Blackbird Fabworx Door bars retrofit - Now available! - ClubRoadster.net
Go Back   ClubRoadster.net > JUNIOR SPONSORS
Old 07-18-2011, 10:01 PM   #1 (permalink)
Junior Sponsor
Blackbird's Avatar
Default Door bars retrofit - Now available!
Finally, the modification that sooo many of you folks were asking about is available!
I can now retrofit door bars to your existing rollbar without the need to remove the rollbar from the car which saves a lot of work, which in turn means that you save $$$.
The cost of the retrofit is about $400-500 depending on setup, actual price may vary if you have different seats or requirements, etc..
For that price you get a proper set of door bars welded to the rollbar main base plates and bolted to the front receivers that are welded to the car.
The finish is satin black paint to match the standard color of most other aftermarket rollbars.
Compare the price to a set of doorbars from other vendor where you pay almost $300 plus shipping and you still need to install them yourself or pay a shop, and you end up with an inferior product that attaches to the flimsy sheet metal of the floor...
The Blackbird Fabworx doorbars work much better because they attach to the rocker, where much of the strength of the chassis comes from.
Here's what Inside Line magazine had to say in a recent review of the Blackbird Fabworx door bars -
Originally Posted by Inside Line
That suspension works even better now that Project Miata's chassis stiffness has been fortified by the GT3 6-point roll bar. I'll go so far as to say that the car has been transformed by its presence, with the brunt of the credit going to its door bars. Much of the secondary jitteriness the body shell had while traversing bumps is now gone; the whole thing drives more all-of-a-piece. It now goes down the road like a fundamentally much more serious and capable car.
There's more. Project Miata's ride quality is notably more supple due to the roll bar. Inputs from the road can actually be damped out by the suspension, rather than simply being transmitted to the previously noodly (and undamped) chassis. Whether increased chassis stiffness improves lap times is one of those endless internet debates, but consider this -- allowing the suspension to work better results in more uniform contact patch loading when traversing lumpy pavement. It also makes for a much more confidence-inspiring (and pleasant) drive. Confidence is speed.
Here are some pics of the doorbars on the BFW 6 point rollbars -
Get your set of door bars - moti@blackbirdfabworx.com
Moti
Blackbird is offline   Reply With Quote
Old 07-18-2011, 10:07 PM   #2 (permalink)
atlnb's Avatar
Default Re: Door bars retrofit - Now available!
Looks very nice
Originally Posted by aarrowadscom View Post
That is in fact, non oem spoiler that came as a factory option on NB1, and offered as an aftermarket piece on NB2 available from the dealer.
Xida CS, Hard Dog, Corn*s, Bride, Carbing, Joyfast, Beatrush, 6UL, KG Works, Square Top Manifold
atlnb is offline   Reply With Quote
Old 07-18-2011, 10:14 PM   #3 (permalink)
Ninja Messiah
kung fu jesus's Avatar
Do want.
I ♣ baby seals.
kung fu jesus is offline   Reply With Quote
Old 07-18-2011, 10:21 PM   #4 (permalink)
Junior Sponsor
Blackbird's Avatar
Originally Posted by kung fu jesus View Post
Do want.
Give me a call, you can have them done before the GW tech day.
Moti
Old 07-19-2011, 12:00 PM   #5 (permalink)
Junior Sponsor
Blackbird's Avatar
Just wanted to add that the door bars are available in various diameters and thicknesses to suit your needs.
Moti
Old 07-19-2011, 05:41 PM   #6 (permalink)
jux
Mostly Harmless
jux's Avatar
want want want!!
This might sound really really odd, but...
...do you (or have you thought about) travel for installs?
You know, for those of us not exactly close enough to drive over and have bits welded in place.
I know there'd be a whole mess of logistical crap to deal with as re: pipe, bends, a welder, a location and whatnot, but I'm really curious.
'90 "LE" with red bits - 7/6 Flex, FM Front Bar, 14x7 +19 RPF1, PWR, SPAL, Maxim Works, Thermal R&D, HDHCSDM2, Zoom, Anvil II, 330mm Walnut Deep Corn, AC/PS delete, LE interior, attitude
VVT swap coming soon
jux is offline   Reply With Quote
Old 07-19-2011, 06:21 PM   #7 (permalink)
etikoner's Avatar
Seriously, have a bunch of us fly you down and you get like 5 cages done in a shot
Quality stuff, maybe someday I'll spring for it.
etikoner is offline   Reply With Quote
Old 07-19-2011, 09:55 PM   #8 (permalink)
Junior Sponsor
Blackbird's Avatar
Originally Posted by jux View Post
want want want!!
I've never really thought about it.
As long as I'm busy here, there's really no reason for me to travel for installs, unless there was a really tempting offer to get me out and about.
But then there really is a boatload of logistical stuff to be taken care of, to start with I'll be away from all my tooling and my shop is fairly equipped so...
Moti
Old 07-19-2011, 10:08 PM   #9 (permalink)
AARP's Avatar
Awesome work Moti!
Originally Posted by Mr.Woolery View Post
Then they said okay, followed me home, and we had a three way. They both sucked my dick. Bitches.
AARP is offline   Reply With Quote
Tags
6 point, blackbird fabworx, door bars, gt3, inside line
