#1 (permalink) |
Its not really that much of an issue with the Turn signal intakes if they are left black, But when painted...the gaps between the TSI and bumper look a mile wide..White is the worst..
I noticed that the bottom of the TSI is not flat...it curves up...So I slapped some bondo on them to correct and level the bottom out ![]() Kept sanding till there was no gap when sittin on flat surface ![]() After test install, I noticed that there was still a gap even with correcting the flat bottoms The holes where the TSI screw to the bumper made the TSI lead back creating a gap.. SO i added bondo to the top of the area that screws flush with the Bumper to angle it down ![]() ...Primed and installed...No gaps..looks amazing I wish they actually came from the factory with this fit ![]() ![]() Still have to be completely wet sanded and painted but you get the idea |
I wanna rock you like the 80s |
#4 (permalink) |
That looks great. I should look in to fixing mine
