Oregonmon's white 1990 ricer dream car - Page 12 - ClubRoadster.net
Old 12-30-2014, 01:23 PM   #331 (permalink)
oregonmon's Avatar
Default Re: Oregonmon's white 1990 (now with VVT swap)
http://revlimiter.net/store/gauges-na.php
Circuit, FC, MX-8 look great.
Conner, what color did your gauges end up being when lit?
Old 12-30-2014, 01:34 PM   #332 (permalink)
Zing Master
Sploinkin's Avatar
Just a brighter green. As retro as the rest of my car might try to be, I like bright lights (LEDs in the map lights and in the visor delete plates).
2016 Meteor Gray Mica Club
Old 12-30-2014, 09:50 PM   #333 (permalink)
CSTG
curly's Avatar
Ryan, check out stoly's NB gauges. Might be your style.
Old 01-03-2015, 01:07 AM   #334 (permalink)
oregonmon's Avatar
Good call Curly.
Trying to figure out why the driver's side parking light (blinker works fine) is intermittent. Ordered a new blinker harness from Rosenthal. Not exactly sure that's the problem, swapping bulbs harnesses back and forth and basically they are all sketchy.
Question though, white or yellow LED bulb?
Max, everyone!
Old 01-03-2015, 01:26 AM   #335 (permalink)
CSTG
curly's Avatar
Yellow and stock lights...
Old 01-03-2015, 09:58 AM   #336 (permalink)
Stock's Avatar
Angry eyes? Really?
Instagram -TF_Tyler
- Parted out
- Sold
Stock is offline   Reply With Quote Quick reply to this message
Old 01-03-2015, 11:40 AM   #337 (permalink)
oregonmon's Avatar
Old 01-03-2015, 12:07 PM   #338 (permalink)
humming's Avatar
I'm with curly. Also, cute kid! I've got 3.
2005 Lava Orange MSM -
Originally Posted by maarp
...I'm a man of wealth and taste. Well. not so much the former, and I'm working on the latter.
humming is offline   Reply With Quote Quick reply to this message
Old 01-03-2015, 12:46 PM   #339 (permalink)
Official Armchair Racer
stormin'norman's Avatar
Originally Posted by Stock View Post
Angry eyes? Really?
My vote. Car is too nice otherwise to have those on it. And you're not on an autozone budget.
E codes + stock indicator housings?
stormin'norman is online now   Reply With Quote Quick reply to this message
Old 01-05-2015, 01:52 PM   #340 (permalink)
Zing Master
Sploinkin's Avatar
Aren't those the turn signal indicators? White is illegal in Washington for sure.
Old 01-05-2015, 02:00 PM   #341 (permalink)
e1_griego's Avatar
Stop being a geriatric ricer.
e1_griego is online now   Reply With Quote Quick reply to this message
Old 01-05-2015, 02:49 PM   #342 (permalink)
Haerie Ballsagna
concealer404's Avatar
Yellow and stock headlights. Or if you must do something to your headlights, have Bo get you some RS Active or Bellofs or something.
PM me for Amsoil fluids.
Originally Posted by Corky Bell
Understanding how it works and even it's limitations doesn't really matter.
Gotta tell you, Quaker Oats with Jose is a real treat.
corky
concealer404 is offline   Reply With Quote Quick reply to this message
Old 01-05-2015, 03:07 PM   #343 (permalink)
PNW JDM parts god
i do happen to have some type 1's sittin around
bogaut is offline   Reply With Quote Quick reply to this message
Old 01-06-2015, 12:37 AM   #344 (permalink)
oregonmon's Avatar
Fine!
I killed my battery trying to diagnose these damn signals.
I wonder if it's the LEDs. Dunno.
Old 01-06-2015, 04:08 PM   #345 (permalink)
oregonmon's Avatar
He does look happy with new working bulbs and nice clear housings.
Old 01-06-2015, 04:15 PM   #346 (permalink)
See You Next Tuesday!
jpatrick's Avatar
I've heard that LEDs can/do require resisters (or something) to be installed to work with certain turn signals.
Something about not having enough resistance to operate the flashers?
(Don't know the specifics, but remember reading about them on one of the major online LED bulb suppliers.)
Have you swapped in stock turn signal bulbs yet to see if that resolves your issue?
And of course, nothing quite as crisp and clean as a stock-ish appearing white NA!
(Though I may be a bit biased!)
jpatrick is offline   Reply With Quote Quick reply to this message
Old 01-06-2015, 04:56 PM   #347 (permalink)
Esteemed Member
99blkx's Avatar
Send me your driver's side TSI right meow. I like asymmetrical things.
Hi, I'm James. A/S/L?
Sold the nice one.
Old 01-06-2015, 05:47 PM   #348 (permalink)
oregonmon's Avatar
I've read a little about that too, could be. The bulbs would work, if I played around with them and/or messed with the harness wires. Then one side would work then all of a sudden just NOT.
Problem is I don't think I can use the incandescent bulbs with the TSIs, too much heat and melting the plastic.
Old 01-06-2015, 10:10 PM   #349 (permalink)
I own Laz and you don't.
greddygalant's Avatar
So much better!!!!!!
Old 01-06-2015, 11:12 PM   #350 (permalink)
oregonmon's Avatar
Next thing you're gonna tell me is to put a tonneau cover on.
Old 01-06-2015, 11:19 PM   #351 (permalink)
Lonely White Girl
aidandj's Avatar
Some LED bulbs come with built in power resistors, I would assume the ones that came with the TSIs would have them build in. Do the incandescent bulbs have the same issue?
1990
1972
- My true love
aidandj is online now   Reply With Quote Quick reply to this message
Old 01-06-2015, 11:24 PM   #352 (permalink)
oregonmon's Avatar
So far, today, the incandescent have not had any problem.
Old 01-07-2015, 12:03 AM   #353 (permalink)
Lonely White Girl
aidandj's Avatar
Its like the miata gods are telling you not to use TSI's
1990
1972
- My true love
Old 01-07-2015, 07:45 PM   #354 (permalink)
CSTG
curly's Avatar
I thought I already fixed this at your house. Bulbs were bad, sockets were worse.
Old 01-07-2015, 08:16 PM   #355 (permalink)
oregonmon's Avatar
You did NOT fix this even after much begging. Some mechanic, now go have a cerveza. Can you even find a hefeweizen in Mexico?
BTW, are you in Playa Del Carmen?
Old 01-07-2015, 11:10 PM   #356 (permalink)
oregonmon's Avatar
Garage updates!
I've been researching lighting upgrades for my garage. Decided on repacing 3 single bulbs fixtures and "plugged in" 2 bulb T8 fixtures with 3 hardwired T5 high output fixtures. Almost went with LED but the initial buy in on LEDs were about 2x the money and about 1/2 the lumens.
I also received my Sonic Motors SP2 seat.
Before.
Pretty straight forward in hooking these up, another set of hands would have helped with getting them really straight.
They come wired with this super easy wiring clip, just push the wires in.
Took a break and unboxed the seat. Looks and feels pretty good. This seat has more differences to my VS3 seat than I thought it would. Different seat material, different textures, but similar enough to match.
It works!
Cars.
They are as bright as I hoped they would be.
Each fixture should be around 7000 lumens.
Seat under good lighting.
Hopefully I'll get to the seat tomorrow.
Old 01-08-2015, 12:44 AM   #357 (permalink)
Esteemed Member
99blkx's Avatar
I need to know... which seat feels wider in the hips and shoulders? Shoulders are mostly my concern. I know the SP2 should and pretty sure that's what I'm ordering but hearing your real world feedback would be super-d-duper.
Thanks dear.
Sold the nice one.
Old 01-08-2015, 12:47 AM   #358 (permalink)
oregonmon's Avatar
I did take a few minutes jumping into both. Hips don't feel that much wider, which I think is true to their numbers but I did feel a little extra room at the rib level and especially shoulders.
I'll have to spend a little time with a dead blow on the tranny tunnel tomorrow. The forward left corner of the seat makes contact.
Old 01-08-2015, 01:42 AM   #359 (permalink)
Esteemed Member
99blkx's Avatar
Nice. I promised the wifey no parts until after we move... and I just ordered another hub, lol. So I should be ordering within the next month. I'll pretend I'm patient and wait to hear even more about its awesomeness. I need those couple extra inches in the shoulders...
Sold the nice one.
Old 01-08-2015, 11:05 AM   #360 (permalink)
oregonmon's Avatar
How tall are you again?
My VS3 seat is far back as possible which puts the left shoulder wing further back, past the door card bumper. Which means it makes contact with the interior piece near the top latches. I don't think you'll get the SP2 back that far unless you did like El Greigo did and shaved some material off that wing. He said it was no big deal, you may need to do something like that. I found that to have a comfortable angle/recline the shoulders will be tilted back. I'm about 6ft even.
I don't plan on having the passenger seat back that far in hopes that I won't have to make any modifications to the seat. I'll let you know today.
Tags
dipstrap
