A place to keep track of progress, let's see if I have the discipline to catch up from 3 years ago.
Up to date list of parts/mods. Damn, this took some time.
Current Build
March 2017
1990 B package
Engine/Exhaust
-2002 1.8 VVT engine, rebuilt August 2014, mild head shave 10.2:1 compression
-Engine dyno'd before supercharger 3/26/15 137hp and 121ft/lbs torque (near peak torque at 2400rpms)
-OBX header 94-97
-Enthuza 2.5” test pipe or Enthuza metal core cat
-Racing Beat non resonated mid-pipe
-Racing Beat Power Pulse muffler
-Rotrex C30-74 supercharger with 75mm pulley (dyno'd 234hp/184tq)
-ebay bar and plate intercooler with custom charge pipes
-Kraftwerks rotrex oil cooler and resevoir
-Turbosmart BOV
-K&N Intake
-Reverant built Megasquirt 3 Basic
-Mazda Competition motor mounts
-MS controlled VICS intake manifold from 99/00 Miata engine
-CX Racing aluminum radiator
-powdercoat black valve cover
Suspension/Chassis/Drivetrain
-Motion Control Suspension (MCS) single adjustable monotube dampers
-Eibach 2.25” springs 6” 700lbs/in front 7” 400lbs/in rear
-alignment numbers- front camber -3.1 rear, 2.7 degrees, toe -.08", caster 3.8'
-OEM NB top hats
-1994 power steering
-Superpro poly steering rack bushings
-Curly Shade Tree Garage aluminum steering rack spacers
-R package tie rod ends
-Racing Beat rear control arm brace
-Thompson Automotive front control arm brace
-4.3 Torsen swap with Energy Supension Poly differential mounts
-949 Racing 7.8 Aluminum 1.6 flywheel
-Supermiata 1.6 Hybrid Organic clutch
-Trackspeed Engineering stainless clutch line
-5 speed tranny
Wheels/Tires
-TRM C3M 15x9 +36 offset wheels
-225/45/15 BFG Rival S
Brakes
-Hawk HP+ pads street/autox and Cobalt XR3/5 track (1.6)
-Brembo rotors
-Stainless braided lines
-ATE DOT 4 fluid
-DIY brake booster brace
-Wilwood proportioning valve (to be installed)
Safety
-HardDog Hardcore M2 Rollbar
-Sonic Motors VS3 driver seat
-Sonic Motors P2 passenger seat
-PCI V1 seat mounts
-Schroth Profi 6pt. camlock harness (driver)
-NRG quick release
-Works Bell steering wheel hub
-Momo Monte Carlo steering wheel
Interior
-DIY door panels, faux suede, RS style door pulls
-Innovate wideband gauge
-LED bulbs
-Tablet connected to Megasquirt via bluetooth, running MSdroid
-Tablet also connected to audio amp via bluetooth for streaming music, google maps, etc..
-Kenwood 4 channel amp (hidden)
-Clarion 7 band EQ installed in glovebox
-Rockford Fosgate Punch 6.5"/1" separate component speakers
-radio delete plate, switches for MS controlled lauch control, audio amplifier power
-delrin shift knob
-Billet pedals
-polished vent rings
-center console delete
Body/Cosmetics
-Snugtop hardtop
-Garage Vary rep front lip
-Front and rear tow hooks
-Garagestar black radiator panel
-Rspeed hood struts
-All turn signal, side marker and license plate bulbs to LED
-Osram Night Breaker in H4 headlight housings
-Rear bumper cut and bumper support delete
-APR carbon fiber mirrors and adapter plates
-antennae delete
-Rspeed side diffusers/skirts.
-Blackbird Fabworx adjustable lexan spoiler
Current Build
March 2017
1990 B package
Engine/Exhaust
-OBX header 94-97
-Turbosmart BOV
-K&N Intake
-OEM NB top hats
-5 speed tranny
Wheels/Tires
Brakes
-Brembo rotors
-ATE DOT 4 fluid
Safety
-PCI V1 seat mounts
-NRG quick release
Interior
-LED bulbs
-delrin shift knob
-Billet pedals
Body/Cosmetics
-Snugtop hardtop
-Rspeed hood struts
-antennae delete
