Oregonmon's white 1990... - Page 5 - ClubRoadster.net
Old 09-10-2014, 11:59 PM   #121 (permalink)
oregonmon's Avatar
Default Re: Oregonmon's white 1990 (NOW WITH VVT SWAP)
http://www.motioncontrolsuspension.com/about-us.html
http://www.motioncontrolsuspension.c...e-dampers.html
Old 09-11-2014, 10:15 AM   #122 (permalink)
oregonmon's Avatar
From what I gather, Lex and Jerome are who started Moton then sold to AST.
http://rennlist.com/forums/997-gt2-g...uspension.html
Old 09-11-2014, 10:25 AM   #123 (permalink)
Official Armchair Racer
stormin'norman's Avatar
Your creak- did you keep the plastic washer sleeve thingys that go between the shock hats and the chassis? Those are actually beneficial in limiting nvh. Just an idea..
Old 09-11-2014, 11:10 AM   #124 (permalink)
CSTG
curly's Avatar
No, he does not have those. Definitely worth trying if he can't solve this.
Ryan, I'm suggesting the diff brace first because it's easier than installing the plastic gaskets on the top hats, and easier than reinstalling stock diff bushings.
However, my next suggestion if the diff brace removal doesn't solve anything, is to bolt on the metal cups below the diff arms. Should be pretty easy if done one at a time.
Old 09-11-2014, 11:27 AM   #125 (permalink)
It is an old car.. ride mine. You'll forget all about your creaks.
Old 09-11-2014, 11:34 AM   #126 (permalink)
oregonmon's Avatar
Josh you're talking about the RB lower control arm brace right, not a diff brace.
I'm gonna put my money on poly diff mounts.
http://forum.miata.net/vb/showthread.php?t=420775
Old 09-11-2014, 12:07 PM   #127 (permalink)
Wow so many activities have happened since I've last seen this car! Awesome stuff Ryan.
Hopefully we can play next year at the Ridge again
My Blog:
My
Raisin is offline   Reply With Quote Quick reply to this message
Old 09-11-2014, 12:10 PM   #128 (permalink)
CSTG
curly's Avatar
correct.
Old 09-11-2014, 12:15 PM   #129 (permalink)
oregonmon's Avatar
Hey, thanks for the comments.
Great blog of yours!!
Old 09-11-2014, 12:52 PM   #130 (permalink)
I own Laz and you don't.
greddygalant's Avatar
Ryan.... you idiot, did you not transfer the little clear plastic gaskets that go on top of the tophats onto the MCS? You know, like Eddie, Nick and I all told you to get before you installed them....
Old 09-11-2014, 01:14 PM   #131 (permalink)
oregonmon's Avatar
Excuse yourself Martin, I'll let you remove your foot from your mouth.
First of all this creak/sound was there before the suspension swap. I thought maybe it was the previous setup but it clearly wasn't.
Also, there were no gaskets there from before.
Old 09-11-2014, 02:52 PM   #132 (permalink)
The gaskets are worth 1 second at PIR. :O
Old 09-11-2014, 04:42 PM   #133 (permalink)
Well if you had no gaskets before and still don't have them I imagine the sound would persist. Why don't you just put some in....
Old 09-11-2014, 05:40 PM   #134 (permalink)
oregonmon's Avatar
Here's what I noticed today. It goes away, similar to what I read regarding poly diff mounts. When people mentioned theirs squeak when cold and then once warm it goes away.
Old 09-11-2014, 08:38 PM   #135 (permalink)
Your miata is damn sexy! love what you have done with it. Hope that engine swap goes well.
LeadFootLiam is offline   Reply With Quote Quick reply to this message
Old 09-11-2014, 08:49 PM   #136 (permalink)
Big Pimpin'
Flyin' 92's Avatar
I want to compare your MCS to my FCMs. I'm sure the ride is similar in terms of compliance over rough roads.
He's what I noticed today. It goes away, similar to what I read regarding poly diff mounts. When people mentioned theirs squeak when cold and then once warm it goes away.
I had a similar creak/clunk for a while. Then it magically disappeared and hasn't come back *fingers crossed*
cant wait until "time attack style" becomes a thing. put me down for decapitation on the sidewalk from someone's GT wing when they're angling to drop .0001 seconds off of their right turn.
Oh the things I would do to get her in bed...
...like murder a whole school full of children
Flyin' 92 is offline   Reply With Quote Quick reply to this message
Old 09-11-2014, 08:52 PM   #137 (permalink)
oregonmon's Avatar
Yeah, we can swap rides.
Thanks Leadfoot, can't wait to get the swap started.
Old 09-11-2014, 08:54 PM   #138 (permalink)
Big Pimpin'
Flyin' 92's Avatar
Are you going to C&C? If so, I can meet you at your place and we can swap rides there. I'm thinking I'll take the HT off this time.
Old 09-12-2014, 12:54 AM   #139 (permalink)
oregonmon's Avatar
We are possibly quite busy Saturday but I'll try to go. If I do I'll send you a FB message tomorrow night or early that morning.
Old 09-12-2014, 05:35 PM   #140 (permalink)
oregonmon's Avatar
After it being recommended by Eddie at AR, sticking with OEM 1.6 clutch, I got this from a member NIB for a good deal.
Still have to decide on flywheel.
Konis/GC all clean for next owner.
Got my other my wheels off the garage floor and 2 of my studded tires as well.. Pretty good little rack for $60. 300 lb capacity.
Just a wee bit leary about putting the car under it the first time. D:
Old 09-12-2014, 06:40 PM   #141 (permalink)
7lb Fidanza
Old 09-12-2014, 06:52 PM   #142 (permalink)
Big Pimpin'
Flyin' 92's Avatar
I have the 10.5lb ACT and I like it.
Old 09-12-2014, 11:33 PM   #143 (permalink)
oregonmon's Avatar
Lite weight clutch and flywheel is the priority.
Old 09-12-2014, 11:43 PM   #144 (permalink)
oregonmon's Avatar
These look good except from their website, they are 1.8 clutches only, no? Even when installed on a 1.6.
Old 09-12-2014, 11:54 PM   #145 (permalink)
7lb Fidanza is for 1.6. It's what I have paired with stock exedy. Amazing response. You will be a god working the pedals.
Old 09-12-2014, 11:58 PM   #146 (permalink)
Big Pimpin'
Flyin' 92's Avatar
I have an OEM 1.8 clutch. It was cheaper than the 1.6 and I figured I'd get more life out of it.
Old 09-13-2014, 09:33 AM   #147 (permalink)
oregonmon's Avatar
My last response was for Chris. Regarding the Fidanza, I thought that's what I had but now I can't find any record of it. Does yours make a drivetrain racket on deceleration?
Old 09-13-2014, 09:36 AM   #148 (permalink)
Me? Yes. Even a stock assembly is prone to noise.
Old 09-13-2014, 03:56 PM   #149 (permalink)
oregonmon's Avatar
Ok, I've heard that too. I'll probably go with the Fidanza.
Can one of the mods edit my thread title to include (now with VVT swap)?
Old 09-13-2014, 04:54 PM   #150 (permalink)
For the right price, bic boi.
Tags
dipstrap
