Full-detailed tuck/delete write-ups for NB's! - ClubRoadster.net
Old 01-05-2012, 05:08 PM   #1 (permalink)
vplukas101's Avatar
Default Full-detailed tuck/delete write-ups for NB's!
Well I am looking threw the thread Full-detailed tuck/delete write-ups for NA's! and its all about the N/A's! Need more love for the NB's. If anyone has tucked there nb post pics.
In a couple of weeks i will start tucking my MSM and i will post some pics if people havent already.
Boosting for a cure for Cystic Fibrosis since 1992!
Give it a like its for a good cause!
http://www.facebook.com/#!/BoostForTheCure
vplukas101 is offline   Reply With Quote
Old 01-05-2012, 05:12 PM   #2 (permalink)
//reported
phillyb™'s Avatar
Default Re: Full-detailed tuck/delete write-ups for NB's!
lol, i never realized the other thread had na written in the title.
when i had my nb, i was able to use some of that info and post questions about specifically removing cruise control.
you want a decal
phill out the phorm on my site - phillybhateme.com
@phillybhatesme on instafag
phillyb™ is offline   Reply With Quote
Old 01-07-2012, 08:55 PM   #3 (permalink)
Wooo! Nb love!
So far I removed the plastic panel that holds the relays. Seems like it doesn't do much. Used zip ties to hold the three relays together and tuck them in near the head light. (I think this may block some air flow )
next will be to make a DIY cold side intake. Removes the bulk of the OEM box. And Remove cruise control. That should clean up that side nicely. Though... The wires (near the drivers fender) are held by clips and seems to have no slack.
On the right side, coolant reservoir, canister, fuel thing-ies, fuse box, and windshield fluid reservoir. And that's about it!
2000NB Silver/tan. Done: MS3x, FM springs. To do: TR c1's 15.7.5's BilsHD's.Sways.rails Build thread
Originally Posted by Spettro View Post
And silvermazda has down syndrome. It's been confirmed.
silvermazda is offline   Reply With Quote
Old 01-11-2012, 11:14 AM   #4 (permalink)
Bump?
Mex-5 is offline   Reply With Quote
Old 01-11-2012, 09:13 PM   #5 (permalink)
vplukas101's Avatar
Originally Posted by Mex-5 View Post
Bump?
Once it gets warmer in chicago i will make some vids on each part i figured out how to tuck
living in a apartment blows no place to work
Old 01-28-2012, 02:45 PM   #6 (permalink)
any updates..?
Slammedmx is offline   Reply With Quote
Old 01-28-2012, 04:58 PM   #7 (permalink)
vplukas101's Avatar
just something about working in weather that makes the car look like this
soo once it gets warmer and i have a day off work and school i will start
Old 01-30-2012, 09:53 PM   #8 (permalink)
lol yup that will do it...
Old 01-30-2012, 10:15 PM   #9 (permalink)
vplukas101's Avatar
Tomorrow should be around 50 so i will start! More updates tomorrow night
Old 01-31-2012, 01:22 PM   #10 (permalink)
vplukas101's Avatar
Tools used 10MM needles noise pliers wire cutter and re used parts from parts removed
What i did is how i did it not sure if i did it right im a newb at this but hear it goes
All of these things do not cause a CEL so you can pass emissions if your state does not require a sniffer test
Start with this
Remove those 2 hoses
Pull on this thing
Remove that hose twist it and pull, mine was hard to get of but i got it off with some pulls
This is what i am not sure about cut that hose and cut some hose off from the last thing removed
Put that hose in the other hose and clamp them down with the stock clamps and put it on the hose that was hard to remove
Remove the 2 10mm
This is what you are left with
FOR MSM owners without a MBC
Remove the bolt and wrap it around the other harness's on the left with the sensor on
Old 02-02-2012, 08:09 PM   #11 (permalink)
Radiohead's Avatar
Nice! I've done some tucking on my NB as of late and will post up some pics tomorrow. So far I have removed the charcoal canister, power steering delete, moved the injector harness between the upper and lower half of the intake plenum, a coolant reroute and tucked the CAS sensor wiring behind the rear timing belt cover. Looks really clean so far but, it's just the begining!
Radiohead is offline   Reply With Quote
Old 02-02-2012, 08:39 PM   #12 (permalink)
Lokiel's Avatar
Originally Posted by silvermazda View Post
Wooo! Nb love!
Figuring out where/how to re-mount these three relays that were originally mounted on a bracket between the OEM front strut brace and chassis (after the AEM CAI install and front strut brace update) was a bit of a challenge - to do it neatly at least.
I had a short length of thin, 25mm wide, aluminium from another job that I figured I could bend somehow into a bracket. I didn't have enough for a trial-and-error approach so grabbed my near-empty box of Vita-Brits and cut it into several 25mm wide strips to try several different brackets and mount points. The best solution was to mount the relays parallell to the DIAGNOSIS box (grey box behind bracket in 1st photo below) on the port side and use angled bends to allow the bracket to mount to existing 10mm bolts - worked out quite well IMHO, i clears the DIAGNOSIS box by a couple off mm and is quite solid.
Don't worry about dying, worry about not living!
Build Thread: http://mx5cartalk.com/forum/viewtopic.php?f=57&t=41091
Lokiel is online now   Reply With Quote
Old 02-10-2012, 11:05 AM   #13 (permalink)
curving_edge's Avatar
FEED ME MORE INFO AND PICTURES!
I have a near stock 02 NB and was wondering what those vacuum lines were for!!!
me want moe knowledge!
Originally Posted by greenyellow View Post
You know you own a miata when: When your passenger freaks the F*** out as you enter a corner at what seems, to you, a perfectly safe and reasonable speed.
curving_edge is offline   Reply With Quote
Old 02-10-2012, 11:29 AM   #14 (permalink)
vplukas101's Avatar
Next step for me was to remove the A/C pish posh and P/s pish posh. This part was a pain in the ass, For the power steering it involved removing the front bumper to get to the "power steering cooler" witch in my eyes was the most stupid thing ever. you unhook the belts and start removing anything that is connected to the P/s reservoir. Next part was a little harder to remove the A/C shit i ended up taking out the radiator so i could remove the condenser in 2 min instead of trying to get at it and taking alot longer
make sure a shop removes your a/c would want to kill the earth, even if you think you have a leak take it to a shop i did and boy was i in for a surprise when i unbolted a line remove alll of the lines attached to the a/c crap and done
Old 02-10-2012, 11:30 AM   #15 (permalink)
vplukas101's Avatar
once i figure out what the hell they all do i will make sure you do
Old 02-10-2012, 12:09 PM   #16 (permalink)
J.Lupe's Avatar
Bump...def following, always excited when the NB's get love and new info and diy surfaces
J.Lupe is offline   Reply With Quote
Old 02-11-2012, 04:03 PM   #17 (permalink)
I think this is the only pic I have of mine, I'll take better pics later.
Passengers side:
Drivers side was tucked too, still need to do the middle harness on top of the manifold, and eventually the fusebox.
My Build Thread
imput1234 is offline   Reply With Quote
Old 02-13-2012, 10:11 AM   #18 (permalink)
Excellent! Keep up the good work!
This is doubling as a weight savings thing for autox...for me at least. And it looks sick!
Already pulled the A/C on my car before reading. Be sure to pull the pin on one of the filler caps to release the pressure of the refrigerant. I simply unbolted the top of the radiator, pulled it out of its resting holes and leaned it back to get to the condenser. I was on a lift while doing the work so it was easy to see; but make sure you pull the mounting bracket for the actual A/C compressor. Its a black object held in by 4 bolts and weighs a solid 5 lbs.
GarageStar
Visit GS
2001 SE NB Racekor: Build Thread
If I've ever sold you a part or bought something from you, please leave me some feedback!
spitefulcheerio is online now   Reply With Quote
Old 02-16-2012, 06:19 PM   #19 (permalink)
great job so far, this will be a must on my nb. do many of wires need to be extended, if so i was considering buying a second hand complete loom and splitting it up so i have all my wiring the same/correct colours.
indie is offline   Reply With Quote
Old 03-14-2012, 11:36 PM   #20 (permalink)
Nicktorius's Avatar
Bump! Any updates?
Nicktorius is offline   Reply With Quote
Old 03-15-2012, 06:50 PM   #21 (permalink)
super blurry pic, tucked more stuff, its missing some stuff, but my engine bay:
My Build Thread
Old 04-06-2012, 07:13 PM   #22 (permalink)
vplukas101's Avatar
removed rest of A/c lines
removed windshield washer res
Old 04-08-2012, 07:43 PM   #23 (permalink)
tucked some more stuff, added some more stuff:
still need to tuck that ugly ass coolant reservoir line.
My Build Thread
Old 04-10-2012, 11:05 PM   #24 (permalink)
looks clean, no detailed write ups though, jus showingn off.
www.mazda-speed.com
Need stickers, any design, ideas, BIG small. Hit me up.
coming out of lurker mode
MSM #1153 out of 1428
HELLIONMX5 is offline   Reply With Quote
Old 04-11-2012, 09:52 AM   #25 (permalink)
vplukas101's Avatar
removing the a/c p/s windshield res is figure it out yourself, couple of bolts and you have to follow the lines etc the charcoal canister i made a how to a couple of posts up there
Old 04-11-2012, 11:01 AM   #26 (permalink)
Edit: will post better pics later
I went out to my car on Monday and just started pulling stuff apart and moving it around. I've retained all the factory emissions sensors since I don't want to do a true bay tuck......I really just wanted to clean everything up. No guides, no how tos, I just kinda figured it out! I'm willing to share any of my methods with people that want it!!
moved:
-all emissions sensors on the passenger aide of the bay
-fuel pressure regulator
-relays
-throttle cable
removed:
-AC
-washer bottle
-cruise control
-evap canister (kept and moved the sensor)
-brake booster hard line (replaced with 3/8" fuel line)
-passenger wiper and arm
-all the ugly brackets associated with all the crap
Only had to extend two wires to the evap canister sensor thing.
GarageStar
Visit GS
Old 04-11-2012, 01:07 PM   #27 (permalink)
Nothing really to write about, you just remove shit, or relocate it.
My Build Thread
Old 04-11-2012, 02:29 PM   #28 (permalink)
thread title is Full-detailed tuck/delete write-ups for NB's!
I can go into the engine and just hulk rip everything out but I would take out important stuff. I would dare try this. Need a/c it's 84 and it's not even the summer yet. It's going to be in the 100 steady this summer, I already know. The winter time I was wearing shorts!!! with only a few cold weeks in between.
Anywho. It is supposed to be where Someone can come into this thread and follow directions. not just figure it out. But i did see the instructions you did post. I just would want to pull out something and have some fluid, gas line, spill all over the place. Thats my luck. Just saying
www.mazda-speed.com
Old 04-11-2012, 02:32 PM   #29 (permalink)
Pics!
GarageStar
Visit GS
Old 04-11-2012, 02:32 PM   #30 (permalink)
moved:
-relays
-throttle cable
removed:
-AC
-washer bottle
-cruise control
for example, I don'tr know what all the emmision things are that were removed. evap canister, no clue. evap can sensor thing... again no clue. I am not trying to argue just trying to make this a little more detailed for someone who would try this.
www.mazda-speed.com
