#751 (permalink) | |
"Never trust a big butt and a smile" 94 M-Edition / 91 ED3 Sedan / 96 JDM DC2 / 97 328Ti / 01 AP1 / 87 MK2 GTI |
#754 (permalink) |
brontosaurus
Jrad- I don't think the AFM is supposed to be mounted like that. Because of the flapper door it will have issues running properly pointed down. It's needs to be mounted horizontally like it is from the factory.
Probably best to just do a u-turn and make it a cold side until you get a standalone to delete the afm. |
#756 (permalink) | |
Supporting Member #5522
things that i still need to do bleed brakes bleed clutch repaint hood and front fenders install roll bar bolt on front end bumper fenders, plastic, stuff, lights touch up under body get a front and rear alignment little things but other then that it should start coming together. next week is the last day of class so i should have more time to work on it. |
#757 (permalink) | |
#759 (permalink) |
Put urs,in bumper like i did man. Functional and cleaner looking. Mines,mounted horizontally still
Team V2lab_____ Sponsored By Rev9 Autosport & D2 Caged_Tucked_Manual Brakes_JenveyITBs_Megasquirted My never ending and always changing build thread. http://clubroadster.net/vb_forum/89-roadster-projects/56935-mr-mattmans-build-thread.html |
#760 (permalink) |
The Boss
http://boss-performance.com/ 90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/89-roadster-projects/25863-bedheadbens-build-thread.html 96 Miata M Edition (Street/Track Car) *Flipped "Got Maserati dreams with Mazda Miata money." -Mykestro |
#761 (permalink) |
ok, so here's what I did today. its a mild tuck and I still need to do some cleaning
tomorrow I will hide and make the overflow tank. More to come! BEFORE ![]() AFTER
#762 (permalink) |
The Boss
Please clean the junkyard paint off your intake manifold haha. Other than that it's looking good! When I removed the charcoal canister I removed that little bracket that holds the lines completely and just bent down the hard line and attached it to the hose coming up. All of the lines from it are now completely hidden.
http://boss-performance.com/ 90 Miata (DD) Build thread here: http://clubroadster.net/vb_forum/showthread.php?t=25863 96 Miata M Edition (Street/Track Car) *Flipped "Got Maserati dreams with Mazda Miata money." -Mykestro |
#763 (permalink) | |
#768 (permalink) |
Team V2lab_____ Sponsored By Rev9 Autosport & D2 Caged_Tucked_Manual Brakes_JenveyITBs_Megasquirted My never ending and always changing build thread. http://clubroadster.net/vb_forum/showthread.php?t=56935 |
#769 (permalink) |
Here is my OBD-II
![]() Need to tackle my fuse box and get an intake . . . . wrap my headers get rid of power steering and ac.............one day |
Boycott Ebay |
#773 (permalink) |
Cr.net is addicting
Alright I've run into most likely a easy problem . The cars been down for atleast 2 months just put some fuel in the tank yesterday and attempted to start it an i got nothing . The car will crank like a champ but no start . I get fuel ,spark ,and from what i can tell the timing should be on (wasn't messed with) . I'm thinking it could be a ground that i've forgotten to hook up or installed in the wrong place . I'm going to check for this today when i get off work.Anyone else have this problem before .Car ran fine before the tuck , I don't recall extending any of the wires to the sensors on the motor.
*Project* Now it has a name . |
#774 (permalink) |
If spark fuel and timing are good I don't see why it wouldn't start.
My Build Thread 1993 Electronic Pearl Blue Miata- Brain built MS2,Stock 1.6 with a SR20 turbo on 14 psi, 3 inch downpipe to open dump, custom stainless steel tubular manifold, Rx7 460cc injectors, MTX-L wideband. Slam Thread ![]() |
#776 (permalink) |
Cr.net is addicting
Honestly my only thought is I'm missing/bad ground. I'm going to check and clean all of them tonight . Only other thing I could think of is my tps sensor isn't talking to the ecu . Idk today is a whole new day shit happens.
#777 (permalink) |
#778 (permalink) | |
