Oregonmon's white 1990... - Page 52 - ClubRoadster.net
Old 08-13-2016, 05:52 PM   #1531 (permalink)
Lonely White Girl
aidandj's Avatar
Default Re: Oregonmon's white 1990 (now with VVT swap)
Setrab cooler + whatever AN lines you want.
I'm partial to redhorse. In black. Ryans car doesnt need the silly colors.
1990
1972
- My true love
aidandj is offline   Reply With Quote Quick reply to this message
Old 08-13-2016, 06:01 PM   #1532 (permalink)
notbenh's Avatar
+ facepalm + total fail because SC is a thing. Thanks curly for keeping me in line.
notbenh is online now   Reply With Quote Quick reply to this message
Old 08-13-2016, 07:10 PM   #1533 (permalink)
Official Armchair Racer
stormin'norman's Avatar
You should buy my Tomeis and spin it to 7500. *thumbs up*
Old 08-13-2016, 09:40 PM   #1534 (permalink)
CSTG
curly's Avatar
Ryan dropped his car off today for the install. Few beers later, we're getting somewhere!
Old 08-13-2016, 09:42 PM   #1535 (permalink)
oregonmon's Avatar
Haha, doctor that's the wrong patient!
Old 08-13-2016, 09:43 PM   #1536 (permalink)
I laughed.
Is the install starting today?
Old 08-13-2016, 09:57 PM   #1537 (permalink)
CSTG
curly's Avatar
Greta was dropped off for a quick diagnosis. When we plug in the oil pressure sensor it blows the tiny 500mA ecu fuse. Once I figure that out (most likely a short in the $7 China sensor), I'll be tearing Ryan's car down for 90% of a wp/tb job to fix some leaks and upon reassembly we'll be installing the rotrex.
Old 08-13-2016, 10:11 PM   #1538 (permalink)
Mobius's Avatar
Originally Posted by 99blkx View Post
I boiled over my PS on my first ever track day. TNIA event and old ass fluid.
Power steering sucks.
FWIW I never had any issues with my power steering, even with 225 Toyo RR's on 90+ days. I used the stock "cooler" which is basically just a pipe up behind the radiator on an NB.
Quality fluid is key and makes all the difference. I've always used Mobil1 synthetic in the PS system.
Yeah I was debating on if I should go or not ... Then I was debating on taking the Honda ...Then I just got some beer instead.
Richard - your pompous NB claims are true
RIP: 2001 LS, Rotrex, 217/166. Build 2.0 to come ...
Mobius is offline   Reply With Quote Quick reply to this message
Old 08-13-2016, 10:13 PM   #1539 (permalink)
Mobius's Avatar
Originally Posted by curly View Post
No, fail. Richard gave you the necessary belt with the rotrex
Maybe It might be too long. I've found at least one more to give you.
IIRC for PS no AC you need a belt that's 6 inches longer than a stock PS/noAC drive belt.
Old 08-14-2016, 11:41 AM   #1540 (permalink)
oregonmon's Avatar
Yeah, I read people liking low foaming Redline fluid.
I'd love to hear people's personal experiences of having driven both driven, tracked, autoxd and lived with both power, depowered racks and which you end up liking the best.
Old 08-14-2016, 12:27 PM   #1541 (permalink)
CSTG
curly's Avatar
You'll get answers all over the map. Tire grip, arm strength, amount driven, condition of rack/PS system all changes. If you didn't like it before it started breaking, switch to PS. If you did, keep it unpowered. Switch to a manual rack if you'd like a little less effort.
Old 08-14-2016, 12:32 PM   #1542 (permalink)
Esteemed Member
99blkx's Avatar
I autocrossed quite a bit with a powered rack on 205s and a depowered rack in 225s. I honestly can't say I felt a ton of difference but they were a season apart. I was too lost in the moment and just a dumb Ricky Bobby wanna go fast driver so I'm terrible at actual feedback and reviews. I can say the depowered rack is exhausting at times like in 4-5 at PIR where I'm fighting hard with my left hand/arm. I also never welded or pinned the shaft so that little bit of empty wiggle going straight sucks... Especially in any kind of grooved surface when I'm whipping back and forth all over the road.
If I wasn't yanking the AC at the same time I probably would have stuck with powered. I don't miss it enough to switch back but which I had never left...
Hi, I'm James. A/S/L?
Sold the nice one.
Old 08-14-2016, 12:37 PM   #1543 (permalink)
oregonmon's Avatar
Side note, I'm reading there had been some improvements made to the powered rack for the NA8, no idea what though. 503Garage has 95 ps rack over at Aidan's for me. Just needs to be pulled from the car.
I think I've pretty much ruled out a manual rack, I don't want to increase the steering ratio.
Old 08-14-2016, 02:53 PM   #1544 (permalink)
Lonely White Girl
aidandj's Avatar
Default Oregonmon's white 1990 ricer dream car
I'll probably be stripping that car soon. So come get it before it disappears
Or just lift more?
Old 08-14-2016, 05:23 PM   #1545 (permalink)
oregonmon's Avatar
Or just lift more?
Strip it and hand me that rack.
Old 08-14-2016, 05:25 PM   #1546 (permalink)
oregonmon's Avatar
Josh already tearing into my timing belt. I think there was a leak here.
Old 08-14-2016, 06:26 PM   #1547 (permalink)
Will you do an early head gasket and reroute to keep things cool with the brotrex?
Old 08-14-2016, 07:53 PM   #1548 (permalink)
oregonmon's Avatar
I dunno, but Josh keeps asking me questions, which I'm not sure what they might lead to.
Old 08-14-2016, 07:53 PM   #1549 (permalink)
CSTG
curly's Avatar
Ryan's car is the reroute control group.
Old 08-14-2016, 10:10 PM   #1550 (permalink)
oregonmon's Avatar
CRYPTIC MESSAGES!
Old 08-14-2016, 10:27 PM   #1551 (permalink)
k1l4m's Avatar
With all the cooling talk, is your header wrapped? If not, TDR heat shield maybe?
JR M45 | MS3 | Bilstein's | Buddy Club Spec II | Maruha LSD | Advanti S1 x 225 R-S3 | APR GTC-200
k1l4m is offline   Reply With Quote Quick reply to this message
Old 08-14-2016, 11:07 PM   #1552 (permalink)
Esteemed Member
99blkx's Avatar
I've got a TDR shield I bought and may never use. Hit me up if you want. It's barely used. Have all hardware.
Sold the nice one.
Old 08-15-2016, 11:12 AM   #1553 (permalink)
oregonmon's Avatar
Thanks, I know function > form but I don't think I could rock that thing.
Old 08-15-2016, 11:40 AM   #1554 (permalink)
chiprez's Avatar
Header wrap then?
chiprez is offline   Reply With Quote Quick reply to this message
Old 08-15-2016, 11:45 AM   #1555 (permalink)
oregonmon's Avatar
Injectors and intercooler shipped.
Supermiata Organic/Hybrid 1.6 clutch ordered.
Old 08-15-2016, 11:50 AM   #1556 (permalink)
Esteemed Member
99blkx's Avatar
There's a reason I haven't put that on... RB sezinesses!!
Sold the nice one.
Old 08-15-2016, 11:53 AM   #1557 (permalink)
oregonmon's Avatar
So while Curly has my car, I have his Smurf. Poor Smurf doesn't get a lot of love these days but I loved driving it back to my house.
Greta, Smurf and my car at CSTG.
NB1 engine swap, Billies, stripped and, no turbo for now, *cry*. I'm gonna give the exterior a little love while I have it.
One pass of rubbing compound and DA polisher.
This is gonna be messy. 2x2 square of the trunk.
Old 08-15-2016, 11:57 AM   #1558 (permalink)
Zing Master
Sploinkin's Avatar
So when is the polishing party to work on the ND?
2016 Meteor Gray Mica Club
Old 08-15-2016, 11:58 AM   #1559 (permalink)
oregonmon's Avatar
It's brand new!
Edit: I'll need it for about 2 weeks.
Old 08-15-2016, 12:43 PM   #1560 (permalink)
Zing Master
Sploinkin's Avatar
It's brand new!
It's a September 2015 build date with 4500 miles on it! I'll need a replacement car though, how about the wagon?
Tags
dipstrap
