| DIY and How-To Writeups Nothing beats home-made |
#2 (permalink) |
its pretty simple. remove the intake manifold and the headers. take off the valve cover, take off the bolts inside the head holding on to the block. pull it off and send it to a machine shop to get resurfaced. and now all you would really need is the torque specs and bolt pattern. and put everything back together
#3 (permalink) | |
#9 (permalink) |
The bottom bolts for the IM can be a little hard to see and get a socket on but they're there. For the exhaust manifold (header) CAREFULLY remove the bolts for the heatshield and note there's a lower heatshield (<~ Should be, what year is your car?) Valve cover is easy enough, once you get it off you shouldn't have a problem getting your way through bolts and removing the head.
'94 Sepang blue project :: '95 flat black, HT | riced, JR45 '89 2WD, burgandy, Lariat F-150 | leveled w/ 31s |
#11 (permalink) |
Thats the egr tube......gotta remove that
GarageStar Visit GS 2001 SE NB Racekor: Build Thread If I've ever sold you a part or bought something from you, please leave me some feedback! |
#13 (permalink) |
Intake mani has 4 bolts and one nut on top and 2 nuts and 2 bolts on the bottom for a total of 9 if that helps. Plus the support bracket. Gasket might be holding it stuck. A few taps with a rubber mallet should do the trick. I am rebuilding mine right now so any other ?s pm me and ill try to help out.
- Hayden 06' Mazdaspeed 6 - The daily 92' MX-5 - The project Build thread - check it out! http://clubroadster.net/vb_forum/89-roadster-projects/54151-project-na-road-track.html |
#15 (permalink) |
This ^ definitely helps a lot lol.
- Hayden 06' Mazdaspeed 6 - The daily 92' MX-5 - The project Build thread - check it out! http://clubroadster.net/vb_forum/showthread.php?t=54151 |
#16 (permalink) |
[QUOTE=iBoost;1222759]Any more tips or recommendations? I cant seem to take off the intake manifold
[/QUOTE This should help ]http://www.miata.net/garage/manifold/index.html |
'99 Classic Red 12/97 #380 Sometimes it's a little better to travel than to arrive -Robert M. Pirsig |
#17 (permalink) |
_n00b
resurfaced head = peace of mind.
not exactly the easiest job for a noob but you can get it done. just make sure you get little baggies for your bolts and label them so you don't forget. im assuming this is going to take you a while. |
#18 (permalink) |
Wow thanks for all the response! Well I've never done a head gasket, hardest job I've done was replace my transmission on my Acura rsx. I guess I'll just remove the head with the manifold. Reason for doing this is because the car overheats quickly, and there's white smoke coming from exhaust as soon as the car starts.
#24 (permalink) |
brontosaurus
Definitely remove the IM with head, I just pulled mine today for a new intake manifold. Shittiest thing I've done so far in may. Could not get my damn tools in with my big dumb hands. Had to go gloveless n now I'm all sliced to hell. F that IM.
#26 (permalink) |
I am also working on this job. I took out my spark plugs and cranked the motor, had coolant shooting up out of my motor.. I am hoping its a head gasket and not a cracked head
Here is a helpful link I found on a DIY head gasket replacement. It's the last one on the bottom of the website: http://www.mazdabg.com/ftp-uploads/Mazda/--Repair%20Instructions--/323,%20626,%20929,%20Miata,%20Millenia,%20MX3,%20M X6,%20Protege,%20RX-7/7920CH03_Cylinder_Head.htm |
#27 (permalink) |
You could follow the protege instructions. But if it were me, and I was a noob, I'd want to know that I was gonna to be able to actually put the damed thing back together. Pick up a copy of the Enthusiasts Workshop Manual by Rod Grainger.
