'96 BRG NA8C Build Thread - Page 4 - ClubRoadster.net
Old 01-26-2017, 01:15 AM   #91 (permalink)
BRGNA8's Avatar
Default Re: '96 BRG NA8C Build Thread
26/01/2017
JDM Eunos Fog Lights
What better way to spend a public holiday than to get some stuff done to the car. Finally fitted the JDM Eunos fog lights. I'm not sure if the Australian delivered MX-5's had these but in Japan, some Eunos Roadster were fitted with these as a factory option. The fogs came with the wiring harness and the OEM fog light switch for the interior which made things a lot easier. To be honest it was pretty much all plug and play but there were a few extra things needed such as some 15 gauge wires (red, black and green to keep it consistent with the factory wiring), a 2-way and 6-way plug socket, blade fuse wire tap adaptor, a 20A yellow fuse, some zip ties, wire stripper, soldering iron and heatshrink, black electric tape and some wire shroud to keep it all neat and factory looking in the engine bay.
The fog lights only turn on when both the car and the headlights are on. Normally you can turn the parkers and headlights on with the car off but the fogs won't operate unless the car is up and running. Took about 3-4 hours for the install. Massive thanks to Gabriel who helped me get some parts from Jaycar and to Sari for helping me install these. If it wasn't for him I think it would have taken a lot longer since my electrical knowledge and know how is extremely limited and he's actually installed a set himself thus he knew exactly what to do so thanks again mate!
JDM Eunos Fog Lights + other stuff you will need. It came with Japanese instructions which were useless for me since I couldn't read.
Fog Light switch.
Installed!
On and operational!
Follow on Facebook
Follow on Instagram
BRGNA8 is offline   Reply With Quote Quick reply to this message
Old 01-29-2017, 09:54 AM   #92 (permalink)
BRGNA8's Avatar
Nothing better than going for a drive on a Sunday...
Follow on Facebook
Follow on Instagram
Old 01-29-2017, 02:26 PM   #93 (permalink)
(⌐■_■)
freshbuzz's Avatar
Originally Posted by BRGNA8 View Post
These don't come up often and this one was purchased on eBay for roughly $130.00 including delivery from London, England, which was pretty good.
I'd say that's really good - iirc, new ones were going for ~$400 a few years ago
Ad hominem
freshbuzz is offline   Reply With Quote Quick reply to this message
Old 02-04-2017, 10:53 PM   #94 (permalink)
BRGNA8's Avatar
Sunday sunrise over Palm Beach. Sydney, Australia.
Follow on Facebook
Follow on Instagram
Old 02-10-2017, 03:24 AM   #95 (permalink)
BRGNA8's Avatar
Update on a few parts which came through
Received a set of billet aluminium HVAC A/C button, knob dial, trim ring and selector covers made by RS-Products Japan. I bought these because it compliments the interior with other parts the car currently has at the moment, such as the rings on my KG Works cluster, the Garage5 vent rings and it will also tie in when I fit the Nakamae door cards and fit the polished LE speaker panels as well as the Nakamae door handles. These pieces will go nicely with the custom HVAC panels I will be ordering soon from Adam from Revlimiter.net. I haven't yet decided on a HVAC panel design but I do know that I want the font for the numbers on the fan speed dial to be matching my gauge faces and the illumination on the panel to be green, thus keeping everything consistent.
I also received my Mazdaspeed competition diff mounts. These provide about 40% stiffness over the OEM rubber mounts. I'm planning on upgrading my diff to a Torsen 4.1 unit as well as refreshing all suspension bushings to Mazdaspeed, therefore I also wanted to refresh the diff mounts. I didn't go with polyurethane or delrin mounts for fears of increased NVH so hopefully this will be a good happy medium.
After backlogs, christmas and new years holiday periods and waiting for about 4 months, I finally received my order of Samco Silicone hoses from Williams Race Services (WRS) who are the official Australian distributors for Samco Sport. These are my cooling hoses which will replace my failing hoses that I purchased from Carbon Miata. Never again.
Follow on Facebook
Follow on Instagram
Old 02-10-2017, 02:16 PM   #96 (permalink)
geffrocks_86's Avatar
Awesome build! I really appreciate the quality and effort you put into your roadster. Replacing oem nuts, bolts, and rubber is really telling of a car enthusiast and fine taste! Respect!
geffrocks_86 is online now   Reply With Quote Quick reply to this message
Old 02-10-2017, 06:45 PM   #97 (permalink)
BRGNA8's Avatar
Thanks for the kind words mate! much appreciated!
Follow on Facebook
Follow on Instagram
Old 02-13-2017, 07:18 AM   #98 (permalink)
A car enthusiast who pays a shop to get all the work done on his car?
vent_rings_pls is offline   Reply With Quote Quick reply to this message
Old 02-17-2017, 06:56 AM   #99 (permalink)
BRGNA8's Avatar
The OEM speakers and sound system in the MX-5 aren't the best. The sound isn't as crisp or as clear as other factory systems I've heard. Not only that, Mazda decided it was a good idea to remove the speakers from the headrests and instead substitute it with tweeters on the door cards instead.
I'm not a huge audio guy but I do like listening to music on drives so I wanted to upgrade the factory speakers to something which was quality and that would give me the crisp sound I was after but wasn't overly expensive. After a bit of research, I opted for these Polk Audio DB651 6.5" 2-way coaxial speakers. This should be a pretty decent upgrade over the factory units and should pair nicely with the Nakamichi headunit. I should mention that I do not plan on using those speaker covers that came with the speakers. They're beyond hideous!
The later model NA8 did not come factory with headrest speakers like the NA6 but from what I'm told, the cutouts for the speakers are there. It's just that there's nothing in them except foam, so the option of putting aftermarket speakers in is definitely a viable option. I'm planning to install speakers in there and keeping with the same brand, I've decided to get the Polk Audio DB351 3.5" coaxial speakers. Since the sound will have to travel out from the headrests once installed, the Nakamae seat covers I plan on getting will also need headrest speaker perforations.
Hopefully these upgrades will make driving even more of an experience, listening to my favourite tunes while tackling the twisty stuff on the blacktop.
Follow on Facebook
Follow on Instagram
