#691 (permalink) |
The Boss
Well when I depowered mine that way a year later it got all rusted out in the rack and was impossible to turn. The time after that I welded the holes where the lines go in shut and removed the seal and it was a little better but still not there. The time after that I just bought a car that had a factory manual rack. The difference is night and day.
http://boss-performance.com/ 90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/89-roadster-projects/25863-bedheadbens-build-thread.html 96 Miata M Edition (Street/Track Car) *Flipped "Got Maserati dreams with Mazda Miata money." -Mykestro |
#692 (permalink) |
Accepting donations.
My car feels fine and has felt fine for a year now. The ratios for power to manuel rack are different, that is why it felt easier.
#693 (permalink) |
The Boss
I know the ratios are different, but none of my depowered racks ever felt as smooth as a factory one.
http://boss-performance.com/ 90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/showthread.php?t=25863 96 Miata M Edition (Street/Track Car) *Flipped "Got Maserati dreams with Mazda Miata money." -Mykestro |
#694 (permalink) |
Okay so you guys are saying that I can't loop the lines, delete the ps resivour, keep fluid in my rack and have working power steering?
Seems like it would work.... |
Boycott Ebay |
#695 (permalink) | |
Power steering pressures are no joke I wouldn't tamper with the system is just delete it all. |
#696 (permalink) |
Just trying to get the bay super clean with keeping as much as I can.
I'm not worries about the pressure, It will be using the same hoses and clamps. Just wondering if a air bubble would start and effect anything? Or anything else that would be weird. |
Boycott Ebay |
#697 (permalink) |
no need to reinvent the wheel, this has been done countless times
298.6whp - 270ft/lbs - 8500 RPM Build Thread: http://www.clubroadster.net/vb_forum...?t=9930&page=9 Coast Works est. 2010 |
#699 (permalink) |
If you're doing a wire tuck, do it the right way or you might run into problems down the road. Imagine getting a leak in your PS system.....how would you refill it without a reservoir
GarageStar Visit GS 2001 SE NB Racekor: Build Thread If I've ever sold you a part or bought something from you, please leave me some feedback! |
#700 (permalink) |
Yea you have to pull the dash. I can pull mine in 15min with me and my roomate. Its simple.
#701 (permalink) | |
If I ever had a problem I would just install an inline filler cap with the right pressure rating. |
Boycott Ebay |
#703 (permalink) | |
Do they make tapered hoses? Also I am getting close to my psudeo wire tuck. No check engine light yet with the OBD-ll All my wires are still in the engine bay, just tucked to the side. Still need to tackle my fuse box |
Boycott Ebay |
#708 (permalink) | |
I'm going to be deleting my headlight motors and the fusebox will be going under the dash. I'm halfway done with depinning the fuse box so I can pull the wiring through the firewall. |
#710 (permalink) |
First one, looks to be a ground
As for the fuse block, I found it to be easier to just pull all of the wires out from the motor to the back where the battery is. Both had hassles but pulling them all out just seemed less of a headache down the road when I went to put it all back in. |
#712 (permalink) |
Cr.net is addicting
You depinned the whole fuse box . Why all you had to do is pull the wires from the rear forward . I tried to de-pin some of the clips screw that i just cut them .
I'm one line away from finishing my tuck waiting on a fitting then i'll get some pictures up . I'm also going to be making my own intake but if i can't get the couplers in time i'm going to just run the factory one . Seeing as i painted it to clean it up and make it look new . |
*Project* Now it has a name . |
#717 (permalink) | |
That is the ignitor condensor. It controls spark output so that the ignitor doesn't throw over voltage.
![]() Quote:
And I know what it does because I needed to replace mine on my NA because the wiring was frayed lol..
#720 (permalink) | |
I hope for your sanity im wrong...but then again i hope for my future sanity im right.
