BEAVIS' White NB Turbo Track Car - Page 3 - ClubRoadster.net
Old 09-03-2016, 04:52 PM   #61 (permalink)
oregonmon's Avatar
Default Re: BEAVIS' White NB Turbo Track Car
Cool stuff on the tablet, looks great. I just ordered the Bluetooth module but charging through the ecu is really convenient.
Old 09-04-2016, 07:25 AM   #62 (permalink)
beavis's Avatar
Bluetooth and USB both work on the ECU, I will use USB if I can, and Bluetooth if I must. I will see how it goes depending on which app i'm using and whether ShadowDash supports USB. I have heard it DOESN'T ...and... I have heard it DOES. I will just have to test it one day and find out myself.
beavis is offline   Reply With Quote Quick reply to this message
Old 09-12-2016, 07:05 AM   #63 (permalink)
beavis's Avatar
Here's the result of my first aluminium weld attempt - welding the water pump coolant inlet pipe as mentioned in the last post.
Not great, not a disaster and not bad for a first try I guess. But, most importantly, water tight. And now it offers the extra clearance from the turbo inlet which is what I was after.
And while I was at it, I had a go at welding the BOV flange to this aluminium intake tube. This is the tube that runs between the intercooler and the throttle body.
I cut, drilled and opened up a hole in the tube to allow the flange to receive the air, then massaged it to try ensure the tube and the flange meet up reasonably close. There were a few large gaps that made welding trickier. I think the differences in thickness also made it trickier. Being a polished pipe, there's probably a heap of polishing compound in there causing contamination?
The BOV in question is a turbosmart kompact for a Nissan I believe. Although it's a 'plumback' design, I'm just going to run it open to atmosphere as pictured.
Old 09-18-2016, 12:47 AM   #64 (permalink)
beavis's Avatar
A couple of weeks ago I spent a weekend making these new flat carbon/fibreglass door trims to replace the previous CF ones which were too bulky for these gutted doors.
I wanted a simple flat panel, with a neat door pull and opener. The previous door trim opener was just a bit of electrician wire, and there was no door pull at all. So pretty much anything was better than what I had before.
The trim is mounted with 7 hex head M6 bolts. I riveted on these aluminium tabs and threw a rivnut in them
The interior door handle you may have noticed in the first pic is simply some aluminum tube bolted to the inner side of the exterior door handle. Pushing on the tube from inside the car will push the exterior door handle out. But, its simple and no fancy/complicated latch mechanisms required. Hand looks far too dirty for an IT nerd.
I'll finish off the top edge that meets the window with some sort of trim - haven't worked that out yet.
The door pulls were some random blue strap I had lying around. Opening the door is now as easy as pushing your thumb on the alloy tube and out the door pops.
Next thing on the to-do list is to start on sanding and painting the new fastback roof...
Old 09-18-2016, 07:27 PM   #65 (permalink)
oregonmon's Avatar
Nice job on the flange.
Old 09-25-2016, 11:46 PM   #66 (permalink)
beavis's Avatar
In case you're not a subscriber of my channel on YouTube, or you just missed it, I have a collection of new videos coming out, here's episode 1
Old 09-27-2016, 10:19 AM   #67 (permalink)
oregonmon's Avatar
Great job on the video, subscribed.
Old 10-15-2016, 08:24 PM   #68 (permalink)
beavis's Avatar
Fastback Part 1
Over the last few weekends I've been doing my least favourite thing, body work. Bleah.
The new roof needs to be sanded, holes filled, painted, windows installed, and finally mounted. I've started on the boot section first, filled all the little pinholes and imperfections.
After many hours fillling and sanding with 120grit, this is where it ended up. You may have noticed the hole right in the middle where the third brake light usually lives.
This is the quick latch mount I've gone with.... It has a socket which hooks into a bolt with a spherical end. To remove the boot I just need to push the button and the whole thing pops backwards.
It's a larger size normally for mounting things like bonnets/hoods, but a single latch in the middle here seems to work well.
These apparantly can support upwards of 80kg which should be more than enough considering the boot weighs about 5% of that.
Old 10-20-2016, 06:05 AM   #69 (permalink)
beavis's Avatar
Fastback Part 2
So the roof is all ready for paint now... Main roof section is now sanded
These are the mounting points out the rear of the main roof section, riveted and epoxied on, which the boot slides onto. Its just some aluminium tube welded to a flat alloy strip. The tube slides into holes on the boot.
The whole lot back on the car for now. Looking forward to getting it all painted and some windows installed so the car is completely sealed up again.
Well there you go, ready for primer next, and some sanding and perhaps a little more filling before the paint goes on.
Old 10-26-2016, 07:02 AM   #70 (permalink)
beavis's Avatar
PAINT!
So onto painting, and first off... allow me to introduce you to my makeshift paint booth:
With that I was able to get the parts primered for the first time which was a good feeling.
I then hit the whole lot with some more sanding and filled a few more imperfections.
A final coat of primer to seal it all up. Looking nice and smooth all over now and in the sun to cure well. Special mention to the supercharged NA.
Finally, colour! Looking nice and shiny in what I thought was Mazda 'Pure White'.
I had an apprentice helping out, however the bloke was pretty useless so I fired him.
After a day enjoying the sun I set the parts on the car and scratched my head as to why the colour was so off...
It would seem the bloke at the paint shop stuffed up somehow along the way. The colour was too creamy. I went back and he mixed me up another can. He thinks he may have forgotten to add some black to the mix, either that or his paint code software is off. Note the two open cans. On the left is the original colour, on the right is the new mix.
So second attempt at painting and the colour is looking better. The ladder was a good tool for standing the roof up.
A reasonably nice gloss off the gun, and some orange peel. I guess I'm reasonably satisfied with the level of peel. When I get the time I might try sand it out a bit. Anyone know if it's worth the bother? Or will I make it worse?
The end result
Now it needs rear quarter and rear windows, seals and some brackets to mount it to the car, then this milestone is done.
But, gonna start on the exhaust next... and come back to the windows.
Old 10-26-2016, 11:20 AM   #71 (permalink)
No Ragrets
CollinMB's Avatar
Very nice, looking forward to some "finished" photos
CollinMB is online now   Reply With Quote Quick reply to this message
Old 11-02-2016, 05:12 AM   #72 (permalink)
beavis's Avatar
Exhaust!
Well I spent the last few weekends on making up the exhaust...
Plan is to run a flex join on the end of the Nitro Dann downpipe which will then mate via a V-band to the rest of the exhaust. The exhaust itself will consist of a hotdog shortly after the V-band, and then a muffler at the rear. I would run less mufflers if I could, but noise restrictions are an issue.
I started by tacking the whole lot together with the MIG. The slip in fitment for the likes of the muffler and the v-bands make welding easier.
However, there is a huge gap around the hotdog ends which made welding those up a bit of a challenge.
Mocking up exhaust tip designs... This upturned style was one concept which got scrapped very quickly.
Notice however, I have angled the rear muffler upwards to make sure there is reasonable room for any rear underfloor work/diffuser.
To get the muffler where I wanted it, the boot had to go.
Saved about 3.5kg or roughly 7lbs. Not that heavy In the grand scheme of things, but every gram helps.
Fast forward a week and I spent a morning welding everything up properly. Given this is just old fashioned mild steel, I decided to paint it for a bit of added weathering/longevity. I found this white exhaust paint at the paint shop and figured it would generate some questionable looks...
Close up of one of my less sh*tty welds… Actually, lap joint of the v-band was reasonably easy to weld.
Also notice the huge fat hangers I’ve used. They are bolted to the car with round rubber bushes, much stiffer than a traditional hanger, but not completely solid. Hopefully they are sufficient to keep things sturdy yet not cause any metal fatigue type issues. I might need to cut some metal out of them, they do look a bit heavy.
And, last job was to try keep some of the heat out of the cabin/gearbox/flat floor... So I’ve wrapped it all in the DEI titanium stuff. This used up most of a 50 inch length roll (I think it was 50 inch).
I used this stuff on the last exhaust (pre-turbo 2.5” dia zorst) and it seemed to work well.
Next time I’ll hopefully get back to finishing the rest of the roof.
Old 11-02-2016, 10:18 PM   #73 (permalink)
MiataMan00's Avatar
Can you elaborate on the Nexus setup? I really want to do this in my car but am not exactly sure about what software or wiring is needed. Is is just plug and play once software is installed? And can you make changes on the tablet or is it just presets?
The one and only.
MiataMan00 is offline   Reply With Quote Quick reply to this message
Old 11-03-2016, 05:12 AM   #74 (permalink)
beavis's Avatar
Hey MiataMan, hopefully this answers most of your questions.
In terms of hardware, It's a Nexus 7 2012 tablet hooked into a MS3pnp ecu. Connectivity is via either a bluetooth connection (requires a bluetooth module plugged into the ECU) or via the USB OTG (on-the-go) cable from the ECU to the tablets micro-USB port. Does not work with a serial to USB adapter.
The tablet has a custom OS on it, specifically: cm-10.1-20130817-USBROM-grouper (you can google how this is done, there are tutorials out there)
Tablet has also been hacked to force it to boot up when power is applied to the USB. (again, google can help here)
There are a few things to consider in terms of software, firstly there are 2 main application options:
msDroid - free (with a paid upgrade) great product which supports on the fly tuning, dash boards, live datalogging
ShadowDash - (paid only) also a great product which does much of the same stuff as above, except for the tuning part
Both of these offer fully customisable dashboard options....
And, I also have AutomateIt which does some fancy work with automating custom actions based on triggers. So I use it to launch msDroid on startup, or put the tablet to sleep on power loss.
Hope that helps.
Old 11-25-2016, 07:09 AM   #75 (permalink)
beavis's Avatar
Reduced Mass Makes The Car Faster
Sorry it's been a while since the last update... but plenty of stuff has been happenning.
So following from my removal of the boot floor (to make room for the exhaust), I continued the work with the grinder and cut out the remainder of the boot floor, that being the parts either side of the main frame rails in the boot where the battery usually lives on these cars.
In theory I could probably cut the frame rails out also, however, I thought it would be good to keep them for now, at least until the wing mount is worked out.
The other section I removed was the piece where the boot hinges usually bolt to, which lives between the passenger compartment and the boot area.
Not satsfied, I kept going with the grinder and took out the multiple layers of steel that lived above the rear wheel arches. There are about 4 layers of sheet metal here.
Sometimes it took a few passes with the grinder to take a layer off at a time to get the the next layer underneath.
And so many difficult hard to reach spots.
So much grinder dust and steel... and not looking forward to the cleaning that I will need to do.
The car is so much more open now, and the rear so easily accessible from the cabin.
While all external metal is still in place, you can really see how much of an 'airy' feel it has now.
I just wish I could shrink the fuel tank hump down now as it seems like a big lump in the way of what could be a big flat area.... MX-5 ute perhaps?
While I was on a roll, the seat mount hump thing on the drivers side of the car was drilled out and removed as the seat now bolts into the cage.
You can see the dash from the boot That's it for now....
Old 11-25-2016, 11:53 AM   #76 (permalink)
oregonmon's Avatar
Wow, quite the surgery. Serious question, obviously less weight is better, what are your thoughts on weight distribution/bias when removing weight?
Old 11-27-2016, 03:06 AM   #77 (permalink)
beavis's Avatar
It is certainly seeming easier to remove weight from the rear of the car than the front. I suspect I will need to make up some sort of tube front end one day to help with that.
But yes, while weight distribution is compromised, any weight reduction is good. Plus, I can just balance it out with more rear wing and diffuser right!?
Old 11-29-2016, 12:25 AM   #78 (permalink)
beavis's Avatar
I should also add, in case you missed it, we've had a few interesting events around Melbourne recently which I managed to get the video camera out for.
Cars and Coffee 2016 at Sandown Raceway and Mazvember 2016 - check out the videos below
Also, a blatant plug for my youtube channel. If you like various things MX-5/Miata/cars you should probably subscribe https://www.youtube.com/bbeavis
Mazvember 2016
Old 12-03-2016, 08:01 AM   #79 (permalink)
beavis's Avatar
Sometimes I hate doing this stuff
So some idiot cut a bunch of holes in my car and now I have to fill them back up.
So... bust out some CAD. I think the pictures say it all here.
The side sections need a slight kink about 3/4ths of the way along.
The sides will be mounted permanently, the middle section however will be bolted in for removal to make for easy access to... stuff?
The middle section has a kick up at the rear to meet the rear of the boot.
The carboard templates will be replaced with fibreglass panels weighing about 1/8th of the steel it replaces.
Oh by the way, take it from me, safety should always come first... my index finger had a close call with the grinder cutoff wheel because of the awkward cutting that was necessary.... so please always take care!
Old 12-03-2016, 12:09 PM   #80 (permalink)
oregonmon's Avatar
Wait, weren't you the ???
So was this the plan all along, to replace with fiberglass?
Old 12-05-2016, 01:48 AM   #81 (permalink)
beavis's Avatar
Well, yes.... I mean, what did you have in mind? Always open to suggestions
But I didn't think it would be a good idea to leave it open.
Old 12-19-2016, 06:45 AM   #82 (permalink)
beavis's Avatar
Intercoolers are cooler with proper tubing
Sorry for the delay between updates... I've got no excuse this time, just been otherwise occupied. But I've managed to do some things on the car...
Although I had already 'finished' the intercooler tubing, I wasn't happy with it.
The previous setup for the pipework from the Turbo to the Intercooler was 3 aluminium lengths joined by silicone 45deg bends.
This would result it too many potential failure points and too many heavy hose clamps.
Thankfully the solution was simple, replace the silicone 45's with aluminium 45's. And now that I had the TIG welder, I could put this all together myself without too much trouble. (and any excuse for welding practice is good)
This is all 2" tube, to match the outlet from the turbo. The silicone joiner into the intercooler is a 2.5" to 2" reducer 90deg bend.
While I was at it, the intake INTO the turbo needed to be sorted out also as nothing had been done for that yet.
The tube work here is 2.5" to match the inlet to the turbo. Working backwards from the turbo to the pod filter there is a 90deg bend out and up from the turbo, and then another 90 to bring the tube parallel with the ground again and over the top of the frame rail. Then, a 3" to 2.5" reducer to adapt from the pod filter.
I decided to go with the pod filter mounted just behind the left hand headlight. (well, if I actually ran headlights) Theres plenty of room there for the pod, and any sort of intake ductwork or whatever I end up with here.... I do not have an exact plan for that yet.
Any thoughts on what I should do here exctly?
Box in the pod filter?
Naca duct in the headlight?
Or run some duct for some cold air intake into the pod perhaps?
Old 01-02-2017, 02:35 AM   #83 (permalink)
beavis's Avatar
Did you forget about the Fastback?
Last time with the roof I had finished painting but it still needs a few finishing touches. Windows for the side and back, some foam rubber seals to get the roof sitting nicely on the body of the car and some fixings to bolt it down.
Here's the style shot of the couple of layers of carbon cloth drenched in resin. This is hand laid and squeegeed to try get the resin out. Not the lightest or strongest way to do carbon... it's mostly just for looks, and to keep the wind out.
I have an old bathroom mirror that's handy for doing nice smooth flat sheet like this. PVA release is brushed on the glass first to ensure this stuff comes away easily when it's set. The masking tape is good for keeping the mess contained and aids cleanup.
Once cured, the window shape was cut with an angle grinder and sanded smooth before being glued (sikaflexed) in place.
For the rear window, I'd tossed up the idea of running no back window, or a louvered window Lambo Huracan style. But, ended up going for a plain clear lexan window for best visibility.
A black border is painted around the permiter of the window to hide the glue, and the window is glued and clamped down.
So to make sure the rear window really stuck down properly and followed the slight curve of the rear section of the fastbacnk, it needed to be weighed down.
You can see here how ugly and yellow the doors look now. The rattle can 'appliance white' paint has not worn well. I've decided they really need to be sanded back and painted properly. But that will be a future update...
Old 01-09-2017, 06:37 AM   #84 (permalink)
beavis's Avatar
Another exciting thing to happen in the BEAVIS world of MX-5's recently:
Coolant Hose Fail on the VVT Supercharged NA
So the story on this one goes... I was driving the car to work and thankfully I had the Torque app running on the headunit which is hooked into the car via an OBD2 bluetooth dongle. It kicks up an alert as the coolant temp hits 100degC (212degF)
Immediately I'm perplexed as its never hit that before. At first I suspected it was a result of the weather as it gets toasty here in Melbourne around December/January. When moving, the temp would return to ~95deg, but when stationary it would return to as high as 105deg
So, there is little I can do as I need to get to work, after work i start the car and begin the drive home, thankfully there isn't too much traffic but the symptoms eventually return as the car warms up. I cruise home cautiously trying to keep the temp under 100ish as best I can.
As soon as I pull into the driveway and kill the motor I can hear a hiss and fear the worst. Busted Rad? Boiled Coolant? Head Gasket? ???
I pop the bonnet and the hissing is coming from around the intake manifold, I suspect perhaps one of those smaller coolant hoses that runs to the throttle body and oil filter may have failed?
I poke around and I can see coolant, but cant find a source.
Then, I squeeze the top radiator hose, no pressure at all and a splooge of coolant comes out the side of it. Well there's my problem. And the cause is immediately obvious.
The hose has been ever so slightly rubbing on the supercharger drive belt. The belt has carved a hole out of the hose, only tiny, but enough for the coolant to spray out at a high level of force.
So, a quick hose swap and some length adjustment and the issue is gone Phew
Here's a video of that endeavor:
Old 01-23-2017, 06:01 AM   #85 (permalink)
beavis's Avatar
So lots of work has been happening lately, and I've neglected to keep the forum up to scratch, but in summary....
  • I've worked on getting the doors painted so now they almost match and are much more sturdy than the old rattle can paint.
  • The brake duct mockup has translated into version 1 of aluminium brake ducts. Liken them to home made singular motorsport items.
  • The oil cooler has been moved to a better spot - although not yet plumbed in.
  • The front duct work from the bumper to the radiator has been completed.
  • The front bumper has been cleaned up and painted.
But, more excitingly, the engine has been started!
Yep, I finally got around to nipping up the last of the bolts and giving everything a quick once over to start it and fire it all up. After some delays due to a swap around of the LS coil firing order, it started right up. A brief video to summarise where things are at with the car:
And, the other exciting news is that I was able to get the car out to Sandown Raceway for the MX-5 Fan Fest.
With the 1,000,000th MX-5 on show, Mad Mike in attendance, and some 670 or so fellow MX-5's... we and had a great day in the hot Aussie sun.
The car loaded on the trailer for the first time in 18 months....
Really happy to see the car out again and fully dressed. It's been a long time since it's had all it's body panels mostly installed.
That's it for now, I'll post some individual updates of all of the little changes that have been happening to the car in the coming days with pics detailing what I've done.
Next step is to properly tune the car and then, aero/bodywork upgrade is in order.
Cheers,
Brendan
Old 01-23-2017, 07:52 AM   #86 (permalink)
93_Eunos's Avatar
I've seen this popp up on my Instagram feed numerous times. It's super cool, i didn't know you were on here.
Sponsors: Zestino Racing, Gasosphere
Instagram: MDonnelly_93
93_Eunos is offline   Reply With Quote Quick reply to this message
Old 01-23-2017, 09:47 AM   #87 (permalink)
oregonmon's Avatar
Damn, car looks the business.
Yeah I a few very/zero tolerances of things in the engine bay now with rotrex.
Glad you caught it before bad things happened.
Old 01-23-2017, 09:52 AM   #88 (permalink)
notbenh's Avatar
Congrats! Love watching this just get better and better.
notbenh is offline   Reply With Quote Quick reply to this message
Old 01-28-2017, 06:15 AM   #89 (permalink)
beavis's Avatar
Thanks fellas.... So the car's been on the dyno and after a few niggles, finally got things settled and working.
It's running around 180rwkw and a safe level of torque so as to not blow the little MX5's standard motor or gearbox.
Old 01-28-2017, 01:11 PM   #90 (permalink)
93_Eunos's Avatar
You Aussies and your Kilowatts. Here in 'Murica we measure our power in horses
