Oregonmon's white 1990 - now with more Porsche.
Tags
dipstrap
297K views 3K replies 112 participants last post by  GreaseMonkey2000
#1 · (Edited)
A place to keep track of progress, let's see if I have the discipline to catch up from 3 years ago.
Up to date list of parts/mods. Damn, this took some time.
Current Build
March 2017
1990 B package
Engine/Exhaust
-2002 1.8 VVT engine, rebuilt August 2014, mild head shave 10.2:1 compression
-Engine dyno'd before supercharger 3/26/15 137hp and 121ft/lbs torque (near peak torque at 2400rpms)
-OBX header 94-97
-Enthuza 2.5” test pipe or Enthuza metal core cat
-Racing Beat non resonated mid-pipe
-Racing Beat Power Pulse muffler
-Rotrex C30-74 supercharger with 75mm pulley (dyno'd 234hp/184tq)
-ebay bar and plate intercooler with custom charge pipes
-Kraftwerks rotrex oil cooler and resevoir
-Turbosmart BOV
-K&N Intake
-Reverant built Megasquirt 3 Basic
-Mazda Competition motor mounts
-MS controlled VICS intake manifold from 99/00 Miata engine
-CX Racing aluminum radiator
-powdercoat black valve cover
Suspension/Chassis/Drivetrain
-Motion Control Suspension (MCS) single adjustable monotube dampers
-Eibach 2.25” springs 6” 700lbs/in front 7” 400lbs/in rear
-alignment numbers- front camber -3.1 rear, 2.7 degrees, toe -.08", caster 3.8'
-OEM NB top hats
-1994 power steering
-Superpro poly steering rack bushings
-Curly Shade Tree Garage aluminum steering rack spacers
-R package tie rod ends
-Racing Beat rear control arm brace
-Thompson Automotive front control arm brace
-4.3 Torsen swap with Energy Supension Poly differential mounts
-949 Racing 7.8 Aluminum 1.6 flywheel
-Supermiata 1.6 Hybrid Organic clutch
-Trackspeed Engineering stainless clutch line
-5 speed tranny
Wheels/Tires
-TRM C3M 15x9 +36 offset wheels
-225/45/15 BFG Rival S
Brakes
-Hawk HP+ pads street/autox and Cobalt XR3/5 track (1.6)
-Brembo rotors
-Stainless braided lines
-ATE DOT 4 fluid
-DIY brake booster brace
-Wilwood proportioning valve (to be installed)
Safety
-HardDog Hardcore M2 Rollbar
-Sonic Motors VS3 driver seat
-Sonic Motors P2 passenger seat
-PCI V1 seat mounts
-Schroth Profi 6pt. camlock harness (driver)
-NRG quick release
-Works Bell steering wheel hub
-Momo Monte Carlo steering wheel
Interior
-DIY door panels, faux suede, RS style door pulls
-Innovate wideband gauge
-LED bulbs
-Tablet connected to Megasquirt via bluetooth, running MSdroid
-Tablet also connected to audio amp via bluetooth for streaming music, google maps, etc..
-Kenwood 4 channel amp (hidden)
-Clarion 7 band EQ installed in glovebox
-Rockford Fosgate Punch 6.5"/1" separate component speakers
-radio delete plate, switches for MS controlled lauch control, audio amplifier power
-delrin shift knob
-Billet pedals
-polished vent rings
-center console delete
Body/Cosmetics
-Snugtop hardtop
-Garage Vary rep front lip
-Front and rear tow hooks
-Garagestar black radiator panel
-Rspeed hood struts
-All turn signal, side marker and license plate bulbs to LED
-Osram Night Breaker in H4 headlight housings
-Rear bumper cut and bumper support delete
-APR carbon fiber mirrors and adapter plates
-antennae delete
-Rspeed side diffusers/skirts.
-Blackbird Fabworx adjustable lexan spoiler
#1,495 ·
Re: Oregonmon's white 1990 (now with VVT swap)
Megasquirts have always had launch.
Ryan, given the amount you've ran on track with no test pipe, it's quite possible your resonated mid pipe was burnt out. Ask Nial how easy it is to do that.
#1,496 ·
Oh it's surely louder just not by much, anyway isn't the resonator just some Swiss cheese metal? Is it typical for that to blow out?
#1,499 ·
Offered free donuts, complains.
Millennial!
#1,501 ·
Thursday was a disappointment. As I pulled into the paddock after tech, getting ready another BMW HPDE, I cranked on the steering wheel and got a loud clunk. Which then resulted in the steering wheel being uncentered to the left by about 1/4 of a turn.
History of the rack; depowered, FM style with seals removed, instead of a welded pinion gear it's press pinned. Poly superpro bushings, and aluminum spacers to aid against bump steer.
Before I get into the rack, what could have caused this? Btw, I sort of re-centered the NRG hub and went out for 2 cautious sessions with no issues.
#1,504 ·
Sitting next to a pretty little RS with 600 miles. Already getting taken apart for upgrades.
Ian, Martin, Eddie, and Josh at AR all looked over my car today sort of scratching their heads as what could have caused this steering issue. Someone on mt.net asked if maybe the alignmemt bolts slipped. Apparently it's not unheard of, FM even developed eccentric washers with teeth in them to prevent this. So we checked that, but it didn't seem to be the issue. So I guess I gotta tear the rack out and inspect. OR just look for a replacement, maybe go back to power steering now that I'm on sticky 225s instead of 195s.
Still shopping around for Rotrex install parts as well.
#1,505 ·
Swap in new manual rack from Mazda motorsports for piece of mind? Not necessarily the cheapest route, but a steering rack is definitely something you want 100% faith in.
#1,507 ·
Thanks Ben.
Spoke with 503Garage, he's got a PS rack/pump from a NA8 and possibly a NA manual rack too.
With the NB motor and NA chassis, which years racks are just bolt? Looks like only NB racks with NB sub frame so that's a no go.
#1,509 ·
You're going down the same route as the oil cooler though. The little stuff can get spendy quick. We have all the oil cooler stuff, but if you're adding back PS, why not get a real cooler for the PS, and custom fit lines to/from the rack and pump. With the NB engine in the NA car, I'm not sure how well all the stock stuff will fit. Plus since we're fitting an intercooler with a heavy focus on ducting and fitment, we might have to take up any space the stock PS cooler wants to occupy.
#1,510 ·
I dont think the stock stuff will have an issue fitting. But if you are adding more coolers ducting and placement gets annoying and difficult.
#1,511 ·
I'm thinking Rotrex cooler in the driver's fender well, identical PS cooler in the passenger.
#1,521 ·
I did that with my car. I fit a decent sized oil cooler, power steering cooler, intercooler and bigger super charger oil cooler relatively easy in my nb. I don't know how much more room i have compared to a na though.
#1,512 ·
With ducting from the gv lip inlets? would be sexy.
I've never liked putting stuff in there because i do so much offroading. Not sure what its like with fender liners.
#1,513 ·
He has no fender liners.
#1,522 ·
Slippery slope with swapping subframes/racks. The NB rack and accoutrements are "better", but increasing at a decreasing rate. Except for all the little dollars that **** you.
PS cooler a necessity?
We made a Nissan to Mazda PS hose so I could keep power steering. I'm so glad I did. Such a brilliant rack. Using the stock cooler though - maybe totally different than running 9" wide "hate-me" rubber.
Would definitely like to see your setup sometime over beers though.
