'96 BRG NA8C Build Thread - ClubRoadster.net
Old 04-23-2016, 09:59 AM   #1 (permalink)
BRGNA8's Avatar
Default '96 BRG NA8C Build Thread
Executive Summary
As at 14/03/2017 :
ENGINE & TRANSMISSION
- Advanced Cam Timing +14 Degrees
- Arrive Intake Pipe
- Beatrush Aluminium Radiator Cooling Panel
- Carbon Miata Black Silicone Cooling Hoses
- GarageStar Lightweight Alternator Pulley
- GarageStar Lightweight Water Pump Pulley
- Gates Racing Performance Timing Belt
- Koyorad 36mm Hyper-V Core Aluminium Radiator
- Mazdaspeed Ignition Leads
- Mazdaspeed Induction Box
- Mazdaspeed Oil Cap
- Mazdaspeed Panel Air Filter
- Mazdaspeed Radiator Cap (1.3 Bar)
- MiataRoadster Short Shifter
- NGK Iridium Spark Plugs
- OEM Mazda Intake Manifold (Satin Black)
- OEM Mazda Rocker Cover (Satin Black)
- Toda Racing Lightweight Flywheel (4.5kg)
- Toda Racing Sports Clutch + Spigot Ring
SUSPENSION & HANDLING
- Beatrush Rear Strut Brace
- GarageStar Delrin Door Mounts
- Mazdaspeed Engine Mounts
- Mazdaspeed Front Strut Brace
- Ohlins DFV Coilovers
- RacingBeat Sway Bar End Links (F+R)
WHEELS, BRAKES & TYRES
- Dixcel Type M Brake Pads (F+R)
- Dixcel Type SD Slotted Rotors (F+R)
- Goodridge SS Braided Brake Lines
- Goodridge SS Braided Clutch Line
- H&R TRAK+ 5mm Spacers (54.1 Hubcentric)
- Pirelli Cinturato P1 Tyres (185/60/R14)
- RS-Watanabe Type-A (14x6.5 +9.5, +4.5 Final Offset)
- RS-Watanabe Centre Caps
- RS-Watanabe Lug Nuts
- RS-Watanabe Valve Stem Caps
EXTERIOR
- B1 Hybrid Polarg Parkers and Tail Lamp Bulbs
- Bosch Aerotwin Wiper Blades
- Depo Clear Front Indicator Lamps
- Front Number Plate Mounting Bracket
- JDM Eunos Fog Lights
- KG Works Chrome Washer Nozzles
- Nielex Fuse Box Sticker
- NoPro Washer Bottle Relocation
- OEM Mazda Genuine Front Lip
- Philips 4300K Crystal Vision Headlamp Bulbs
- Raybrig Crystal Reflector Headlamps
- Runabout M2 Mirrors
- ZOOM Engineering Amber Side Indicators
- ZOOM Engineering Eunos Lotus Emblem
- ZOOM Engineering Retro Fuel Lid
INTERIOR
- Arrive Mahogany Wood Handbrake Handle
- ArtWorks DEWA Billet Aluminium Needle Caps
- Carbing DASH Foot Rest Pedal
- Garage5 Brushed Aluminium Vent Rings
- HKB Boss Kit
- J-F Customs Tan Leather Gearshift Boot
- J-F Customs Tan Leather Handbrake Boot
- JASS Performance Sun Visor Plugs
- JDM Eunos Chrome Door Sills
- JDM Eunos Sunglass Holder
- Joyfast Chrome Gear Knob (Super Short)
- Joyfast Chrome Handbrake Button
- Nakamae Cup Holder
- Nakamae Quilt Mat Belt Line Trim
- Nakamae Quilt Mat Lower Package Tray Trim
- Nakamae Quilt Mat Side Step Trim
- Nakamae Quilt Mat Transmission Tunnel Trim
- Nakamae Quilt Mat Upper Package Tray Trim
- Nakamichi CD400 Headunit
- Nardi Classico 360mm Wood Steering Wheel
- OEM Mazda 93LE Speaker Grilles
- OEM Mazda Silver Tweeters
- RevLimiter Retro Window Switch
- RevLimiter "Type MX-5" BRG Door Sill Inserts
- RevLimiter "Type Smith" Gauge Faces
- RS Products Classic Retro Meter Panel (Type-1)
- RS Products Classic Retro Switch
- Vintage Mazda Chrome Cigarette Lighter
- Zeromotive M2-1002 Style Pedals
MAINTENANCE/OEM REPLACEMENT/MISC
- Carbon Canister Delete
- Front Tie Down Hooks Removed
- Reconditioned Fuel Line Metal Shroud
- Reconditioned Wiper Arms
- OEM Mazda Camshaft Seal Replacement
- OEM Mazda Clutch Master Cylinder Replacement
- OEM Mazda Clutch Slave Cylinder Replacement
- OEM Mazda Coolant Overflow Tank Replacement
- OEM Mazda Crankshaft Seal Replacement
- OEM Mazda External Tensioner Belt Replacement
- OEM Mazda Fuel Filter Replacement
- OEM Mazda Idler Bearings Replacement
- OEM Mazda JDM NA8C 180km/h Cluster Replacement (Replaced at 166,386km)
- OEM Mazda NA6 Oil Pressure Gauge Replacement
- OEM Mazda NA6 Oil Pressure Sender Replacement
- OEM Mazda Panasonic Battery Replacement (Replaced 28/07/2016)
- OEM Mazda PCV Valve Replacement
- OEM Mazda Rear Deck Fuel Line Cover Replacement
- OEM Mazda Rear Deck Fuel Pump Cover Replacement
- OEM Mazda Rear Parcel Shelf Replacement
- OEM Mazda Rocker Cover Gasket Replacement
- OEM Mazda Shifter Insulation Replacement
- OEM Mazda Soft Top Latch Replacement
- OEM Mazda Soft Top Latch End Cap Replacement
- OEM Mazda Soft Top Striker Plate Replacement
- OEM Mazda Thermostat Replacement
- OEM Mazda Third Brake Light Gasket Replacement
- OEM Mazda Timing Lower Cover Replacement
- OEM Mazda Timing Upper Cover Replacement
- OEM Mazda Water Pump Replacement
BRGNA8 is offline   Reply With Quote Quick reply to this message
Old 04-23-2016, 10:00 AM   #2 (permalink)
BRGNA8's Avatar
Default Re: '96 BRG NA8C Build Thread
Hey guys. My name is Steve from Sydney, Australia. Thought I'd start a build thread for my recently acquired NA8C in BRG.
Brief history : The car was previously owned by a much older gentleman (2nd owner, age would be around mid-late 60's) who kept it for around 10 years. He too was a car enthusiast and we chatted a bit about his past car history, which included a Porsche 944, Type A Mini and an Austin Healey 3000, amongst others. In fact, it was the love that he had for his BRG Austin Healey which led him to search for an NA BRG MX5 with tan interior. He had found the perfect one for him and when he picked the car up in late 2005, it has 153,XXX kms on the clock, equating to approximately 15,000kms per year travelled, which I'd consider average mileage. Once he picked it up though, he realised that he simply did not have time to enjoy it as much as he thought he would, which meant that this MX5 under his 10 year ownership travelled only approx. 2000 kms and was always garaged with a car cover over it, laying dorment. He did, however, take the car out every year to get it registered and serviced by getting the oil and filter changed and fixing up whatever may have been wrong.
Fast forward 10 years to December of 2015, the car is now with its 3rd owner. Me. The BRG paintwork is still very deep and in very good condition, has relatively low km's for its age when I picked it up (155,646 kms), has full service history and receipts (including every single receipts from the first owner, also an older gentleman according to the previous owner), and the best thing was that there was absolutely zero aftermarket modifications done to the car aside from a Sony Headunit, thus providing me with the perfect blank canvas to work with.
Here's a few photos of when I picked it up :
12/12/2015
Old 04-23-2016, 10:01 AM   #3 (permalink)
BRGNA8's Avatar
29/12/2015
Photoshoot with Joseph Hui
A good mate of mine who is a photographer and who has taken a few photos of my past cars wanted to see if I was free today so that he could test out his new lense. It just so happened I was, so I picked him up and we went scouting for locations for a mini photoshoot. We took a bunch of photos and even rigged up the MX5 for some rolling shots. I think the photos turned out pretty well!
More photos coming after he edits them.
Old 04-23-2016, 10:01 AM   #4 (permalink)
BRGNA8's Avatar
Getting my NA8 a full service in a few days time hopefully. As with all my cars, whenever I pick up a used car, I always change out and replace with fresh fluids.
So along with the fluid change, the following will be performed :
- new Gates Racing timing belt
- new NGK ZE21 ignition leads
- new NGK BKR5EIX-11 Iridium spark plugs
- new NA8 black silicone cooling hose replacements from CarbonMiata
- new Koyo Aluminium radiator with 1.3 bar Koyo radiator cap
- new Goodridge braided brake lines
- new Bosch Aerotwin BBA450 wipers
- new Philips 4300K H4 Crystal Vision headlights with matching T10 wedge parkers
- new GarageStar Delrin Door Bushings
- new OEM cam and crank seals
- new OEM rocker cover seals and gaskets
- new OEM timing tensioner pulley
- new OEM oil and fuel filter
- Liquimoly 10w40 engine oil
- Liquimoly 75w90 gearbox oil
- Motul RBF600 brake fluid
- Dexron III power steering fluid
And a few little bits 'n bobs purchased as a late Christmas present to myself :
- Joyfast Gearknob (super short)
- KG Works Retro Rear View Mirror
- Custom number plates "96 BRG" black background with white letters
Old 04-23-2016, 10:02 AM   #5 (permalink)
BRGNA8's Avatar
30/12/2015
OEM Rubber Pedal Replacement
Decided to change these as they were getting quite worn and faded.
Bought these as the sunvisors were getting in the way and I never really use them anyhow. Looks much cleaner as a result
I've always wanted this ever since I saw this on a friends NA8C Clubman. It gives it such a nice retro feel to it! Shout out goes to Greasemonkey2000 for sharing a bit of knowledge on where to purchase this item! Thanks again! Install was a breeze, albeit in Japanese. It didn't really take too long to figure out from the diagrams and soon enough, it was fitted and looking very nice indeed!
Old 04-23-2016, 10:03 AM   #6 (permalink)
BRGNA8's Avatar
05/01/2016
Received these in the mail the other day and decided to mount them. It was a very simple install, only requiring a 10mm socket and a philips head screwdriver. Revlimiter has done a pretty nice review on these items here
Factory Mount (which still looked very very good) :
Once removed, there was some gunk and residue :
Decided to clean it up with some cleaner and degreaser before installing the Delrin Door Mounts
Installed!
Have yet to drive the car with these on due to Sydney having some really shocking weather (rain) lately (isn't it meant to be summer?!). These did require a bit of careful playing around and as mentioned on Revlimiters review, the door should not be any harder to close with these mounts in. My driver side screws were loose when I was taking them off. Passenger side was okay. I made sure to tighten them and being careful not to over-tighten.
Philips 4300K Crystal Vision with Parkers
Purchased some bright white Philips headlight bulbs to replace the dull yellow from the headlamps and parker lights. Freshens up the front a little bit at night and emits a very nice white light. The bulbs come with matching white parker lights so decided to change them all.
Yellow parker light
Comparison of Philips Crystal Visions VS OEM
Old 04-23-2016, 10:03 AM   #7 (permalink)
BRGNA8's Avatar
Pole Position Key
Old 04-23-2016, 10:04 AM   #8 (permalink)
BRGNA8's Avatar
07/01/2016
OEM Third Brake Light Gasket Replacement
I realised that my third brake light has little tiny cracks on the plastic and the crusty rubber gasket had all but worn away. Decided to replace them as well as the gasket just for peace of mind. Managed to find a donor third brake light from the wreckers which was in perfect condition.
Brand new rubber gasket
The donor third brake light with old gasket cleaned off
The OEM bracket was all rusty and worn. It also wasn't doing my front bumper any favours as the number plate which was mounted had screws which were way too long and as a result, the top two corners where the screws were holding the plate onto the bracket was also hitting the front bumper itself, which would have caused it to chip etc when going over bumps or when driving over rough surface. I pulled the bracket as far away as I could to the bumper to avoid further damage until I got my new mounting bracket. Thankfully the damage isn't large with the chips being about 1-2mm in diameter, so it's really nothing.
Old number plate bracket :
New number plate bracket. Precision laser cut.
Before. Yuck!
After. Much Better!
Old 04-23-2016, 10:04 AM   #9 (permalink)
BRGNA8's Avatar
08/01/2016
Small cruise, tackling some twisties
Met up with with two mates of mine, one who owns a 2015 Porsche Boxter GTS, and the other being who owns a pretty amazing NA6. Some of you may know him from this forum (Dan AKA "91-BRG")
I met Dan a while ago through a mutual friend and ever since I took delivery of my NA8 BRG, I've been wanting to meet up with him to have a chat to him about MX5's, mods, to see his car, etc since he knows a lot about them and to also just take my car for a good drive through some B roads. Thankfully, that opportunity presented itself today, especially after some horrible weather Sydney has had over the past few days with torrential rain etc. The drive today was epic. Blue skies, no clouds, sun was out. Perfect for some top down cruising.
We went through Bells Line heading up towards Blue Mountains, then decided to come back down and go through Putty Rd. Both drives were fantastic and Dan was so kind to let me drive his NA6 through a few sections of road. I have to say, given that it has no driver aids, modified suspension components and grippy rubber, it made my NA8 feel like a wobbly boat by comparison. Need to do suspension ASAP!
We stopped off at a few locations to chat and take some photos. Here are some. All photos courtesy of Dan (91-BRG)
Old 04-23-2016, 10:05 AM   #10 (permalink)
BRGNA8's Avatar
11/01/2016
Decided to upgrade the tired old stock Koito headlamps to these brand spanking new Raybrig Reflector headlamps. Should have waited for these to arrive before I installed my Philips Crystal Visions but oh wells. Install was a breeze.
Raybrig Headlamps
Installed!
Closeup shot
Before :
After :
Due to the car's age, exposure to sun and general wear and tear, the wiper arms on the NA8 have faded and it was starting have that chalky matte black appearance and texture. Since I was going to replace the wiper blades anyway, I decided to take the arms off and give them a refurb.
Closeup of the worn wiper arms :
Prepping the wiper arms by sanding it down to bare metal. Ended up using a Dremel with a sanding bit.
A once over with some wax and grease remover, I then used a rattle can which has a "satin black" finish to spray the wipers. Applied approximately 6-7 light coats, spraying on the whole wiper arm, then waiting about 10 minutes between each coat before re-applying.
Result :
Pretty happy with how these turned out.
Changed the wiper blades to Bosch Aerotwins. Had these on my previous vehicles and loved the wipe. Model number : BBA450
B1 Hybrid Polarg Light Bulbs
Had a stack of these bulbs laying around from a previous project. Decided to change all the exterior indicator, reverse and brake lights to these items. In the NA8, some had busted, some were worn, so I thought may as well refresh. All the exterior bulbs are the same 1156 bulbs (pictured below), except for the rear brake bulbs which use 1157.
RevLimiter Gloss Black Vent Rings
I purchased these vent rings from Adam (RevLimiter) and went halves on shipping with a friend of mine who wanted some chrome vent rings. I decided to opt for the gloss black as I wasn't sure whether the polished look would suit the BRG's tan interior dash.
I have to admit, I was very surprised when I received the package. In all my years of buying aftermarket parts, I have never once received a thank you letter from the guy I was buying the item from. It was quite personal and was a very nice touch I felt! Adam also included a free gift for me, which was a pretty awesome looking EF Honda Civic Hotwheels car! Not only is the quality of the vent rings exceptional, but he made me feel valued as a customer and for that, I would not only recommend him to people I know, but I wouldn't hesistate to purchase from him again (which I already have in the form of some custom keyrings)
Thanks again Adam, if you're reading this! :cheers:
Goodies from RevLimiter
Honda EF Civic Hotwheels Car. JDM YO!
Sharka Vents Installed
Received the NoPro Washer Bottle to relocate the washer bottle to behind the firewall. Install seemed pretty straight forward. Just need to remove the factory water pump and then install that pump from the old bottle to the new NoPro.
Wires are included in the kit which act as an extension to connect to the relocated water pump. There are two plugs and four terminals supplied with the kit, expose the wire, crimp the terminals and insert them through the plug. Done!
Old 04-23-2016, 10:07 AM   #11 (permalink)
BRGNA8's Avatar
20/01/2016
I had purchased the NoPro washer bottle about two weeks ago and there were a few tutorials online about how to go about fitting one of these for those who have LHD, but no tutorial was available for those who had RHD. To be honest, it's not particularly hard and it's probably a lot easier than fitting one on a LHD car, but I thought I'd document it myself on how I went about installing it. Hopefully this will become useful for someone else later on too.
The items included with the NoPro bottle is an instruction guide, some zip ties, extension wire, two plugs and four terminals. The instruction guide is all in Japanese so unless you know how to read it, it's pretty much useless.
Step 1 : Unclip the power going into water pump.
Step 2 : Use a socket wrench and 10mm socket to undo the bolts holding the OEM washer bottle to the chassis.
Step 3 : Empty out water from the OEM bottle.
Step 4 : Carefully take out the water pump from the OEM washer bottle.
Step 5 : Fit the washer bottle onto the NoPro. New grommet should be on the NoPro bottle already. It should clip in perfectly.
Step 6 : Loosly bolt up the NoPro washer bottle to the chassis. There are two holes which are already on the car (one which has a rubber grommet, pictured below on the left, which comes off very easily) and the brackets on the NoPro should line up with the holes perfectly. All that is required is to either use a Philips head or a 10mm socket to hold it in place.
Step 7 : Strip back and expose the extension wire that came with the NoPro washer bottle. A wire stripper is handy, but if you don't have one, carefully strip back using a razor or box cutter.
Step 8 : The plugs are basically extensions of the original plug on the water pump and also on the car. Crimp the terminals and insert them into the new plugs provided. Make sure that your wiring colours are matching.
Step 9 : Connect everything up and test to make sure it's all working. Once you know it's all working, tighten up the bolts holding the NoPro bottle and tidy up and neaten the wiring under the cowl. Zip tie the wires together if necessary.
Step 10 : Fill up the bottle with water. I've also added about 3/4 bottle of Wurth windscreen cleaner concentrate.
Mazdaspeed Oil Cap
Scored this rare JDM Mazdaspeed oil cap in Gold. I actually ordered a black one but the seller sent me the wrong one. Doesn't matter though, as I'm going with a BRG/Gold theme on my NA8 so after I get the rocker cover polished, it should go nicely with it.
The factory shift knob feels very nice but after having a drive in Dan's (91-BRG) MX5, the weighted shift knob he had felt so much nicer and it compliments the short shifter he has too (which I will also be purchasing down the line). Install was pretty easy, however I have read that some shift knobs are quite tight from factory and it caused a few members some grief in getting them off. With mine though, no strength required. It appears it had been taken off before and had been hand tightened afterwards, which was great for me.
OEM gearknob
Joyfast chrome gear knob (super short, 297g)
OEM knob removed
Installed
The handbrake buttons was also very easy. It just requires the handbrake to be pulled off, which can be done by gripping the handle and moving side to side while pulling towards the headunit. It should then slide off quite easily. The button needs to be turned counter-clockwise to come out. Be careful as there is a spring so make sure the spring doesn't go flying off when you take the button out. Put the new button on and screw it back into place.
Grip handle off
Chrome button installed and handle back on
Result
Old 04-23-2016, 10:08 AM   #12 (permalink)
BRGNA8's Avatar
Few things I bought that are coming in/already in.
JDM Mazdaspeed Front Strut Brace. Will install after full service has been done.
JDM Mazdaspeed NA8C Green Ignition Leads
JDM NA8C 180km/h Cluster showing 166XXX km on the odo. My current cluster is showing 157XXX. Will change it over when it hits the same number. Gives me time to modify it whilst the cluster is not on the car, i.e with RS Product retro face plate and gauges, needles, needle caps etc.
JDM "Roadster" Door Scuff Sills
Revlimiter "MX-5" Door Sill Inserts (to replace the old "Roadster" sticker)
Old 04-23-2016, 10:09 AM   #13 (permalink)
BRGNA8's Avatar
25/01/2016
Not really much of an update but decided to delete the carbon canister from the engine bay. Given that my NA8 is now 20 years old, I think the usefulness of this canister has passed its expiry date a long time ago.
Was going to do a detailed write up but I found a very good step-by-step guide online which you can click here to access.
Before...
...and after
In the bin you go!
In the DIY, it says to go to the boot and that there should be a small black hose nipple on one of the bolts on the rear tail lights. I couldn't find any, but I did find this which came off a coathanger. Just a shame it's not black, but it'll do for now.
Also got this from Adam (Revlimiter). I love BBS wheels, the RS and LM's in particular. Couldn't find any BBS logo keyrings anywhere, so I decided to get a custom keyring made. Initially I wanted it to be red background with gold lettering, but Adam said he doesn't have any gold material to make it and for him to make it, he'd have to pass the cost down to me which is understandable, and it would have resulted in the keyring being too expensive. Therefore, I opted for the classic black background and silver BBS letters. It came out perfect and I'm very happy with how it turned out! Thanks again Adam!
A full major service will be done when I drop my car off on the 30th of this month.
- New Gates Racing High Performance Timing Belt (Part Number : T179R)
- New NGK Ignition Leads (Part Number : ZE21)
- New NGK Iridium Spark Plugs (Part Number : BKR5EIX-11)
- New Koyo Hyper-V core 36mm Aluminium Radiator (Part Number : VH060245)
- New Mazdaspeed 1.3bar Radiator Cap
- New CarbonMiata NA8 Black Silicone Cooling Hoses
- New Goodridge Braided Brake Lines (Part Number : SMA0101-4P)
- New Goodridge Braided Clutch Line (Part Number : 25001-CLU)
- New OEM Mazda Camshaft and Crankshaft Seals
- New OEM Mazda Rocker Cover Seals and Gaskets (Part Number : BP05-10-235C)
- New OEM Mazda Oil Filter (Part Number : B6Y1-14-302A)
- New OEM Mazda Fuel Filter (Part Number : B61P-20-490A99)
- New OEM Mazda Timing Tensioner Pulley (Part Number : GMB445-2050)
- New OEM Mazda Water Pump (Part Number : GMBB6BF15010RMF)
- New OEM Mazda Green Coolant
- Liquimoly Leightlauf 10w40 Engine Oil
- Liquimoly 75w90 Gearbox Oil
- Motul RBF600 Brake Fluid
- Motul Dexron III Power Steering Fluid
- Clean Throttle Body and PCV Valve
After this, the mechanical side of things will be all done and should be bulletproof
Few more mods I'm eyeing at the moment
- Nardi Classico 360mm Wooden Steering Wheel
- Arrive Mahogany Handbrake Handle
- Maximworks 4-2-1 Headers
- Fujitsubo Catback Exhaust
- Tein Monosport Coilovers
Old 04-23-2016, 10:09 AM   #14 (permalink)
BRGNA8's Avatar
Car is in for its servicing. Will be picking it up next week.
Received my number plates.
Tried on a set of BBS RS001, 4x100, 15x8.5, Offset +6. These have been rebuilt with 2.5" lips all round. Originally was going to get gold centres and Black BBS cap and ignore the 4WD spec as I don't have coilovers on as yet. However, when I test fit these on, I realised I will need to roll and pull the guards quite a bit to get them to fit nicely. Not only that, will need to respray the centres, get black BBS caps, polish the lip, get new black bolts and hardware. It would have ended up costing too much for this particular set. Ideally I would like a BBS RS001 which hasn't been rebuilt, which in factory spec is 15x7 +25 and then perhaps go a 1.5" or 2" lip and rebuild it myself.
So, I decided to get Watanabe's instead. 14x6.5 +14.5. Will be repainting the centres Gold and re-polishing the lip. Not my photos but will look like this below.
Will need to get RS Watanabe centre caps too.
Old 04-23-2016, 10:12 AM   #15 (permalink)
BRGNA8's Avatar
06/02/2016
Major Service : Completed
Received the car back from service today. As mentioned previously, with all my cars, whenever I purchase a second hand car I usually do a full service and change out all the fluids with new items as well as tending to other matters which require my attention. Major overhaul has been completed now with fresh oils and all new fluids, new aluminium radiator, oil and fuel filter, spark plugs and leads, silicone hoses, timing belt, water pump, thermostat, PCV valve, tensioner and idler pulleys, rocker cover gaskets, cam and crankshaft seals, brake and clutch lines, and timing advanced to +14 degrees. OEM parts and equipment have been used where possible.
When I was getting a debrief on what was done to the car, it seems as though there were a lot of things which needed changing anyhow and it was a good thing that they were tended to in this service. Basically, ALL the fluids were atrocious, spark plugs were black and definitely needed changing a few thousand km's ago, the leads were misfiring and old (still the original leads from 1996!), fuel filter and water pump weren't installed properly by previous mechanic (who did the work for the previous owner) and the old radiator had a very tiny hairline fracture. If I had driven the car any more than what I had done already, it would have definitely resulted in the plastic end tanks letting go.
Although the previous owner had looked after it as well as he could for 10 years and although he only drove the car 2,000kms in his 10 year ownership and the car "felt" okay every year when he would start the car up and go for a little drive, the component parts were slowly wearing away which isn't good for the health or longevity of the vehicle.
Needless to say, it now feels like a brand new, totally different car. She now idles much smoother with no misfire and driving feel is improved, especially since now that the timing has been advanced to +14 degrees the low down torque is definitely noticeable and there is more useable power.
The new look engine bay!
Silicone hoses.
Koyorad 36mm Hyper-V Aluminium Radiator.
Mazdaspeed!
J-F Customs Tan Leather Gearshift + Handbrake Boot
Decided to refresh the gearshift boot and plastic handbrake boot with some nice tan Italian leather stitched items.
OEM plastic handbrake boot removed and replaced with the new leather boot. Much nicer.
Gearshift Boot ready for install.
Took apart the centre console to find that the shifter insulation looks like a pile of shit. OEM replacement already ordered from Mazda to fix the heating issue. Will also be ordering a brand new MiataRoadster short shifter too, so that I can replace the shifter and fix the heating issue in one go.
All done. Goes well with the interior!
Bought this on eBay to replace my tired, rusted old OEM cigarette lighter. Feels very nice and looks quite pretty. Weighted, chromed, and has the oldschool vintage Mazda symbol. Sticks out a tad more than the OEM lighter but nothing intrusive. Although it's not a genuine part, I feel it goes quite nicely with the interior and the rest of the car.
Very nice chrome finish on the cigarette lighter.
Right at home!
JDM Chrome Door Sills + RevLimiter "Type MX-5" Door Sill Inserts
Purchased a second hand set of chrome door sills in very good condition from Yahoo Japan Auctions with the "Roadster" insert. Decided to hit up Adam from RevLimiter again and purchased his "Type MX-5" door sill inserts to replace it. The inserts from Adam are made from an epoxy which is flexible, sticks perfectly to the door sill recess, very durable, will not yellow or pit and should last around 8 years. Again, very happy with his work!
JDM Chrome Door Sills purchased from Yahoo Japan Auctions.
RevLimiter "Type MX-5" Door Sill Inserts.
Ready to mount.
Removed the plastic sill. Cleaned the grime and dirt before installing the sills.
Installed.
And finally, I was able to take delivery of my RS Watanabe Type-B. Specs are 14 x 6.5 with a +14.5 offset. These also come with tires which still have around 99% of tread left, virtually brand new. Bridgestone Ecopia 185/60/14. Nothing too special but hey, it'll do for now!
Two of the wheels have gutter rashes so I'm going to get that fixed as well as getting the lips polished so they come up brand new. Also, I'll be powdercoating the centres in gold and going to purchase some chrome Watanabe centre caps if I can find some on Yahoo Japan. I was so surprised at how light these are even with the tires on them! It will definitely help reduce unsprung weight, that's for sure.
For now though, I'll be swapping over the rubber from the Watanabe's to my OEM wheels as the tires I have on them currently are Pirelli P6000's which, although when brand new are quite a good rubber, they were put on 10 years ago and albeit only travelling 2,000kms until I picked it up, they're are rock hard! Fresh new rubber will be a welcome change.
Taking delivery of the Watanabe's!
Authenticity.
Time for a bit of a clean.
All done and ready for a refurb.
Next up :
1) Will be looking at fixing the insulation issue and changing the shifter to a MiataRoadster short shifter (already purchased, awaiting delivery)
2) Nardi Classico 360mm Wooden steering wheel + Arrive Mahogany Handbrake Handle to purchase. Already purchased the HKB Boss Kit, (part number : OR-18)
3) KG Works Chrome washer jets + new 5mm PVC clear plastic hoses to route from washer bottle to nozzle.
Old 04-23-2016, 10:13 AM   #16 (permalink)
BRGNA8's Avatar
13/02/2016
The OEM plastic nozzles were stuffed and the jets I think got clogged. Not only that, the plastic pipes from the water pump on the NoPro connecting the nozzles were old, faded and in some places, kinked. Decided to change the hoses to new plastic PVC pipes.
The install was pretty simple. Just needed a long nose plier to get the old washer nozzles off. At most it was a 30 minute job. I had thought about getting the fluidic nozzles but I liked the chrome from these KG Works ones as it will go with the overall theme of the car.
Old nozzle.
New KG Works Chrome washer nozzles installed.
Got this emblem for the front to replace the Mazda flame logo on the bumper. I think it looks pretty cool and goes well with the BRG.
Eunos Lotus emblem.
What it will be replacing.
Residue double stick tape and holes from the emblem.
Done.
Bought this from REV9 as the OEM sticker had lost its adhesiveness over the years. However, it appears that there may have been some JDM engrish printed on these stickers. Unfortunate, but what can you do?
OEM Fuse Box Sticker.
Nielex Fuse Box Sticker. JDM Engrish included as a bonus.
Have also made a few purchases lately, largely from Yahoo Japan.
To go with my RS Watanabe Type B's, I decided to buy the supporting hardware for them.
RS Watanabe Lug Nuts (12x1.5 pitch)
RS Watanabe Valve Stems
RS Watanabe 63mm Centre Caps
JDM Eunos Roadster Sunglass Holder (Thanks to 91BRG and NotableGuest)
Should be coming in soon hopefully.
Old 04-23-2016, 10:14 AM   #17 (permalink)
BRGNA8's Avatar
08/02/2016
Beatrush Radiator Cooling Panel
Installed the Beatrush/Laile radiator cooling panel. Very straight forward install, much like everything else on the MX-5, which you gotta love! I think the NA8 came with a factory cooling panel, if you can even call it that. It's just a flimsy piece of rubber/plastic. Not sure how much more benefit the Beatrush cooling panel will give but if nothing else, it looks awesome!
Beatrush panel ready to be installed.
Before...
...and after.
Also installed this chrome ventilation pipe which I purchased from Mazda spare parts via Amayama (along with many other spares). The NA8 came with just a rubber hose bent in the shape of this pipe but I liked the look of this more, and since I had a spare rubber hose, I cut it up and made it fit. I think it looks pretty neat.
Engine bay as it currently stands.
Purchased these side indicators because I really love how they look. It integrates so well with the ZOOM retro fuel filler lid and coupled with the Runabout M2 mirrors, it gives a retro vibe to the car. Since my car is a BRG, I'm wanting to take it down that route. Install was pretty easy, but I did have to cut the stock wiring.
ZOOM side indicators with wire splicers included in the kit.
Stock side indicators currently on the vehicle.
Wiring cut.
Spliced into the stock wiring.
End result.
Unlike the NA6 BRG's, my NA8 never came with the wood handbrake handle, nor did it come with the Nardi wood steering wheel. These were two things that I really wanted my car to have. I have purchased the Nardi Classico 360mm Wood Steering wheel with black centres and am awaiting delivery. From what I'm told, this handbrake handle will match the wood from the Nardi. In the meantime, I decided to just install this.
Arrive handbrake handle.
Installed. I've also put in my JDM Eunos sunglass holder in place of the ashtray.
I purchased this item as I will be getting some sports pedals for the clutch, brake and accelerator but I'm a little disappointed to be honest. The pedal came with five screws for five holes but the three holes which are on the left side of the pedal have nothing to screw into as there are no exposed holes which can secure the pedal in place. Moreover, the remaining two holes don't require screws as it slots in to the exposed bolts which were holding the OEM foot rest pedal and then secured with the nuts.
I installed it for the time being but it looks a bit odd. I might dremel it off, or just revert back to the OEM. Either way, it was done for looks only.
Carbing DASH foot rest pedal.
Installed. Notice how the left side isn't secure. I may dremel them off.
Old 04-23-2016, 10:14 AM   #18 (permalink)
BRGNA8's Avatar
Forgot to post this photo before.
Overnight parts from Japan.
-Cusco Front Sway Bar (22mm)
-Cusco Rear Sway Bar (16mm)
-Beatrush Rear Strut Bar
-Beatrush Radiator Cooling Panel
-RS-Watanabe Lug Nuts (12x1.5 thread pitch)
-RS-Watanabe Centre Caps (Black)
-HKB Nardi Boss Kit
-Runabout M2 Mirrors
Cusco Front + Rear Sway Bars
Runabout M2 Mirrors
Plus, got some spare second hand OEM parts such as HVAC with AC, AC fan blower and other misc items.
Other parts which are en-route
- Nardi Classico 360mm Wood Steering Wheel with Black Centre
- Exedy Heavy Duty Clutch
- Racing Beat Front and Rear Sway Bar End Links
Old 04-23-2016, 10:15 AM   #19 (permalink)
BRGNA8's Avatar
Some close ups of my RS Watanabe's. Will be refurbing them with a company called Barrel Bros. These guys specialise in restoring wheels. Customers can bring in their wheels and have it repaired/restored to its former glory. Their specialty is old school vintage JDM wheels to be mounted on cars such as 240Z's, TA22 Celica's, AE86's and the like.
Check out the piece written by my friend Kevin (who owns a Nissan Skyline Hakosuka) on Japanese Nostalgic Car blog. Click HERE.
My wheels have some pretty bad gutter rash. The polish lip is no longer shiny and the centre old and tired. It's definitely seen better days.
Plan is to have it completely stripped back, have the lips re-polished to a high shine, centres and barrels painted gold, finished off with RS-Watanabe valve stems, lug nuts and centre caps on some fresh Pirelli rubber.
Hopefully this, along with lowering the car, will complete the exterior look I'm after.
Old 04-23-2016, 10:16 AM   #20 (permalink)
BRGNA8's Avatar
10/02/2016
When I had purchased my NA8, I noticed that as I was driving, the left side of my leg would get really hot due to the temperature coming from the car. Dan (91-BRG) informed me that it was most likely my shifter duster cover was torn as well as the insulation probably having worn out. Sure enough, he was correct. When I was installing my gearshift boot, I noticed that the insulation was just a mess and sure enough there was a tear in the duster cover.
After speaking to Dan, he suggested that if I plan to fix it (which I was), I might as well get the MiataRoadster short shift kit as it comes complete with new duster cover. Having a quick look on the website I realised just how complete this kit was. Not many kits these days come with OEM parts but this was one of them. I promptly messaged Bill at MiataRoadster, placed my order and within a few weeks, I had received my kit.
Following a great comprehensive DIY install guide by Adam at RevLimiter (which you can find by clicking HERE), the install was very simple. The pictures really says it all.
MiataRoadster Short Shifter kit with all the component parts.
The old insulation and torn duster cover.
The old shifter.
New parts ready to be installed.
Installed with brand new duster cover in place.
I had also purchased some new OEM insulation from Mazda Spare Parts via Amayama.
Went for a quick test drive.
After installing the short shifter and going for a spin, the shifter throw is immediately noticeable. It feels so much nicer now with the shorter throw and the shifting feels more precise. Not only that, I'm glad that this kit came with the OEM dust cover. It feels like the most complete short shifter kit available for our MX5's as most only offer the short shifter itself and basically you re-use your existing parts. If you're thinking about getting a short shift kit, get this. You definitely will not be disappointed. It's probably my favourite mod to date.
Many thanks to Dan (91-BRG) for the suggestion and to Bill at MiataRoadster for answering all my queries and for making a sublime short shifter for all of us.
Old 04-23-2016, 10:16 AM   #21 (permalink)
BRGNA8's Avatar
Went for a small drive yesterday with a few mates. Dan's (91BRG) mate recently purchased an '89 NA6. Although it was in pretty bad shape when they picked it up, after a bit of TLC it came back to life along with a new soft top, new tyres and new brake pads. Plus, it was good opportunity to test out his new tyres as well as my new short shifter. Only thing I'll say is, I need to get a proper alignment and dial in some camber.
Some photos. Few of them were taken by 91-BRG.
First stop location.
Porsche Boxter GTS.
Second stop location. Cooling down.
96-BRG NA8 and 91-BRG NA6.
Old 04-23-2016, 10:17 AM   #22 (permalink)
BRGNA8's Avatar
24/03/2016
Unlike the NA6 BRG's, my NA8 never came with the wood handbrake handle, nor did it come with the Nardi wood steering wheel. These were two things that I really wanted my car to have. To replace my OEM Momo steering wheel (which is in great condition and feels fantastic) I purchased the Nardi Classico 360mm Wood Steering wheel just so that I could complete the retro/vintage look. I already installed the Arrive Mahogany Wood Handbrake Handle and this was the last piece of the interior puzzle (for now) to make it seem like an oldschool vintage British Roadster.
Nardi steering wheel with component parts.
In the process of removing the MOMO steering wheel.
MOMO OEM boss which needed to be removed. Cluster also removed (see below).
Steering wheel removed. Date stamp on the MOMO wheel.
Installed!
Feels very nice. The handle isn't as thick as the MOMO but I love how "complete" it looks now that it has the wooden steering wheel with matching wooden handbrake.
I also took this opportunity to install some LED lights in my dash cluster. Since the steering wheel was off, it was much easier to remove the dash cluster and cover. I'm going to have to remove it again later on anyway when I get my RS Products retro dash face with new dials but decided to do it anyway. Now it has white LED's which makes the needles glow white, and is overall much brighter.
Next to be installed :
Currently awaiting on :
- Ohlins Coilovers
- RS Watanabes refurbed to polished lip + Gold centres
Old 04-23-2016, 10:17 AM   #23 (permalink)
BRGNA8's Avatar
31/03/2016
Runabout M2 Mirrors
Decided to install the Runabout M2 Mirrors I had bought from YJA. I've always liked these mirrors and it goes with the retro theme I'm going with, but have been told by many that visibility is quite poor due to the size of the mirrors compared to the large OEM ones. However, it's all for looks, right? Install was very simple and straight forward but unlike the NA6, I had to take my door cards off to unplug the power mirrors. Was easy enough though!
Runabout M2 Mirrors.
Door cards removed to unplug power mirrors.
Installed.
Visibility is, as mentioned previously, not the greatest. But, I'm stoked now that these are installed. It's going to look awesome once I get my Watanabe's on and coilovers installed.
Speaking of Watanabe's, I mentioned previously that I would be getting them refurbed by Barrel Bros. Well, I had dropped them off yesterday and got a message from Mark, who is looking after my set. The wheels will be fully refurbed, with lips polished, gutter rashes repaired, and centers painted gold. Here is the teaser photo I received from him. They've been "stripped down to its undies" according to him.
Their workshop really is worth a visit. They had some pretty rare and old school JDM wheels, of which were either for sale, or were in the process of being refurbed for a customer.
Also, going to be installing this very soon. RS Products Classic Meter Panel Type-1. Will need to order matching gauge faces soon. Looking at the Type-RS Gauge face.
Finally, purchased the ARC intake chamber and box from forum member Munky (thanks mate!). Just have to settle the payment and hopefully I'll be able to install this very shortly. I REALLY want the Mazdaspeed induction box but they're rare as hens teeth. The ARC box is equally as rare and looks fantastic in the engine bay. It will be given the TLC it deserves
The intake chamber and induction box installed in Munky's awesome NA. Photo credits to Munky.
- ARC Intake Chamber
- ARC Super Induction Box
- ARC Replacement Air Filter
- RS Products Classic Meter Panel Type-1
- Ohlins Coilovers
Old 04-23-2016, 10:18 AM   #24 (permalink)
BRGNA8's Avatar
Mark from Barrel Bros sent me a few more photos! He works fast!
Gutter rashes re-welded.
Let the polishing begin!
In progress...
Old 04-23-2016, 10:19 AM   #25 (permalink)
BRGNA8's Avatar
Went for a Sunday cruise yesterday with a few friends. A friend of mine had started a Sunday Morning Drive group where once a month on a Sunday, we go for a small drive and since starting it last year, the numbers have grown. It's not limited to a specific make or model of car either. Anyone can bring anything along and as a result, you do have an eclectic mix of cars which is awesome.
Yesterdays drive was to the Hunter Valley, which is Sydney's wine country, or Napa Valley equivalent, just not as good haha! But, the drive there is around 190kms (120 miles) and about 180km worth is through the twisty stuff, which is always good!
Will be going to the next one too. Hopefully by then, I will have the Watanabe's and the Ohlins DFV's in!
8:30am meet up. Then the fun began. Here are some snaps.
Old 04-23-2016, 10:19 AM   #26 (permalink)
BRGNA8's Avatar
Part 2
Old 04-23-2016, 10:20 AM   #27 (permalink)
BRGNA8's Avatar
Some more progress on the Watanabes. Should be ready in another week or so!
Old 04-23-2016, 10:21 AM   #28 (permalink)
BRGNA8's Avatar
Received this, courtesy of Munky. Thanks again mate for a smooth and easy transaction! Will take very good care of them.
Wrapped and labeled with love. *Cue Charlie Puth/Wiz Khalifa : See You Again*
Contents inside! ARC Chamber and ARC induction box! Cannot wait to put this on my NA8!
Will be polishing it up first using some of the PIKAL metal polish that I got with my ZOOM retro fuel lid. Hoping to install this over the coming weekend!
Old 04-23-2016, 10:21 AM   #29 (permalink)
BRGNA8's Avatar
RS-Watanabe's fully refurbed and repaired, ready to be mounted! It will be accompanied by :
- RS-Watanabe Lug/Lock Nuts
- RS-Watanabe Valve Stems
- 185/60/R14 Tyres. (Not many options for this size in Australia, so will most likely go with Pirelli Cinturato P1's)
Old 04-23-2016, 10:22 AM   #30 (permalink)
BRGNA8's Avatar
Now that I got the RS-Watanabe's back, I can't wait to mount them with fresh rubber. Took some more photos and mocked up how it'd look once the wheels are on there for good.
Once again, cannot thank Mark at Barrel Bros enough. His quality, workmanship and attention to detail is second to none. He tried to match the gold paint as period correct as he could and even when it was painted, the first time around wasn't satisfactory so he stripped it all back and did it again, free of charge. I love people like him who take pride in their work and lets their workmanship speak for themselves. Will definitely be going back there for future wheel restorations.
He also gave me this bottle free of charge too. It's called the "Barrel Bros Lip Balm" and it was developed in house. Basically it's a wheel polish that leaves a nice wax and gloss over the polished lips. Has things inside which help protect the wheel from the brake dust as this is one of the major causes of wheel damage, aside from physical gutter rashes etc.
Always a treat coming here. Everything from SSR's, Works, RAYS, Hoshinos, you name it. Pretty much a wheel whores wet dream.
Mark owns an awesome Datsun 260C with 14" Starsharks fitted. (That's him in the middle. Really good guy). Not just a wheel magician, but a proper car enthusiast.
Closeup of Watanabe's and the finish. Spectacular to say the least. The lip is immaculate and the paint is spot on. It's the exact gold finish I was looking for.
Mark fit some brand new 90 degree bend valve stems in the Watanabes to make putting air in to the tyres a lot easier and one less way to avoid any unwanted scuffs on the lips from the air hose. Also complimentary. I can still revert to my RS Watanabe valve stems later on if I really want to but I kinda like this look. Very practical too.
Mock up of what it will look like.
Better lighting.
With the RS-Watanabe centre caps on.
Just needs a fresh set of 185/60/14 rubber and a drop from the Ohlins DFV's to get it sitting and handling right.
