Old 08-13-2011, 10:03 PM   #2 (permalink)
Always Useful Sometimes.
thedguy's Avatar
Default Re: 91 manual trans into a 97 auto swap.
Yes, but the 94+ transmissions are supposedly a little stronger and have better syncro's on 2nd gear.
I wouldn't fuck with the wire harness or ecu. Throw in a clutch pedal, change the pedal box for the brake/gas, install clutch hydraulics, clutch/pp/flywheel, transmission, manual trans ppf brace and driveshaft.
I wired the electronic parking lock to be permanently disabled (just tied them together) rather than trying to run the wires back to the clutch switch. splice in the reverse lights you should be good to go.
That's how I did it with a 94 trans in my 90auto
Originally Posted by hhsohn View Post
You actually have the right to be a douchebag and an idiot, but it's not wise to exercise those rights.
thedguy is offline   Reply With Quote
Old 08-14-2011, 09:24 PM   #3 (permalink)
bipple91's Avatar
Thanks man very useful! And so that should mean the automatic ecu will work eith the manual trans right? Thanks again!
Tags
swap, transmission
