Full-detailed tuck/delete write-ups for NA's! - Page 12 - ClubRoadster.net
Old 11-11-2010, 12:49 PM   #331 (permalink)
adore's Avatar
Default Re: Full-detailed tuck/delete write-ups for NA's!
Originally Posted by demoniam View Post
holy hell.
I am not so shure about hell being holly, but Thanks
adore is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 01:19 PM   #332 (permalink)
chricto's Avatar
I'm hoping you have or are going to start a build thread for that thing.
...Come on NB owners. Lets make this happen.
chricto is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 03:07 PM   #333 (permalink)
adore's Avatar
please read to post up
Old 11-11-2010, 03:21 PM   #334 (permalink)
Please sir!!!!!
roboticmiata is offline   Reply With Quote Quick reply to this message
Old 11-11-2010, 03:34 PM   #335 (permalink)
chricto's Avatar
Ha, missed that. Thanks.
Old 11-14-2010, 03:48 PM   #336 (permalink)
shlammed's Avatar
Started my tuck.... will look similar to Adore's setup.... with no maf..
Also getting a brake line tuck if i get the time...
shlammed is online now   Reply With Quote Quick reply to this message
Old 11-24-2010, 07:15 PM   #337 (permalink)
kewilso3's Avatar
My "tuck" as it stands... the only wires cut/extended are the two running to the FPR and the two going to the IAT sensor for the Megasquirt. All wiring is tucked under the lip of the fender, still inside the bay but mainly out of sight. It is routed under the headlights from there. I still need to route the hood release cable behind the light. Injector wiring is under the rail and the FPR is moved to the rear of the IM. EGR is gone in addition to the obvious things. I really want to put the filter in the bumper for a cleaner look but it would be a ton of work not worth it I think. And I HATE that stupid blue intake elbow...
Anyone have any solid reason not to get rid of the stupid rubber caps on the headlight adjusters? Or has anyone removed that whole manual mechanism? I cant use it anyway because of the low-pro's
1994 black and tan, 1.6 dash, hardtop, single diag rollbar, stance GR+, low-pros, frame rails, r-lip, MS2 standalone, lc-1, sparco speed, absurdflow/gt2860/3"dp/2.5ex, ic, fm clutch/10lb fw,etc...
kewilso3 is offline   Reply With Quote Quick reply to this message
Old 12-19-2010, 10:26 PM   #338 (permalink)
RedMX5's Avatar
Originally Posted by maciag View Post
just letting you guys know that I have been working on write up's..
it might take a while.. i have a lot of other stuff goin on with the car too (i've been working on other crap with the car recently including power windows, power locks, alarm off my older NA, rollbar, new trims, rspeed rear panel, fuel pump, new soft top, putting in my 330mm nardi wheel + hub, new csf rad., waterpump, advancing timing, oem fogs, mount/balance & powder coat new wheels, sport brake swap (still haven't even started this), other crap with cooling system, and still planning to fix my heater. please also keep in mind i have a full time work and school schedule too... haha
I would really like to put power windows/locks in my 96.. how difficult is it? i've found that the power switches are underneath the center console.
RedMX5 is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 02:34 PM   #339 (permalink)
mighty mouse's Avatar
has anyone found a source for a rubber grommet to plug up the existing firewall holes from where the wiring harness passes through?
Miata 298.6whp - 270ft/lbs - 8500 RPM
GC8 320 awhp - 295 ft/lbs- 8250 RPM
Build Thread:
Daily Build:
mighty mouse is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 03:56 PM   #340 (permalink)
I just used the one that was already there and filled the hole where the wire was with a rubber patch and some silicone.
TFMMC is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 04:51 PM   #341 (permalink)
I'm actually going to be relocating them, so I can't do that. I'd like something a little more factory looking as well.
Build Thread:
Daily Build:
Old 12-20-2010, 06:38 PM   #342 (permalink)
Relocating what? And how can you get more factory than stock? I'm confused. o_O
Old 12-20-2010, 08:29 PM   #343 (permalink)
Speed Racer
XCLR8TN's Avatar
Originally Posted by jdmv8 View Post
Would anyone care for a complete DIY brake line tuck? I started mine and have tons of pictures and a complete part list.
I also have a complete DIY with part list for a wire tuck. The only issue with my DIY is its for my LS1 Miata so I deleted pretty much everything.
Let me know!
in for parts list and pics.
Originally Posted by midnitehour View Post
Because to get rid of ABS i'd have to get a new prop valve. Also i'd have to figure out the wiring harness
Hm. I get to do this :/
I talked to Chase Bays today and they offer a booster delete for the Miata. The booster delete kit is $215.00 shipped and includes everything needed to install it.
They also said they will have a brake line tuck kit coming out soon. I said something about a group buy and they sounded interested.
This sounds nuts. I don't know about deleting the power brakes, lol. Wondering what route you went since you gave up contacting them, though.
And that wilwood setup is nuts too
_Jess_
1991 White Mazda Miata DD
1991 BRG Mazda Miata
LS6 swap ...SOON
XCLR8TN is offline   Reply With Quote Quick reply to this message
Old 12-20-2010, 09:46 PM   #344 (permalink)
I'm reusing the firewall grommets, just moving them elsewhere in the car, hence the relocating
I would rather find something like this:
Not just a factory wire grommet filled with caulking... that's not "OEM"
Build Thread:
Daily Build:
Old 12-20-2010, 09:52 PM   #345 (permalink)
And a wire tuck is OEM?
Just weld them shut lol.
Old 12-21-2010, 11:43 PM   #346 (permalink)
Mid-wire tuck. Finishing off the driver side tommorow and then tackling the pass side. The only think I will do differently is I won`t bring the wires into the cabin and drill an extra hole like I did on the driver side. Rather keep the fuse box as the only think in the bay and route the wires through the already existing hole to the fender area.
falcon is offline   Reply With Quote Quick reply to this message
Old 12-22-2010, 06:23 PM   #347 (permalink)
Has anyone here completley removed the diagnostic box? I never use it, or see the need for it in the future. I've so far fully removed the MAF connector (aside from teh two wires I need for air temp sensor, running MS), the brake fluid level sensor, the blue connector for helping set timing (+ wire) and a few other things.
Since I don't use the dianostic box and with the MS, it's fairly useless, I want to just cut it off and seal off all the ends of the wires from water. Do any of these wires ground anything else? Or work in a fully system where if you were to remove the box part of the wires (where the terminate) that it would cause anyting else on the car to stop working?
Old 12-22-2010, 06:26 PM   #348 (permalink)
Oh, and I'm having a hard time finding a rubber gromet to use for my new 2'' hole I drilled as well as a solid rubber 2.75'' plug for where the wires used to come out. Any ideas?
Old 12-22-2010, 07:15 PM   #349 (permalink)
If you have MS I don't think you need many wires at all... pretty sure the diagnostic box can go too but I'm not sure. Its not like they're leads to anything else, they all dead end in the box.
Old 12-22-2010, 07:28 PM   #350 (permalink)
I did
But I realized I cut off my resistor to make the tach work... now I have to find it in my mess of wires on the floor.
My driver side will basically ONLY be the lights and one relay.
Does anyone know what the blue relay is that's under that black box in the drivers side of the bay, right next to the clutch slave cyl?
Old 12-23-2010, 04:59 AM   #351 (permalink)
vindi49's Avatar
Good thread this, I'll try to do as much of this as I can to my Wataru.
As for all the holes, I'm all for welding them shut along with removing all the brackets you're no longer using... it somehow ruins it to delete all the wires etc, and have a load of random holes, brackets and stuff sticking out for no apparent reason!
Russell.
1992 Eunos Roadster V-Limited : More and more DIY, less and less JDM
1995 Pitcrew ... about as JDM as you can get!
vindi49 is offline   Reply With Quote Quick reply to this message
Old 12-23-2010, 05:00 PM   #352 (permalink)
Well unfortunatley I am not going to be welding anything in the near future.
And I still can't find a 2'' grommet for the new hole I drilled to pass the wires into the fender area.
Old 12-24-2010, 02:12 AM   #353 (permalink)
Drivers side done. And yes, everything works I checked. I couldn't figure out where to route the hood pop, so it's kind of down the middle. But I don't mind.
Pass side fully underway. The most difficult part of this is going to be getting the TPS, water temp sensor and a my COP harness routed descretley.
Old 12-24-2010, 02:34 AM   #354 (permalink)
sidvv's Avatar
i got a noob ? if i remove my charcol canister will that effect my emissions?
sidvv is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 02:54 AM   #355 (permalink)
not any kind that actually get tested.
Old 12-24-2010, 03:11 AM   #356 (permalink)
sidvv's Avatar
What you mean?
Old 12-24-2010, 11:14 AM   #357 (permalink)
Speed Racer
XCLR8TN's Avatar
Falcon, pop the cable out of the hood latch and re-route it right along the inside of the fender (inside of bay). There's a reinforcement attached over there for the headlight bucket assembly, if u run it in between that and the fender it keeps it along the side, then run it under the headlight and back over to your latch and re-attach it. That's what I did and you couldn't even see the cable at all.
Here's the cable, running thru the turn signal housing opening.
And you can see it running next to that assembly, right beside the headlight:
_Jess_
LS6 swap ...SOON
Old 12-24-2010, 12:42 PM   #358 (permalink)
garageSTAR Supporter
jdmfc3s90's Avatar
Californians, yes, it will effect visual check for smog. As for actually emissions i dont think so. Theres a write up for this, you should check it out.
Visit-
jdmfc3s90 is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 01:22 PM   #359 (permalink)
//banned
phillyb™'s Avatar
just removed the windshield wiper fluid reservoir...
what do you guys do with the electrical connector that was connected to it?
this guy
phillyb™ is offline   Reply With Quote Quick reply to this message
Old 12-24-2010, 03:16 PM   #360 (permalink)
kewilso3's Avatar
tuck it away behind the fuse box, i put little bags over my connectors and taped them up
