Full-detailed tuck/delete write-ups for NA's! - Page 23 - ClubRoadster.net
Old 04-03-2012, 11:34 AM   #661 (permalink)
nperkins's Avatar
Default Re: Full-detailed tuck/delete write-ups for NA's!
Originally Posted by Mr. MattMan View Post
sooo much room in the bay now..
I know I asked in your build thread, but I figured i'd be rude and ask here too... Any more pics of your coolant reroute? Curious about the back of the head and if its possible to do with the motor in the car...
nperkins is offline   Reply With Quote
Old 04-03-2012, 11:41 AM   #662 (permalink)
Boostedmx5's Avatar
Everywhere I have read about reroutes, they had to pull the motor.
Boostedmx5 is offline   Reply With Quote
Old 04-03-2012, 01:24 PM   #663 (permalink)
Mr. MattMan's Avatar
nope... i made a front block off.. (or u can use a 30mm freeze plug) and used the front housing in back... put thermostat directly in head and ran coolant hose from it. I got a buddy club sensor block, and drilled and tapped for the water temp guage and then wired fan to ignition..
Team V2lab_____ Sponsored By Rev9 Autosport & D2
Caged_Tucked_Manual Brakes_JenveyITBs_Megasquirted
My never ending and always changing build thread. http://clubroadster.net/vb_forum/89-roadster-projects/56935-mr-mattmans-build-thread.html
Mr. MattMan is offline   Reply With Quote
Old 04-03-2012, 01:34 PM   #664 (permalink)
Boostedmx5's Avatar
You wired your fan to the ignition? So now its going to run at all times Key On Engine ON?
Old 04-03-2012, 01:39 PM   #665 (permalink)
Yep
My never ending and always changing build thread. http://clubroadster.net/vb_forum/showthread.php?t=56935
Old 04-03-2012, 01:41 PM   #666 (permalink)
Boostedmx5's Avatar
Won't that greatly decrease life of the fan?
Old 04-03-2012, 01:43 PM   #667 (permalink)
Im not wories about a 30$ slim fan
Old 04-03-2012, 01:44 PM   #668 (permalink)
Boostedmx5's Avatar
Won't this cause your engine to maybe run too cold?
Old 04-03-2012, 01:50 PM   #669 (permalink)
nperkins's Avatar
Wait so that's it? No spacer needed? No modifications to the neck to be able to bolt it? Just:
- Remove Water Neck from Front
- Install Block off Plate on Front of motor
- Remove Block off Plate from Back of Motor
- Install Thermostat into back of motor
- Install Water Neck from front
- Run coolant hose / water pipe from back of motor to radiator
- Install Buddy Club Sensor block somewhere in the middle
I'm guessing the only catch is you eliminated your heater core?
Old 04-03-2012, 02:03 PM   #670 (permalink)
The Boss
bedheadben's Avatar
Exactly, mine is wired to ignition too and it's fine.
That's what your thermostat's for. I live in Washington and my fan is always on and even on the coldest nights in winter it still runs great.
http://boss-performance.com/
90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/89-roadster-projects/25863-bedheadbens-build-thread.html
96 Miata M Edition (Street/Track Car) *Flipped http://www.youtube.com/watch?v=qMmjaaSQP08
"Got Maserati dreams with Mazda Miata money." -Mykestro
bedheadben is online now   Reply With Quote
Old 04-03-2012, 02:45 PM   #671 (permalink)
yep no heat.
Old 04-04-2012, 08:29 AM   #672 (permalink)
Boostedmx5's Avatar
I ripped all my heater core shit out the other day. Looped the lines.
Old 04-05-2012, 01:26 PM   #673 (permalink)
Old 04-05-2012, 02:11 PM   #674 (permalink)
The Boss
bedheadben's Avatar
So clean, I love all the smoothing you did, that's my favorite part. How is that typically done? Body filler?
90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/showthread.php?t=25863
Old 04-05-2012, 02:12 PM   #675 (permalink)
fiber glass and rage/bondo
Old 04-07-2012, 10:08 PM   #676 (permalink)
IH8
IH8's Avatar
looks amazing.
could look better with ITB's, bike carbs or dual carbs but it'spretty much the best roadster bay i have seen!
IH8 is offline   Reply With Quote
Old 04-07-2012, 11:05 PM   #677 (permalink)
amptramp's Avatar
There is a way to retain the heater when doing a coolant reroute: swap the water elbows from front to rear and the elbow with the small outlet will be on the front. Attach a heater hose to that and you have basically swapped the rear and the front of the engine. It isn't optimum, but it is better than the original setup.
amptramp is online now   Reply With Quote
Old 04-07-2012, 11:12 PM   #678 (permalink)
Hey Matt, have you had any issue with electrical sensors/electric parts in general? I've heard that lengthening all those sensor wires can cause them to read improperly because of voltage drop off or something like that
GarageStar
Visit GS
2001 SE NB Racekor: Build Thread
If I've ever sold you a part or bought something from you, please leave me some feedback!
spitefulcheerio is online now   Reply With Quote
Old 04-11-2012, 04:24 AM   #679 (permalink)
Cr.net is addicting
Venice's Avatar
My bay as of now still need to finish up a couple things . None of the sensor wires have been extended .
*Project* Now it has a name .
Venice is offline   Reply With Quote
Old 04-11-2012, 09:06 AM   #680 (permalink)
//reported
phillyb™'s Avatar
very nice!
you want a decal
phill out the phorm on my site - phillybhateme.com
@phillybhatesme on instafag
phillyb™ is offline   Reply With Quote
Old 04-11-2012, 09:50 AM   #681 (permalink)
mighty mouse's Avatar
I extended pretty much every wire, and I don't have any issues- you'll be fine.
298.6whp - 270ft/lbs - 8500 RPM
Build Thread: http://www.clubroadster.net/vb_forum...?t=9930&page=9
Coast Works est. 2010
mighty mouse is offline   Reply With Quote
Old 04-11-2012, 11:33 AM   #682 (permalink)
only wires i extended were for VAF.. but everything is good
Old 04-11-2012, 11:38 AM   #683 (permalink)
Thanks for the info!
GarageStar
Visit GS
Old 04-11-2012, 10:22 PM   #684 (permalink)
perzbenz's Avatar
Didn't weld and grind? Aren't you going to run into a lot of cracking later?
perzbenz is offline   Reply With Quote
Old 04-13-2012, 09:06 AM   #685 (permalink)
i did weld all the holes shut. then i used the glass to round myfender wells
Old 04-13-2012, 05:08 PM   #686 (permalink)
DangerKart's Avatar
Here is what I got going so far, Just deleted what I could and didn't touch the driveside yet.
So what is the easiest way to relocate my fuse box?
Does everybody put it under the dash?
Also can I just loop the 2 tubes together for this resivior and call it a day?
Any help with ODB-ll would be great!!
Boycott Ebay
DangerKart is offline   Reply With Quote
Old 04-13-2012, 08:03 PM   #687 (permalink)
Accepting donations.
adamvanxxx's Avatar
Loop the lines on the rack after draining the rack after a few lock to lock turns.
Depin the fuse box and put it inside.
Originally Posted by kawaii_kawaii View Post
My car
adamvanxxx is offline   Reply With Quote
Old 04-13-2012, 08:19 PM   #688 (permalink)
The Boss
bedheadben's Avatar
Worst advice on depowering a steering rack ever haha. Depower it the right way, that way you don't need to be superman to turn the wheel.
Old 04-13-2012, 08:25 PM   #689 (permalink)
adamvanxxx's Avatar
LOL not.
If there is no fluid in the rack the the seals aren't pressurizing anything. Either I am super strong and wrong or I'm not.
Edit: If you leave the rack full or just take off the belt then yes it is hard as dick.
My car
Old 04-13-2012, 08:52 PM   #690 (permalink)
Boostedmx5's Avatar
Either I'm superman or you are a pussy.
