| DIY and How-To Writeups Nothing beats home-made |
#1 (permalink) |
hey,
new here figured i should contribute. the actuator on my power door locks froze up so i decided to remove it. this is my first how to post sorry if its not the best here is your nb door panel and location of screws/clips/etc. you need to remove, the top left pop rivet you need to pry out the center part ![]() and theese two as well, theese two you push in the middle rather than pry out the middle ![]() heres some pictures of the locations of the hidden screws ![]() ![]() ![]() put a screw driver behind the window arm oppsoite side of the handle and pry the clip out ![]() this is what the clip looks like behind there ![]() after removing all theese there is plastic pop rivets securing the panel to the door, i found the best way to not break them is too locate them and pull quickly on the edge of the door, after youve gotten the panel loose lift the panel straight up ![]() and wa la |
#8 (permalink) |
I need your assistance, kind sir. PM coming your way
GarageStar Visit GS 2001 SE NB Racekor: Build Thread If I've ever sold you a part or bought something from you, please leave me some feedback! |
