Aidan's SCCA Stock Class Autocross Build (EFR 6758/VVT 1.9L) - Page 16 - ClubRoadster.net
Old 03-15-2017, 11:41 PM   #451 (permalink)
Lonely White Girl
aidandj's Avatar
Default Re: Aidan's SCCA Stock Class Autocross Build (EFR 6758/VVT 1.9L)
Lower bushings off the lathe and into the car.
Because EGT sensors use special K type wire, special connectors are needed if you want to make your probe detachable.
1990
1972
- My true love
aidandj is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 10:50 PM   #452 (permalink)
Lonely White Girl
aidandj's Avatar
Tossed some sphericals in Mobius's rear uprights.
Added another temp bung...I'm running out of things to do. But at least now I have exterior temperature?
And here is the completed hotside. Everything is done here except the valve cover breather and the oil feed line.
1990
1972
- My true love
Old 03-21-2017, 12:29 AM   #453 (permalink)
See You Next Tuesday!
jpatrick's Avatar
This thread needs more cats.
jpatrick is offline   Reply With Quote Quick reply to this message
Old 03-23-2017, 12:38 AM   #454 (permalink)
Lonely White Girl
aidandj's Avatar
No words needed
1990
1972
- My true love
Old 03-23-2017, 02:25 PM   #455 (permalink)
Aero Master
hnguyen037's Avatar
Trump's America.
-Henry
hnguyen037 is offline   Reply With Quote Quick reply to this message
Old 03-26-2017, 10:52 PM   #456 (permalink)
Lonely White Girl
aidandj's Avatar
Built my exhaust vent line
Wired in the LS coils
Oh and my unicorn (for now) gears showed up. 3.307 rear end.
1990
1972
- My true love
Old 03-29-2017, 12:06 AM   #457 (permalink)
Lonely White Girl
aidandj's Avatar
Bearings arrived at the machine shop today. Maybe I'll see the block by the end of the week?
Installed my hood vent and started drilling out the old rivets. And replacing them with black rivets. May not be everyones cup of tea, but I think the black looks a lot better.
1990
1972
- My true love
Old 03-29-2017, 10:35 PM   #458 (permalink)
Lonely White Girl
aidandj's Avatar
That was an annoying amount of drilling.
1990
1972
- My true love
Old 03-29-2017, 11:32 PM   #459 (permalink)
Aero Master
hnguyen037's Avatar
why did you drill so many rivets? You could have done with maybe 1/3 of that.
-Henry
Old 03-29-2017, 11:44 PM   #460 (permalink)
notbenh's Avatar
I think someone just wants to be fancy 😋
notbenh is offline   Reply With Quote Quick reply to this message
Old 03-30-2017, 12:03 AM   #461 (permalink)
Lonely White Girl
aidandj's Avatar
didnt use enough last time. Wasn't happy with it. No such thing as overkill.
1990
1972
- My true love
Old 03-30-2017, 08:50 AM   #462 (permalink)
hox
hox's Avatar
Originally Posted by aidandj View Post
didnt use enough last time. Wasn't fancy enough. No such thing as overkill.
FTFY
Something to consider when driving to Laguna Seca
hox is offline   Reply With Quote Quick reply to this message
Old 03-30-2017, 09:16 AM   #463 (permalink)
notbenh's Avatar
I'd hate to see what happens when Aidan gets a bedazler 🤗
Old 03-31-2017, 10:21 AM   #464 (permalink)
Lonely White Girl
aidandj's Avatar
External Temp
Street car stuff.
Once I build a heat shield for the intake filter this should be pretty close to exterior temp. Especially if i get a NACA duct in there.
1990
1972
- My true love
Old 04-01-2017, 12:58 AM   #465 (permalink)
Lonely White Girl
aidandj's Avatar
Socket cap screw all of the things
Put the butterflies back in. Special China Loctite.
1990
1972
- My true love
Old 04-01-2017, 06:28 AM   #466 (permalink)
oregonmon's Avatar
Just realized you're not running a squaretop.
Sent from my SM-N920V using Tapatalk
Old 04-01-2017, 07:58 AM   #467 (permalink)
Lonely White Girl
aidandj's Avatar
Am not. VICS should be worth a little down low I'm thinking. Which matters more to me that up top.
1990
1972
- My true love
Old 04-01-2017, 05:39 PM   #468 (permalink)
Lonely White Girl
aidandj's Avatar
Its baffling how much rtv these need
dirty valves are dirty
quick spin through a brass wire wheel.
Good to go.
1990
1972
- My true love
Old 04-01-2017, 08:51 PM   #469 (permalink)
Lonely White Girl
aidandj's Avatar
Belt sander makes short work of the stage 8 clips.
1990
1972
- My true love
Old 04-04-2017, 10:18 PM   #470 (permalink)
Lonely White Girl
aidandj's Avatar
Oil cooler sealed to the radiator. Will probably use the same stuff to seal the intercooler to the radiator.
Grommet for the O2 sensor wiring
Finally got some SFI padding. Same stick will be going on the other side.
1990
1972
- My true love
Old 04-05-2017, 08:30 AM   #471 (permalink)
I own Laz and you don't.
greddygalant's Avatar
Any ETA on motor? Want to see 20psi track day videos asap!
Old 04-05-2017, 08:32 AM   #472 (permalink)
Lonely White Girl
aidandj's Avatar
Always seems to be "it will be done next week" I'm over it. I haven't driven this car since MRLS. It's been too long
1990
1972
- My true love
Old 04-05-2017, 01:07 PM   #473 (permalink)
shlammed's Avatar
ask for the bits back and it will get done pretty quick.
HellaFab Instagram:
shlammed is offline   Reply With Quote Quick reply to this message
Old 04-05-2017, 01:11 PM   #474 (permalink)
Lonely White Girl
aidandj's Avatar
I'm not working directly with the machine shop. A friend works at a shop that deals with them. Guess they were swamped this winter, and this isn't standard practice for them. The ACL bearing shortage going on right now didn't help either.
1990
1972
- My true love
Old 04-10-2017, 08:54 PM   #475 (permalink)
Lonely White Girl
aidandj's Avatar
Talking shit a buddy got me thinking that I wanted a coolant pressure sensor. Just another idiot light in case something goes wrong. So I got out the JB weld and made something happen
1990
1972
- My true love
Old 04-16-2017, 12:54 PM   #476 (permalink)
Lonely White Girl
aidandj's Avatar
Went over to oregonmon's place so he could work some magic on my new hood. Single stage paint can shine. Too bad the rest of the paint looks like ass. Maybe i'll try and make it over when the car is running.
Did some injector rehab
1990
1972
- My true love
Old 04-16-2017, 02:03 PM   #477 (permalink)
notbenh's Avatar
Wondering if there's an epoxy coating you could use to keep the hood looking that good?
Old 04-16-2017, 08:30 PM   #478 (permalink)
Lonely White Girl
aidandj's Avatar
I really need the motor back. I'm starting to make up projects. Found a place for a trans temp sensor on the second try. This is my spare trans, so it got plugged for now.
1990
1972
- My true love
Old 04-17-2017, 03:35 PM   #479 (permalink)
oregonmon's Avatar
I am a magician.
Old 04-21-2017, 09:36 PM   #480 (permalink)
Lonely White Girl
aidandj's Avatar
Photo dump
1990
1972
- My true love
